    DWC Z - Axis Movement off by Factor 10
    1.4k
    • BoAundefined
      BoA @Frederik
      @Frederik Make a picture. will be faster.
      • Frederikundefined
        Frederik
        according to the BOM:
        8mm Metric ACME Lead Screw
        BoAundefined 1 Reply Last reply Reply Quote 0
        • BoAundefined
          BoA @Frederik
          @Frederik If this is Tr8x8 with 1.9deg stepper and 16microsteps it should be 400steps/mm
          Also seems movement parameters section is doubled for some reason.
          • Frederikundefined
            Frederik
            • Vetiundefined
              Veti
              thats a 4 start tr8 leadscrew
              it has an 8mm pitch
              • BoAundefined
                BoA @Veti
                @Veti So as I wrote, 1.9deg, 16 microsteps, 8mm pitch - 400steps/mm. Not ~4000 or 2560.
                And... what kind of extruder You have that E steps/mm are so.. not a round number?
                Frederikundefined 1 Reply Last reply Reply Quote 1
                • Frederikundefined
                  Frederik
                  thanks a lot, i will try the new values 😉
                  • BoAundefined
                    BoA @Frederik
                    @Frederik And cleanup You config. Seems
                    M92 X160.00 Y160.00 Z2560.00 E837.02 ; set steps per mm
                    M203 X12000.00 Y12000.00 Z1800.00 E1200.00 ; set maximum speeds (mm/min)
                    M201 X500.00 Y500.00 Z30.00 E250.00 ; set accelerations (mm/s^2)
                    M906 X1800 Y1800 Z1000 E1200 I30 ; set motor currents (mA) and motor idle factor in per cent
                    M84 S30 ; Set idle timeout
                    M208 X400 Y400 Z400 S0 ; set axis maxima
                    M574 X2 S1 P"!io1.in" ; configure active-high endstop for high end on X via pin !io1.in
                    M574 Y1 S1 P"!io0.in" ; configure active-high endstop for low end on Y via pin !io0.in
                    is duplicated
                    • Frederikundefined
                      Frederik
                      MY other question is about the LAser FIlament Sensor:
                      I only Found the following Line in the dozuki for RRF 3.x
                      M591 D0 P5 C"e0_stop" R40:120 E3.0 S0 ; Duet3D laser sensor for extruder drive 0, connected to endstop input 3 (E0), tolerance 40 to 120%, 3mm comparison length, disabled
                      would this work on my duet 3 (connected to io3)
                      M950 J3 C"!^io3.in" ; Input 3, inverted, pullup enabled
                      M591 D0 P5 C"io3.in" R40:120 E3.0 S1 ; Duet3D laser sensor for extruder drive 0, connected to IO 3,
                      tolerance 40 to 120%, 3mm comparison length, enabled
                      • Frederikundefined
                        Frederik @BoA
                        @BoA oh, i see, thats a copy and paste error.... in my config its only once
                        • BoAundefined
                          BoA @Frederik
                          @Frederik said in DWC Z - Axis Movement off by Factor 10:
                          I would remove this one.
                          Frederikundefined 1 Reply Last reply Reply Quote 0
                          • Frederikundefined
                            Frederik @BoA
                            @BoA so only this line :
                            M591 D0 P5 P"io3.in" R40:120 E3.0 S1
                            the green light flashes constantly and when i move the filament i respnds with faster blinking.
                            is this all i need ? no extra pause and resume command ?
                            • BoAundefined
                              BoA @Frederik
                              @Frederik Should be fine. But I am guessing when filament monitoring shows some problems pause.g is executed to pause the print.
                              You can check sensor status by M591 D0
                              • Frederikundefined
                                Frederik @BoA
                                @BoA my extruder Setup:
                                Original Bondtech BMG with a E3d Volcano with 0.4 mm micro swiss nozzle and titan heatbreak. 40W Heater and Thermistor 100K
                                0.9° Pancake Stepper
                                bedheater: 220V AC1.2 kW Keenovo Silicone Pad 400x400
                                • Frederikundefined
                                  Frederik
                                  @BoA said in DWC Z - Axis Movement off by Factor 10:
                                  M591 D0
                                  Response: Extruder 0 has no Filament Sensor
                                  • BoAundefined
                                    BoA @Frederik
                                    @Frederik BMG with 0.9 stepper + 16 microsteps should have 830steps/mm
                                    • Frederikundefined
                                      Frederik
                                      i will try it. on moment
                                      • BoAundefined
                                        BoA @Frederik
                                        @Frederik Paste Your config.g only and result of
                                        M98 P"config.g"
                                        • Frederikundefined
                                          Frederik
                                          ; generated by RepRapFirmware Configuration Tool v3.1.7 on Wed Nov 18 2020 18:04:17 GMT+0100 (Mitteleuropäische Normalzeit)
                                          M550 P"Duet 3" ; set printer name
                                          M669 K1 ; switch to CoreXZ mode and multiply motor movements by 3 for the Z axis
                                          M569 P0.0 S0 ; physical drive 0.0 goes backwards
                                          M569 P0.1 S0 ; physical drive 0.1 goes backwards
                                          M569 P0.2 S0 ; physical drive 0.2 goes backwards
                                          M569 P0.3 S0
                                          M569 P0.4 S0
                                          M569 P0.5 S1 ; physical drive 0.5 goes forwards
                                          M584 X0.1 Y0.0 Z0.2:0.3:0.4 E0.5 ; set drive mapping
                                          M671 X425:200:-25 Y240:-25:240 S1 P1.25 ; leadscrews at front left, rear middle and front right with 1mm per screw compensation
                                          ; Movement Parameters
                                          M350 X16 Y16 Z16 E16 I1 ; configure microstepping without interpolation
                                          M92 X160.00 Y160.00 Z400.00 E830.00 ; set steps per mm
                                          M906 X1800 Y1800 Z800 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
                                          M208 X400 Y400 Z385 S0 ; set axis maxima
                                          M574 Z2 S2 ; configure Z-probe endstop for low end on Z
                                          ; Duet Laser Filament Sensor
                                          M591 D0 P5 P"io3.in" R40:120 E3.0 S1 ; Duet3D laser sensor for extruder drive 0, connected to IO 3,
                                          M92 X160.00 Y160.00 Z400.00 E837.02 ; set steps per mm
                                          M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
                                          M558 P9 C"^io7.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
                                          G31 P500 X-26 Y2 Z2.5 ; set Z probe trigger value, offset and trigger height
                                          M557 X0:400 Y0:400 S20 ; define mesh grid
                                          M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
                                          M143 H0 S200 ; set temperature limit for heater 0 to 200C
                                          M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin temp1
                                          M950 F0 C"out8" Q500 ; create fan 0 on pin out8 and set its frequency
                                          M106 P0 C"Hotend" S1 H1 T45 ; set fan 0 name and value. Thermostatic control is turned on
                                          M950 F1 C"!out4" Q500 ; create fan 1 on pin !out4 and set its frequency
                                          M106 P1 C"Bauteildüse" S1 H-1 ; set fan 1 name and value. Thermostatic control is turned off
                                          M563 P0 S"E3D V6 0.4 Steel" D0 H1 F0:1 ; define tool 0
                                          T0 ; select first tool
                                          • Vetiundefined
                                            Veti
                                            this section is still in your config twice
