"Z" axis problems CNC
I am working with a Duet 2 controller on my Workbee CNC. Everything use to work fine but lately it doesn't home properly. When I try to home all, the "Z" axis just grinds and slowly moves down causing me to hit the emergency stop. I have gone thru all the settings in the system file and everything looks good as far as bed size goes. I have changed Duet boards thinking it may be the board and it does the same thing. I also changed the Z axis servo motor and that wasn't it either. Please let me know if anyone has had a similar problem and let me know how I may correct this. Thanks in advance to anyone who responds.
More info needed. It moves down, is that the correct direction?
Servo? External driver?
Are the endstops working?
Config and homing files attaches would certainly help others understand whats going on.
Sorry but I'm not sure I understand what you mean by text.
; generated by RepRapFirmware Configuration Tool v3.1.8 on Tue Nov 24 2020 10:04:16 GMT-0600 (Central Standard Time); General preferences
M550 P"My Workbee CNC" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
M208 X230 Y210 Z200 S0 ; set axis maxima; Endstops
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M558 P1 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
homeall
; homeall.g
; called to home all axes
G91 ; relative positioning
G1 H1 X-235 Y-215 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 H2 X5 Y5 F6000 ; go back a few mm
G1 H1 X-235 Y-215 F360 ; move slowly to X and Y axis endstops once more (second pass)
G90 ; absolute positioning
G1 X15 Y15 F6000 ; go to first bed probe point and home Z
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G90 ; absolute positioning -
@onescentpro said in "Z" axis problems CNC:
M584 X0 Y1 Z2 E3 ; set drive mappingI take it you're using stepper motors with the built in drivers and not servo motors?
If z is going the wrong way the simple explanation is perhaps to have plugged it the wrong way around (although if using the supplied connectors that's not something you do by accident)
if you've tried another motor and another board then you're left with the wiring, one of the conductors coming loose sounds like it could be a good fit, but the duet normally alerts to a disconnected phase.
@onescentpro might be a result of the issue rather than the cause, but given your screenshot show an error message 'Z probe already triggered at start of homing move' I'd start there. What type of probe are you using? What value does the probe show in DWC normally/when you tap it by hand?
Maybe try using the R parameter in your M558 so there is a pause for it to settle?
https://duet3d.dozuki.com/Wiki/Gcode#Section_M558_Set_Z_probe_typeI'd also double check the wiring to it
RE Bearer's posting comment, there is a formatting option on the forum when putting your coding which puts it in nice boxes etc to make it easier to read (like the line of text he put). The option is two over from bullet points at the top (you can see in his screenshot).
@bearer , Good morning, I saw and old post from you that mentioned you could log into my computer and take a look. Is that a possibility for you?
@engikeneer Thanks for the reply. I am using the endstops supplied by Ooznest. I have checked the wiring to the stepper motor and its fine. The endstop appears to working fine when I manually close it the light comes on on the Duet so I think it's fine.
@bearer I am using everything that was supplied for the Workbee from Ooznest. Yes, I am using steppers controlled by the Duet
So no Z probe at all?
Your config.g and homing files are setup as if you had a Z probe. Please let me know if that is the case or not.
Thanks for all the input. I got everything up and running. So thanks to all who helped me with this problem.
