    Newbie: New Install on Ender 5 Plus---Willing to PAY$$$
    7.2k
    • shattyundefined
      shatty @Veti
      @Veti I tested endstops already under settings and machine specific. X and Y work
      • Vetiundefined
        Veti
        G1 X-1.3000000000000007 Y1 F6000 ; go to first bed probe point and home Z
        replace that with
        G1 X50 Y50 F600
        when exactly does it try to move past the endstops?
        during the first move?
        shattyundefined 1 Reply Last reply Reply Quote 0
        • shattyundefined
          shatty @Veti
          @Veti Yes. I tried that setting and no good. Its random in which direction it goes to home and it just slams at the end of each axis.
          • shattyundefined
            shatty
            ; homeall.g
            ; called to home all axes
            ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Nov 15 2020 03:22:47 GMT-0500 (Eastern Standard Time)
            G91 ; relative positioning
            G1 H1 X-355 Y-355 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
            G1 H2 X5 Y5 F6000 ; go back a few mm
            G1 H1 X-355 Y-355 F360 ; move slowly to X and Y axis endstops once more (second pass)
            G90 ; absolute positioning
            G1 X50 Y50 F600 ; go to first bed probe point and home Z
            ;G91 ; relative positioning
            ;G90 ; absolute positioning
            M550 P"E5Plus" ; set printer name
            M551 P"xxxx" ; set password
            M552 S1 ; enable network
            M586 P0 S1 ; enable HTTP
            M586 P1 S0 ; disable FTP
            M586 P2 S0 ; disable Telnet
            M569 P2 S0 ; physical drive 2 goes backwards
            M92 X80.00 Y80.00 Z800.00 E412.60 ; set steps per mm
            M566 X1200.00 Y1200.00 Z60.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
            M203 X9000.00 Y9000.00 Z1200.00 E6000.00 ; set maximum speeds (mm/min)
            M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
            M906 X800 Y800 Z1400 E1000 I50 ; set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M208 X350 Y350 Z400 S0 ; set axis maxima
            M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
            M558 P9 C"^zprobe.in" H5 F600 T6000 ; set Z probe type to bltouch and the dive height + speeds
            G31 P500 X16.3 Y14 Z1.7 ; set Z probe trigger value, offset and trigger height
            M557 X15:190 Y15:190 S20 ; define mesh grid
            M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
            M143 H0 S110 ; set temperature limit for heater 0 to 110C
            M308 S1 P"e0temp" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin e0temp
            M143 H1 S280 ; 280 deg max on hot end
            M106 P0 S1 H1 ; set fan 0 value. Thermostatic control is turned off
            • Vetiundefined
              Veti @shatty
              @shatty said in Newbie: New Install on Ender 5 Plus---Willing to PAY$$:
              i have never heard of this happening.
              let me get this straight.
              you home your printer. it moves to the right?
              you restart the printer it moves to the left?
              post the output of M119 when no endstop is pressed.
              post the output of M119 when only the enstop for the x axis is pressed
              • shattyundefined
                shatty @Veti
                @Veti
                When I turn it on, nothing moves unless i press the home button. There is no telling which direction it will go if i center the extruder in the middle of the area. Where am I supposed to set the hotend before I turn on the printer?
                • Vetiundefined
                  Veti @shatty
                  @shatty
                  please test the stepper motor direction using this
                  https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Checking_connected_stepper_motors
                  report for x y and z
                  • shattyundefined
                    shatty
                    Heres a video of what it does....
                    https://drive.google.com/file/d/1IeBbFe_YLu9XSz0GbuNmigxwDfcq57Ay/view?usp=sharing
                    • Vetiundefined
                      Veti
                      please do the testing from the webui to rule out a bad touch screen connection.
                      • Vetiundefined
                        Veti
                        btw what is that strange sound at the start of the homing?
                        • shattyundefined
                          shatty @Veti
                          @Veti said in Newbie: New Install on Ender 5 Plus---Willing to PAY$$:
                          TS is fine.
                          Anyways....hitting any positive value will move each toward the endstop switch...The Z is not right..Looks like they are fighting each other
                          Vetiundefined 2 Replies Last reply Reply Quote 0
                          • shattyundefined
                            shatty @Veti
                            The Z axis motors are fighting each other.
                            • Vetiundefined
                              Veti @shatty
                              that would indicate that your motors are turning in the wrong direction.
                              • shattyundefined
                                shatty @Veti
                                @Veti
                                OK Let me fix that.
                                • Vetiundefined
                                  Veti @shatty
                                  that means on of your motors is wired in the opposite direction
                                  • Vetiundefined
                                    Veti @shatty
                                    TS is fine.
                                    i beg to differ. The bad command 55 at the end is an indication.
                                    • shattyundefined
                                      shatty @Veti
                                      @Veti Thats because I hit stop
                                      Not the motors are moving away from endstops with hitting the positive values. Z still fighting each other. They are in series config because there are 2 on 1 driver
                                      • shattyundefined
                                        shatty
                                        Paneldue5i is connected with ribbon cable only. How can it be wrong?
                                        • Vetiundefined
                                          Veti @shatty
                                          that mean you have to reverse the wiring of one of your stepper motors
                                          • shattyundefined
                                            shatty @Veti
                                            @Veti
                                            OK. TY. Hopefully I can gain progress now.
