    Newbie: New Install on Ender 5 Plus---Willing to PAY$$$
    7.2k
    • Vetiundefined
      Veti
      i would recommend that you get a plated Copper nozzle. it can print pla and carbon fiber as well.
      https://www.aliexpress.com/item/4000007458595.html
      shattyundefined 2 Replies Last reply Reply Quote 0
      • shattyundefined
        shatty
        Any prebuilt filament files I can download anywhere? I might have a brass nozzle somewhere. Im not going to use PLA after this. I have PETG as well as the CF.
        • shattyundefined
          shatty @Veti
          This post is deleted!
          • shattyundefined
            shatty @Veti
            @Veti IMG_2609.HEIC IMG_2610.HEIC IMG_2611.HEIC IMG_2612.HEIC IMG_2613.HEIC IMG_2616.HEIC IMG_2617.HEIC IMG_2618.HEIC
            • Vetiundefined
              Veti @shatty
              @shatty
              i cant view those images. can you post normal jpgs?
                It looks like it was printed too hot. So dial it back to 200 and see how it goes.
                shattyundefined 1 Reply Last reply Reply Quote 0
                • shattyundefined
                  shatty @Phaedrux
                  • shattyundefined
                    shatty
                    Not bad for a first print! LOL I was at 220. Where can I set my bed temps and extruder temps during printing? In the filament config.g?
                      Phaedrux Moderator @shatty
                      @shatty said in Newbie: New Install on Ender 5 Plus---Willing to PAY$$:
                      You set them in the slicer. Then during a print if you want to change them, you can use the web interface to entire a new temperature.
                      • shattyundefined
                        shatty @Phaedrux
                        @Phaedrux TY. During heat up if i were to set in the UI, it would always revert. I had to wait until pre-heat was done
                        • shattyundefined
                          shatty
                          Also, Im using Creality Slicer. What is a good nonbranded software? Like top-notch. And how do I earn 1 reputation? This 60 sec post thing is annoying
                            Give PrusaSlicer a try. Probably your best bet. You will have to do a bit of setup. I think it has a profile for the Ender 3 which should get you 99% of the way there.
                            • shattyundefined
                              shatty @Phaedrux
                              @Phaedrux I tried Ultimaker last night but it seemed too complicated
                              • Vetiundefined
                                Veti
                                prusaslicer is easier, it has far less options
                                • shattyundefined
                                  shatty
                                  IMG_2610.jpg IMG_2609.jpg IMG_2611.jpg IMG_2613.jpg IMG_2612.jpg IMG_2616.jpg IMG_2617.jpg IMG_2618.jpg
                                  • shattyundefined
                                    shatty
                                    What speed to print at? Fast (0.2mm), Normal (0.15mm), or HQ (0.1mm)?
                                    • Vetiundefined
                                      Veti
                                      yes print cooler.
                                      also post your config.g
                                      • Vetiundefined
                                        Veti @shatty
                                        Fast (0.2mm)
                                        i use this for most prints. and about 60mm/s on my ender 3.
                                        • shattyundefined
                                          shatty
                                          ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Nov 15 2020 03:22:47 GMT-0500 (Eastern Standard Time)
                                          M550 P"E5Plus" ; set printer name
                                          M551 P"xxxxx" ; set password
                                          M552 S1 ; enable network
                                          M586 P0 S1 ; enable HTTP
                                          M586 P1 S0 ; disable FTP
                                          M586 P2 S0 ; disable Telnet
                                          M569 P1 S0 ; physical drive 1 goes forwards
                                          M569 P2 S1 ; physical drive 2 goes backwards
                                          M92 X80.00 Y80.00 Z800.00 E130 ; set steps per mm
                                          M566 X1200.00 Y1200.00 Z60.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
                                          M203 X9000.00 Y9000.00 Z1200.00 E6000.00 ; set maximum speeds (mm/min)
                                          M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
                                          M906 X800 Y800 Z1400 E1000 I50 ; set motor currents (mA) and motor idle factor in per cent
                                          M84 S30 ; Set idle timeout
                                          M208 X350 Y350 Z400 S0 ; set axis maxima
                                          M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
                                          M558 P9 C"^zprobe.in" H5 F600 T6000 ; set Z probe type to bltouch and the dive height + speeds
                                          G31 P500 X16.3 Y14 Z2.43 ; set Z probe trigger value, offset and trigger height
                                          M557 X15:190 Y15:190 S20 ; define mesh grid
                                          M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
                                          M307 H0 A101.7 C607.1 D2.6 S1.00 V24.3 B0 ; enable bang-bang mode for the bed heater and set PWM limit
                                          M143 H0 S110 ; set temperature limit for heater 0 to 110C
                                          M308 S1 P"e0temp" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin e0temp
                                          M307 H1 A268.5 C102.1 D3.1 S1.00 V24.2 B0 ; disable bang-bang mode for heater and set PWM limit
                                          M143 H1 S280 ; 280 deg max on hot end
                                          M106 P0 S1 H1 ; set fan 0 value. Thermostatic control is turned off
                                          • Vetiundefined
                                            Veti @shatty
                                            @shatty
                                            is the thermistor the original thermistor of the ender 5?
                                            if yes change both M308 to T98801 B4185
