    Newbie: New Install on Ender 5 Plus---Willing to PAY$$$
    7.2k
    • shattyundefined
      shatty @Phaedrux
      This post is deleted!
      • shattyundefined
        shatty
        Not bad for a first print! LOL I was at 220. Where can I set my bed temps and extruder temps during printing? In the filament config.g?
          Phaedrux Moderator @shatty
          @shatty said in Newbie: New Install on Ender 5 Plus---Willing to PAY$$:
          You set them in the slicer. Then during a print if you want to change them, you can use the web interface to entire a new temperature.
          shattyundefined 1 Reply Last reply Reply Quote 0
          • shattyundefined
            shatty @Phaedrux
            @Phaedrux TY. During heat up if i were to set in the UI, it would always revert. I had to wait until pre-heat was done
            • shattyundefined
              shatty
              Also, Im using Creality Slicer. What is a good nonbranded software? Like top-notch. And how do I earn 1 reputation? This 60 sec post thing is annoying
                Give PrusaSlicer a try. Probably your best bet. You will have to do a bit of setup. I think it has a profile for the Ender 3 which should get you 99% of the way there.
                • shattyundefined
                  shatty @Phaedrux
                  @Phaedrux I tried Ultimaker last night but it seemed too complicated
                  • Vetiundefined
                    Veti
                    prusaslicer is easier, it has far less options
                    • shattyundefined
                      shatty
                      IMG_2610.jpg IMG_2609.jpg IMG_2611.jpg IMG_2613.jpg IMG_2612.jpg IMG_2616.jpg IMG_2617.jpg IMG_2618.jpg
                      • shattyundefined
                        shatty
                        What speed to print at? Fast (0.2mm), Normal (0.15mm), or HQ (0.1mm)?
                        • Vetiundefined
                          Veti
                          yes print cooler.
                          also post your config.g
                          • Vetiundefined
                            Veti @shatty
                            Fast (0.2mm)
                            i use this for most prints. and about 60mm/s on my ender 3.
                            • shattyundefined
                              shatty
                              ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Nov 15 2020 03:22:47 GMT-0500 (Eastern Standard Time)
                              M550 P"E5Plus" ; set printer name
                              M551 P"xxxxx" ; set password
                              M552 S1 ; enable network
                              M586 P0 S1 ; enable HTTP
                              M586 P1 S0 ; disable FTP
                              M586 P2 S0 ; disable Telnet
                              M569 P1 S0 ; physical drive 1 goes forwards
                              M569 P2 S1 ; physical drive 2 goes backwards
                              M92 X80.00 Y80.00 Z800.00 E130 ; set steps per mm
                              M566 X1200.00 Y1200.00 Z60.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
                              M203 X9000.00 Y9000.00 Z1200.00 E6000.00 ; set maximum speeds (mm/min)
                              M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
                              M906 X800 Y800 Z1400 E1000 I50 ; set motor currents (mA) and motor idle factor in per cent
                              M84 S30 ; Set idle timeout
                              M208 X350 Y350 Z400 S0 ; set axis maxima
                              M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
                              M558 P9 C"^zprobe.in" H5 F600 T6000 ; set Z probe type to bltouch and the dive height + speeds
                              G31 P500 X16.3 Y14 Z2.43 ; set Z probe trigger value, offset and trigger height
                              M557 X15:190 Y15:190 S20 ; define mesh grid
                              M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
                              M307 H0 A101.7 C607.1 D2.6 S1.00 V24.3 B0 ; enable bang-bang mode for the bed heater and set PWM limit
                              M143 H0 S110 ; set temperature limit for heater 0 to 110C
                              M308 S1 P"e0temp" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin e0temp
                              M307 H1 A268.5 C102.1 D3.1 S1.00 V24.2 B0 ; disable bang-bang mode for heater and set PWM limit
                              M143 H1 S280 ; 280 deg max on hot end
                              M106 P0 S1 H1 ; set fan 0 value. Thermostatic control is turned off
                              • Vetiundefined
                                Veti @shatty
                                @shatty
                                is the thermistor the original thermistor of the ender 5?
                                if yes change both M308 to T98801 B4185
                                • shattyundefined
                                  shatty @Veti
                                  @Veti yes.
                                  • shattyundefined
                                    shatty
                                    @Veti said in Newbie: New Install on Ender 5 Plus---Willing to PAY$$:
                                    T98801 B4185
                                    Do i have to auto tune again?
                                    • RyanPundefined
                                      RyanP @shatty
                                      @shatty
                                      I'm printing on my E5+ right now. Duet 2 Wifi, running perfectly. Send me your config G and I will look at it.
                                      CR10S, August 2018
                                      Anycubic Photon S December 2019
                                      Ender 5 Feb 2020
                                      Ender 5 Plus May 2020
                                      Anycubic Photon Mono X Nov 2020
                                      https://3dimensiongames.com/
                                      shattyundefined 1 Reply Last reply Reply Quote 1
                                      • shattyundefined
                                        shatty @RyanP
                                        @RyanP I posted above
                                        RyanPundefined 1 Reply Last reply Reply Quote 0
                                        • shattyundefined
                                          shatty
                                          Temps are good. I used my infrared thermo.
                                          • RyanPundefined
                                            RyanP @shatty
                                            @shatty
                                            Bear in mind you are running Firmware 3 where as I am not. But here is your gcode with the bolded sections changed. Feel free to try that.
                                            Configuration file for Duet WiFi (firmware version 3)
                                            M566 X600 Y600 Z60.00 E3000.00 ; set maximum instantaneous speed changes (mm/min)
                                            M201 X1500.00 Y1500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
                                            M204 P600 T1500 ;set print and travel accellerations
                                            M906 X800 Y800 Z800 E800 I50 ; set motor currents (mA) and motor idle factor in per cent
                                            M208 X0 Y0 Z***-1*** S1 ; set axis minima
                                            M558 P9 C"^zprobe.in" H5 F60 T6000 ; set Z probe type to bltouch and the dive height + speeds
                                            CR10S, August 2018
                                            Ender 5 Feb 2020
