Solved Duet3 config Frustration
I just wanted to see this new printer print. And guess what, it's printing. But the part fan isn't turning on automatically. I have to turn it on manually. This must be that F setting on the tool I was playing with before but have no idea how to set it... As I can manually turn the fan on, and it turns on, on the correct tool from DWC... I am not sure what to do to fix this at the moment.
Tool part cooling fan is swapped. That is the problem. Where do I make that change?
@BlueDust said in Duet3 config Frustration:
Post your config.g file [again] and we'll tell you.
So I think I fixed it, as it appears to be working right now... Will not know until I print something with the 2nd tool...Is this is my current gcode.
Looking at this...
M563 P0 S"LeftExtruder" D0 H1 F0:1Does the 0 and 1 match up with the Pn parameter under the fans? If it does, I am having a hard time understanding what goes to what between the different Gcode commands, as the letters do not match from one to the other. If it's not obvious, I haven't figured out the logic and not able to easily make the connections to different settings in RepRap 3 yet...
; Fans M950 F0 C"out5" Q500 M106 P0 S0 H-1 M950 F1 C"out8" Q500 M106 P1 S1 H1 T40 M950 F2 C"out4" Q500 M106 P2 S0 H-1 M950 F3 C"out7" Q500 M106 P3 S1 H0 T40 ; Tools M563 P1 S"RightExtruder" D1 H0 F2:3 G10 P1 X0 U0 Y0 Z0 G10 P1 R0 S0 M563 P0 S"LeftExtruder" D0 H1 F0:1 G10 P0 X0 U0 Y0 Z0 G10 P0 R0 S0
The F parameter in M563 matches up with the F parameter in M950 and the P parameter in M106.
Thank you!
If I would like to have independent Z motors on a IDEX Cortesian printer for auto bed tramming, would DUET 3 EXPANSION BOARD 3HC, be the correct expansion board to get, or is there another, possibly better option? Is there anything else I would need to make it work?
How many of the 6 internal drivers are you using?
The 3HC expansion would probably be the best way to add more drivers, unless you wanted to use tool board for the print head and free up a driver that way.
@Phaedrux
I am using all 6.Left Extruder
Right Extruder
X Axis
U Axis
Y Axis
Z Axis (two motors tied into one driver). -
Similar issue to the fan problem...
If I try to print with the only the 2nd tool, it will heat up and extrudes plastic, but the 1st tool will make the movements.... Thanks for the help!; Drives M569 P0.1 S1 ; physical drive 0.1 goes forwards M569 P0.5 S1 ; physical drive 0.5 goes forwards M569 P0.0 S0 ; physical drive 0.0 goes forwards M569 P0.3 S0 ; physical drive 0.3 goes forwards M569 P0.2 S1 ; physical drive 0.2 goes forwards M584 X0.1 Y0.5 Z0.0 U0.4 E0.3:0.2 M350 X16 U16 Y16 Z16 E16:16 I1 M92 X160.00 U160.00 Y160.00 Z800.00 E844.45:844.45 M566 X900.00 U900.00 Y900.00 Z12.00 E2000:2000 M203 X6000.00 U6000.00 Y6000.00 Z180.00 E3600:36000 M201 X400.00 U400.00 Y500.00 Z20.00 E10000:10000 M906 X1000 U1000 Y1200 Z1800 E1000:1000 I30 M84 S30 ; Set idle timeout M572 D0 S0.06 ; Pressure Advance ; Axis Limits M208 X-52 U0 Y0 Z0 S1 ; set axis minima M208 X300 U352 Y300 Z380 S0 ; set axis maxima ; Endstops M574 X1 S3 M574 Y1 S3 M574 U2 S3 M574 Z1 S2 ; Z-Probe M950 S4 C"io4.out" M558 P9 C"^io4.in" H5 F100 R0.2 T6000 A5 B0 G31 P500 X-30 Y-12 Z3.58 M557 X30:270 Y20:280 P2 ; Heaters M308 S0 P"temp0" Y"thermistor" T100000 B4138 M950 H0 C"out1" T0 M307 H0 B0 S1.00 M308 S1 P"temp1" Y"thermistor" T100000 B4138 M950 H1 C"out2" T1 M307 H1 B0 S1.00 M308 S2 P"temp2" Y"thermistor" T100000 B4138 M950 H2 C"out3" T2 M307 H2 B0 S1.00 M140 H2 M143 H2 S145 ; Fans M950 F0 C"out5" Q500 M106 P0 S0 H-1 M950 F1 C"out8" Q500 M106 P1 S1 H1 T40 M950 F2 C"out4" Q500 ; M106 P2 S0 H-1 M950 F3 C"out7" Q500 M106 P3 S1 H0 T40 ; Tools but hotend cooling does not M563 P1 S"RightExtruder" D1 H0 F2:3 G10 P1 X0 U0 Y0 Z0 G10 P1 R0 S0 M563 P0 S"LeftExtruder" D0 H1 F0:1 G10 P0 X0 U0 Y0 Z0 G10 P0 R0 S0
I just noticed, that both tools have X and U listed... Shouldn't the tools only have the Axis they will be on? But that is the Axis offset...
I can move all the tools manually from DWC or the PanelDue. My homeall.g also works for all axis.
Do you get any errors sending M98 P"config.g" ?
See here for tool configuration. I think your first tool should only have X and not U.
Yes.
11/23/2020, 8:39:31 PM M98 P"config.g"
Warning: M307: Heater 2 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
Warning: M307: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 672C
Warning: M307: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 478C
Warning: M307: Heater 2 appears to be over-powered. If left on at full power, its temperature is predicted to reach 243C
11/23/2020, 8:33:41 PM Warning: Obsolete use of S parameter on G1 command. Use H parameter instead. -
That would indicate you've got an G1 S1 in your homing files where it should be G1 H1.
That's one possibility. You should connect the 3 Z motors to the main board. Probably best to also connect X, Y and U moors to the main board, and the E motors to the expansion board.
Another possibility is to use two tool boards, This may be the best solution if your extruders are direct drive and you can accommodate the tool boards in the print carriages.
This is the printer/kit I built.
https://www.ratrig.com/3d-printing-cnc/3d-printer-kits/all-3d-printer-kits/rat-rig-v-cast.htmlI only really need one tool board for one extruder, but not sure how I would mount it to the carriage. If I did that, I could see getting two, one for each hotend.... If I did that, wouldn't I need the DUET 3 TOOL DISTRIBUTION BOARD, and then 2x DUET 3 TOOLBOARD 1LC?
@Phaedrux
I rearranged the tool gcode to make it easier to understand in config.g, and that error is gone.
I didn't see a G1 and an S1.... So not sure what it was complaining about.11/24/2020, 8:46:10 AM M98 P"config.g"
Warning: M307: Heater 2 appears to be over-powered. If left on at full power, its temperature is predicted to reach 243C -
The tool distribution board isn't essential, but it makes the CAN and power wiring to the tool boards easier.
Are you saying I could wire in two, DUET 3 TOOLBOARD 1LCs directly into the Duet3 (without a Distribution Board)?
When reviewing the instructions, it looked like I could only wire one directly to the Duet 3 at a time.
