    DWC Z - Axis Movement off by Factor 10
    1.4k
    • BoAundefined
      BoA @Frederik
      @Frederik And cleanup You config. Seems
      M92 X160.00 Y160.00 Z2560.00 E837.02 ; set steps per mm
      M203 X12000.00 Y12000.00 Z1800.00 E1200.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z30.00 E250.00 ; set accelerations (mm/s^2)
      M906 X1800 Y1800 Z1000 E1200 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X400 Y400 Z400 S0 ; set axis maxima
      M574 X2 S1 P"!io1.in" ; configure active-high endstop for high end on X via pin !io1.in
      M574 Y1 S1 P"!io0.in" ; configure active-high endstop for low end on Y via pin !io0.in
      is duplicated
      Frederikundefined 1 Reply Last reply Reply Quote 1
      • Frederikundefined
        Frederik
        MY other question is about the LAser FIlament Sensor:
        I only Found the following Line in the dozuki for RRF 3.x
        M591 D0 P5 C"e0_stop" R40:120 E3.0 S0 ; Duet3D laser sensor for extruder drive 0, connected to endstop input 3 (E0), tolerance 40 to 120%, 3mm comparison length, disabled
        would this work on my duet 3 (connected to io3)
        M950 J3 C"!^io3.in" ; Input 3, inverted, pullup enabled
        M591 D0 P5 C"io3.in" R40:120 E3.0 S1 ; Duet3D laser sensor for extruder drive 0, connected to IO 3,
        tolerance 40 to 120%, 3mm comparison length, enabled
        BoAundefined 1 Reply Last reply Reply Quote 0
        • Frederikundefined
          Frederik @BoA
          @BoA oh, i see, thats a copy and paste error.... in my config its only once
          • BoAundefined
            BoA @Frederik
            @Frederik said in DWC Z - Axis Movement off by Factor 10:
            I would remove this one.
            Frederikundefined 1 Reply Last reply Reply Quote 0
            • Frederikundefined
              Frederik @BoA
              @BoA so only this line :
              M591 D0 P5 P"io3.in" R40:120 E3.0 S1
              the green light flashes constantly and when i move the filament i respnds with faster blinking.
              is this all i need ? no extra pause and resume command ?
              • BoAundefined
                BoA @Frederik
                @Frederik Should be fine. But I am guessing when filament monitoring shows some problems pause.g is executed to pause the print.
                You can check sensor status by M591 D0
                • Frederikundefined
                  Frederik @BoA
                  @BoA my extruder Setup:
                  Original Bondtech BMG with a E3d Volcano with 0.4 mm micro swiss nozzle and titan heatbreak. 40W Heater and Thermistor 100K
                  0.9° Pancake Stepper
                  bedheater: 220V AC1.2 kW Keenovo Silicone Pad 400x400
                  • Frederikundefined
                    Frederik
                    @BoA said in DWC Z - Axis Movement off by Factor 10:
                    M591 D0
                    Response: Extruder 0 has no Filament Sensor
                    • BoAundefined
                      BoA @Frederik
                      @Frederik BMG with 0.9 stepper + 16 microsteps should have 830steps/mm
                      • Frederikundefined
                        Frederik
                        i will try it. on moment
                        • BoAundefined
                          BoA @Frederik
                          @Frederik Paste Your config.g only and result of
                          M98 P"config.g"
                          • Frederikundefined
                            Frederik
                            ; generated by RepRapFirmware Configuration Tool v3.1.7 on Wed Nov 18 2020 18:04:17 GMT+0100 (Mitteleuropäische Normalzeit)
                            M550 P"Duet 3" ; set printer name
                            M669 K1 ; switch to CoreXZ mode and multiply motor movements by 3 for the Z axis
                            M569 P0.0 S0 ; physical drive 0.0 goes backwards
                            M569 P0.1 S0 ; physical drive 0.1 goes backwards
                            M569 P0.2 S0 ; physical drive 0.2 goes backwards
                            M569 P0.3 S0
                            M569 P0.4 S0
                            M569 P0.5 S1 ; physical drive 0.5 goes forwards
                            M584 X0.1 Y0.0 Z0.2:0.3:0.4 E0.5 ; set drive mapping
                            M671 X425:200:-25 Y240:-25:240 S1 P1.25 ; leadscrews at front left, rear middle and front right with 1mm per screw compensation
                            ; Movement Parameters
                            M350 X16 Y16 Z16 E16 I1 ; configure microstepping without interpolation
                            M92 X160.00 Y160.00 Z400.00 E830.00 ; set steps per mm
                            M906 X1800 Y1800 Z800 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
                            M208 X400 Y400 Z385 S0 ; set axis maxima
                            M574 Z2 S2 ; configure Z-probe endstop for low end on Z
                            ; Duet Laser Filament Sensor
                            M591 D0 P5 P"io3.in" R40:120 E3.0 S1 ; Duet3D laser sensor for extruder drive 0, connected to IO 3,
                            M92 X160.00 Y160.00 Z400.00 E837.02 ; set steps per mm
                            M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
                            M558 P9 C"^io7.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
                            G31 P500 X-26 Y2 Z2.5 ; set Z probe trigger value, offset and trigger height
                            M557 X0:400 Y0:400 S20 ; define mesh grid
                            M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
                            M143 H0 S200 ; set temperature limit for heater 0 to 200C
                            M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin temp1
                            M950 F0 C"out8" Q500 ; create fan 0 on pin out8 and set its frequency
                            M106 P0 C"Hotend" S1 H1 T45 ; set fan 0 name and value. Thermostatic control is turned on
                            M950 F1 C"!out4" Q500 ; create fan 1 on pin !out4 and set its frequency
                            M106 P1 C"Bauteildüse" S1 H-1 ; set fan 1 name and value. Thermostatic control is turned off
                            M563 P0 S"E3D V6 0.4 Steel" D0 H1 F0:1 ; define tool 0
                            T0 ; select first tool
                            • Vetiundefined
                              Veti
                              this section is still in your config twice
                              • Frederikundefined
                                Frederik
                                config (1).g
                                wow, i dont know why its doubling these lines 😮 ?!?
                                • Frederikundefined
                                  Frederik
                                  in my normal config. in DWC there is this section only once
                                  • BoAundefined
                                    BoA @Frederik
                                    @Frederik drag and drop file instead of copy paste content
                                    • Frederikundefined
                                      Frederik
                                      ok.
                                      i restartet my DWC and now it looks good i think 🙂
                                      • Frederikundefined
                                        Frederik
                                        config (1).g
                                        • Frederikundefined
                                          Frederik
                                          M591
                                          i get always the error M591 no pin name given.
                                          do i have to use the m950 command befor to create a pin ?
                                          • BoAundefined
                                            BoA @Frederik
                                            @Frederik M591 D0 P5 P"io3.in" R40:120 E3.0 S1 should be
