How to make io on/off(m42 pn s255/0) by just one macros
428
    huai3895
    by c or c++,i just need as thus:
    if s=255
    s=0
    or
    s=255
    But idont know can gcode do that?
    I read GCode Meta Commands,still find no way。(https://duet3d.dozuki.com/Wiki/GCode_Meta_Commands#Section_Programming_constructs)
    huai
      oliof
      See https://forum.duet3d.com/topic/19799/toggle-gpio-with-external-trigger-on-off-on/4?_=1606417543586
      undefined 1 Reply Last reply 27 Nov 2020, 08:35 Reply Quote 0
        huai3895 @oliof
        @oliof I m just too noob,that i need to know how to write it concrete
        [I have use “OUT7” on duet3 6hc,M950 S2 C"OUT7"Q65535,And i try write this in macros :
        (If OUT7.pwm==0
        M42 P2 S1
        else
        M42 P2 S0)
        but it warn with:(Error: Failed to read code from macro Z-axis-brake: unexpected else in line 3)]
        THANKS
        huai
        undefined undefined 2 Replies Last reply 27 Nov 2020, 08:57 Reply Quote 0
          Donpi @huai3895
          @huai3895 can you post the code of your config.g where you create the pin ?
          undefined 1 Reply Last reply 27 Nov 2020, 11:15 Reply Quote 0
            huai3895 @Donpi
            @Donpi M950 P2 C"!OUT7" Q65535
            undefined 1 Reply Last reply 27 Nov 2020, 11:20 Reply Quote 0
              Donpi @huai3895
              @huai3895 if you type/send
              M42 P2 S1
              in the console does it works ?
              undefined 1 Reply Last reply 28 Nov 2020, 04:49 Reply Quote 0
                OwenD @huai3895
                @huai3895
                Remove the brackets (...)
                  huai3895 @Donpi
                  @Donpi yes ,it works
                  undefined 1 Reply Last reply 29 Nov 2020, 10:04 Reply Quote 1
                    Donpi @huai3895
                    @huai3895 ok so like @OwenD said, I think that the problem are the ( )
                    undefined 1 Reply Last reply 3 Dec 2020, 13:38 Reply Quote 0
                      huai3895 @Donpi
                      @Donpi the () just make easy to show you code,infact i never write it in my macros
                      undefined 1 Reply Last reply 3 Dec 2020, 13:42 Reply Quote 0
                        huai3895 @huai3895
                        @huai3895 But i still find something:with duet3&raspberry pi(duet pi with GUI) ,M409 just report nothing, so mabe its just a bug with duet pi?
                        4 out of 11
