    Duet reboot when trying to heat bed
    673
    • hmmatosundefined
      hmmatos @A Former User
      @bearer
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
      Board ID: 08DGM-917DA-G4MS4-6J9DL-3SD6L-TVYZA
      Used output buffers: 3 of 24 (10 max)
      Static ram: 27980
      Dynamic ram: 93860 of which 24 recycled
      Exception stack ram used: 264
      Never used ram: 8944
      Tasks: NETWORK(ready,368) HEAT(blocked,1224) MAIN(running,1848) IDLE(ready,80)
      Owned mutexes: WiFi(NETWORK)
      Last reset 00:00:18 ago, cause: power up
      Last software reset at 2020-11-22 23:43, reason: User, spinning module GCodes, available RAM 8944 bytes (slot 3)
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
      Error status: 0
      MCU temperature: min 15.0, current 15.9, max 16.2
      Supply voltage: min 12.1, current 12.2, max 12.3, under voltage events: 0, over voltage events: 0, power good: yes
      Date/time: 2020-11-23 16:42:56
      Cache data hit count 30199406
      Slowest loop: 3.34ms; fastest: 0.12ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 3.0ms, write time 0.0ms, max retries 0
      Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
      === MainDDARing ===
      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
      === AuxDDARing ===
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 16.16ms; fastest: 0.00ms
      Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
      HTTP sessions: 1 of 8
      • WiFi -
        Network state is active
        WiFi firmware version 1.23
        WiFi MAC address ec:fa:bc:2d:e7:66
        WiFi Vcc 3.35, reset reason Unknown
        WiFi flash size 4194304, free heap 24416
        WiFi IP address 192.168.1.100
        WiFi signal strength -61dBm, reconnections 0, sleep mode modem
      • hmmatosundefined
        hmmatos @JamesM
        @JamesM
        I have run this exact setup for more than a year, now the board can't handle it?
        • hmmatosundefined
          hmmatos
          I also leave a video
            A Former User
            Given M122 show 'power up' and no complaints about under voltage are you sure it is rebooting?
            I suppose if the power supply has overload protection it could cut the power causing the reboot reason to appear to be 'power up'. But it doesn't fit with the M140 message shown previously.
            hmmatosundefined 1 Reply Last reply Reply Quote 0
            • hmmatosundefined
              @bearer
              did you see the video?
              I don't know if is a reboot it looks like and I lost connection to the board but is a quick thing
              • Vetiundefined
                Veti
                power supplies can go bad, especially cheap ones.
                to rule out a fault with the board, you could connect the hotend to the bed output and see if that can be heated.
                  Can you put your volt meter on the PSU output while you trigger a reset?
                  From your video it does look like the board is resetting, and if it's resetting because of a power off event the M122 would simply report that it was power cycled.
                  Given the draw of the bed maybe it's time to look into either upgrading to 24v psu and all that entails, or at least getting a separate PSU for the bed and switching with a DCDC SSR.
                  @hmmatos said in Duet reboot when trying to heat bed:
                  Pushing the PSU to the limit for a year and now something is failing. That's usually how it goes. Things work until they don't.
                    A Former User @hmmatos
                    incorrectly assumed it related to the bed resistance.
                    but yeah, video does suggest a sag in voltage before overload protection kicks in, but that should have resulted in warning about Vin undervoltage and not M140 Operation has been cancelled. could be one of those things.
                    power supply does climb to the top of the suspect list. which revision of a duet board is it?
                    • hmmatosundefined
                      hmmatos
                      thanks to all, it seems that the problem was in the power supply I did the test with the multimeter as suggested by @Phaedrux and as soon as I turn on the bed it loses power.
                      I experimented with the original CR 10 power supply and all works normally and I think the board was not damaged.
                      Now the dilemma is to buy another power supply (12v) or buy a smaller one (24v) and a new bed to connect directly to the main power (I already have an SSR).
                      The second option is much better but it is much more expensive...
                      https://e3d-online.com/products/high-temperature-heated-beds
                      Do you guys think having two power supplies is a solution?
                      Can I have a 24v power supply for the board and hotend and a 12v one for the bed? is this a good solution?
                      With the intention of upgrading the bed later...
                      achrnundefined 1 Reply Last reply Reply Quote 0
                      • achrnundefined
                        achrn @hmmatos
                        You can have a mains powered heated bed without buying an E3d high temperature bed (which I expect is very good, but is not needed if what you want is a mains heated bed).
                        e.g. https://keenovo.store/ have 110V and 220V beds in numerous shapes and sizes
                        • achrnundefined
                          achrn @achrn
                          @achrn said in Duet reboot when trying to heat bed:
                          110V and 220V beds
                          Sorry - for avoidance of confusion - they have the heaters, not the whole bed - it needs applying to a bed plate.
