    First Layer and Extrusion Problems
    5.8k
    • Frederikundefined
      Frederik
      what could be the cause of this message :
      G28 Z
      Error: Z probe already triggered at start of probing move
      Error: Homing failed
      i got this message on every 4th or 5th try to home z.
      its a genuine bltouch
      • Vetiundefined
        Veti
        that sounds like a wiring probem
        Frederikundefined 1 Reply Last reply Reply Quote 0
        • Frederikundefined
          Frederik @Veti
          @Veti i tought, perhaps its the standard and would be better for compatibility or troubleshoooting reasons...
          • Vetiundefined
            Veti @Frederik
            @Frederik
            no the standard is 0,0 is bottom left.
            • Frederikundefined
              Frederik @Veti
              @Veti ok , one moment i will check it with my multimeter... could it be a bad crimp ?
              • fcwiltundefined
                fcwilt @Frederik
                @Frederik said in First Layer and Extrusion Problems:
                I could only mount the Endstop on the left side of my carriage and the Y Endstop is at the back
                The location of the end stop sensors do not determine where 0, 0 is located.
                End stop sensors are used during homing, true, but they only "tell" the firmware the hardware is in a known location, which may be at the axis min, the axis max or somewhere else.
                It is common to have 0, 0 at the left front corner of the bed. Another option is to have 0, 0 at the center of the bed - that is the what I do.
                • Frederikundefined
                  Frederik @fcwilt
                  @fcwilt Ah ok, now i got it ๐Ÿ™‚
                  • Frederikundefined
                    Frederik
                    so, now to a new start... nozzle free again, probe working (was a light loose crimp pin on the black wire)
                    • Frederikundefined
                      Frederik
                      ok ,looks good so far. i startet my first 20mm xyz test cube ๐Ÿ™‚ fingers crossed , i hope it will run through without clogging
                      • Frederikundefined
                        Frederik
                        This is my very first successful Print:
                        It should be 20x20x20
                        And the actual dimensions are
                        X 20.10 MM WITH STEPS 160
                        Y 20.10 MM EITH STEPS 160
                        Z 20.40 MM WITH STEPS 400
                        • Vetiundefined
                          Veti
                          you have not calibrated you e steps yet
                          • Frederikundefined
                            Frederik @Veti
                            @Veti i forgot E 830
                            • Vetiundefined
                              Veti @Frederik
                              i forgot E 830
                              i dont know what you mean by that
                              here is a guide on how to calibration it
                              https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40#s165
                              • Frederikundefined
                                Frederik @Veti
                                @Veti My extruder steps are correct. 100mm are 100mm
                                • Vetiundefined
                                  Veti
                                  the bottom looks a bit strange, did you enable raft?
                                  • Frederikundefined
                                    Frederik @Veti
                                    @Veti brim was activated. but iยดm struggling with the z offset a little bit. sometimes its really good , on the next try its scrubbing over the bed.
                                    The cube was also printed on the backside of my buildplate. not the pei side to avoid any additional damage to my surface. ๐Ÿ˜ž
                                    i adjusted the bed to the subframe assembly with my digital calipers to ~ 0.05mm equal distances.
                                    then i checked my bltouch mountig if it is perpenticular to the bed. that is also good.
                                    then i homed z.
                                    after that a true bed level with G32
                                    another G32
                                    Then mesh compensation with G29 and another G32 to Load the new Heightmap.
                                    Now im testing with ABS Filament. because the pla before was constantly clogging in the heatbreak.
                                    i adjustet my retraction to 1mm with 25mm/s speed and will see if it will be better. i have zero stringing with these settings.
                                    • Vetiundefined
                                      Veti @Frederik
                                      another G32
                                      that is not a good idea. the G32 after the G29 will mess up the mesh. also after running G32 you need to establish a new Z
                                      Frederikundefined A Former User? 2 Replies Last reply Reply Quote 0
                                      • Frederikundefined
                                        Frederik @Veti
                                        @Veti oh, I didn't know that. Then I wonยดt do a G32 after the G28 anymore ๐Ÿ™‚
                                        is the software handling everything after the G32 automatically from the heightmap every time I start a new print?
                                          A Former User @Veti
                                          @Veti said in First Layer and Extrusion Problems:
                                          If you have a bed.g like below you already re-establish the Z datum all in one go.......
                                          ; bed.g
                                          G28                         ; Home all
                                          G30 P0 X2 Y-2 Z-99999       ; Probe near the front left lead-screw
                                          G30 P1 X152 Y278 Z-99999    ; Probe near the rear lead screw
                                          G30 P2 X290 Y-2 Z-99999 S3  ; Probe near the front right lead-screw
                                          G30 P0 X2 Y-2 Z-99999       ; Probe near the front left lead-screw (Second Pass)
                                          G30 P1 X152 Y278 Z-99999    ; Probe near the rear lead screw (Second Pass)
                                          G30 P2 X290 Y-2 Z-99999 S3  ; Probe near the front right lead-screw (Second Pass)
                                          G91                         ; Switch to relative positioning moves
                                          G1 H2 Z5 F8000              ; Drop the Z axis (the bed) by 5mm relative to its current position
                                          G90                         ; Revert back to absolute positioning moves
                                          G1 X160 Y155 F8000          ; Position the nozzle at the centre of the bed
                                          G30                         ; Probe and set the height as probed
                                          G29 S1 P"heightmap.csv"     ; Load the height map
                                            A Former User @Frederik
                                            G32 must be initiated AFTER the printer has homed all axises otherwise the printer has NO reference to work from.
                                            Here is what the Duet G-Code dozuki lists G28 & G32 as :
                                            G28 Home
                                            Example
                                            G28 ; Home all axes
                                            The purpose of homing is to allow the printer to obtain a reference of where it is in space.
                                            G32: Run bed.g macro
                                            Parameters
                                            None
                                            Example
                                            G32:
                                            The firmware executes macro file bed.g. This macro normally uses G30 commands to probe the bed and then perform auto calibration of a delta printer (see Calibrating a delta printer), or perform bed leveling by moving the Z leadscrews independently, or display the manual corrections needed to the bed levelling screws.
                                            So if you do not carry out G28 before you attempt to carry out G32 you will receive and error message ; Not enough axises homed
                                            Unless the printer was already homed which is what G28 does anyway.....
