Duet 3 and PC local ethernet connection
Can Duet 3 be connected to a PC via ethernet cable and using DWC as control interface? If yes, what are the required changes?
Thank you.
Yes it's possible.
Here's a thread that discusses this configuration.
You would need to manually configure your PC and Duet to have unique IP addresses within the same Subnet.
Ex: 192.168.0.2 and 192.168.0.3
Manually configuring the IP address on your PC is pretty easy. Best to google if you're not sure.
For the Duet, you can specify the IP address in your config.g by editing the M552 command.
ex M552 S1 P192.168.0.3
Then you could access the web interface from the PC browser by using the IP address of the duet in the address bar.
Also make sure you Duet 3 SD card has the /www folder with all the DWC files as well.
@alankilian said in Duet 3 and PC local ethernet connection:
Yes it's possible.
Thanks @alankilian for the link. I went through it before posting, hence I wanted to confirm that the feature would work on duet 3.
@Phaedrux said in Duet 3 and PC local ethernet connection:
Thanks @Phaedrux for the modifications and tips.
