    Inconsistent results with optical encoder wheel filament sensor
    Filament Monitor
    9
    168
    11.6k
    • JohnOCFIIundefined
      JohnOCFII @alankilian
      @alankilian said in Inconsistent results with optical encoder wheel filament sensor:
      I don't remember what your optical receiver circuit looks like, so you might need either a pull-up or a pull-down on the input to the Schmitt trigger inverter pin #1.
      Here are two photos of the optical sensor. Not sure it is clear enough to indicate presence or absence of the pull-up or pull-down resistors.IMG_2055.jpeg
      • alankilianundefined
        alankilian @JohnOCFII
        @JohnOCFII
        R1 is a 180 Ohm resistor in series with the emitter LED.
        R2 is a 2,200 Ohm resistor to pull UP the receiver signal line.
        The resistor on the top is a 1,000 Ohm resistor in series with the LED on top. Is that a power-on LED?
        So I would just hook it directly to the input of the Schmitt-inverter. No pull-resistors required on the input or the output of the inverter.
        JohnOCFIIundefined 1 Reply Last reply Reply Quote 0
          @JohnOCFII
          The LED is not a power-on LED -- it lights up when the light beam is broken. Interestingly, there is a corresponding e1stop LED on the Duet board as well.
          Thanks again on the advice. I'll try to wire this up tomorrow!
            @JohnOCFII AH! I tool another look at a larger zoom level and I do see that the LED is connected between positive voltage and the output signal.
              JohnOCFII
              @alankilian
              Progress!
              I manually moved the filament back and forth a few times, just to see if I was capture what I expected to capture. Other than the fact that the signal seems inverted -- it definitely looks like the Channel 1 signal is a cleaned up version of Channel 3.
              Spacing seems somewhat different too, but I can't imagine that matters in this case. I'll do a test print next.
              Here's the very tiny Saleae log file: https://1drv.ms/u/s!ApuOkxTDmZEzgoHeOopsvsFwqzJ2Eck?e=6bpojT
                JohnOCFII
                Yeah, maybe that inversion does matter. The LED on the optical sensor now is behaving opposite to the sensor on the DUET e1stop.
                Of course, I did buy a Schmitt trigger -inverter-...
                https://www.ti.com/lit/ds/symlink/cd40106b.pdf?HQS=TI-null-null-digikeymode-df-pf-null-wwe&ts=1606236503315
                  JohnOCFII
                  OK - test print complete. I inverted the endstop in my config:
                  M591 D0 P7 C"!^e1stop" S0 R30:1500 L04.0 E5 A1
                  Once again, this was just a slow vase mode test, but it looked pretty consistent. Now to do a more varied test print.
                  Pulse-type filament monitor on pin !e1stop, disabled, sensitivity 4.000mm/pulse, allowed movement 30% to 1500%, check every 5.0mm, measured sensitivity 4.048mm/pulse, measured minimum 92%, maximum 107% over 275.3mm
                  Here's the Saleae capture: https://1drv.ms/u/s!ApuOkxTDmZEzgoHgcZ3MG-VMfmaWuDk?e=LBB2Ue
                  John
                    JohnOCFII
                    A "normal" print with varying movement types and speeds up to 120 mm/sec. Results were pretty stable. Very similar to the vase mode print.
                    Pulse-type filament monitor on pin !e1stop, disabled, sensitivity 4.000mm/pulse, allowed movement 30% to 1500%, check every 5.0mm, measured sensitivity 4.016mm/pulse, measured minimum 91%, maximum 109% over 851.3mm
                    That's enough for today.
                    fractalengineerundefined arhiundefined 2 Replies Last reply Reply Quote 1
                    • fractalengineerundefined
                      fractalengineer @JohnOCFII
                      @JohnOCFII brilliant results that is a huge improvement
                      I actually have a C045 single inverter from my TBS Crossfire mod lol; might give it a shot
                      https://www.ti.com/lit/ds/symlink/sn74lvc1g04.pdf?ts=1606443533029&ref_url=https%253A%252F%252Fwww.google.com%252F
                      Railcore II ZL
                      JohnOCFIIundefined 2 Replies Last reply Reply Quote 1
                      • arhiundefined
                        arhi @JohnOCFII
                        @JohnOCFII said in Inconsistent results with optical encoder wheel filament sensor:
                        awesome 😄
                        so would be cool if @dc42 can implement sometimes in future Schottky input on the MCU for endstop inputs as it is supported from what I see in the datasheet.
                        JohnOCFIIundefined 1 Reply Last reply Reply Quote 1
                          JohnOCFII @fractalengineer
                          @fractalengineer
                          Thanks -- my next step is to re-test with the higher resolution encoder wheel. Right now I'm on the "middle" wheel.
                            @fractalengineer said in Inconsistent results with optical encoder wheel filament sensor:
                            Does that have the Schmitt trigger in it?
                            fractalengineerundefined 1 Reply Last reply Reply Quote 0
                              @JohnOCFII ah right, it doesn't.
                              I've found some in the same package though; might work on making a custom pcb with sensor and trigger included
                              https://lcsc.com/product-detail/74-Series_ON-Semiconductor-ON-M74VHC1G132DFT1G_C233567.html
                              Railcore II ZL
                                Cool idea! I was just thinking, "well, it looks like I've got a usable solution -- now how am I going to package up this mess..." 🙂
                                  JohnOCFII @arhi
                                  @arhi said in Inconsistent results with optical encoder wheel filament sensor:
                                  awesome 😄
                                  Yeah, it would be. And based on my testing so far, I wish I had known that the CONN_LCD input apparently does have the same input filter (or something) as the e0 and e1stop. I certainly got less wacky results once I switched from CONN_LCD to e1stop.
                                    Yes, it's inverted, but it makes ZERO difference since you are not using it as an endstop, but rather as a pulse for the filament monitor.
                                    If you care to have the lights be the same, just wire two of the inverters in series and it will invert twice and make it not-inverted anymore!
                                    Pin 1 input from sensor
                                    Pin 2 connect to pin 3
                                    Pin 4 connect to Duet.
                                      Oooh! I might try that. Thanks!
                                        The timing difference between the Saleae edge and the Schmitt trigger inverter edge is all caused by the difference in "threshold" voltages between the two and the VVVVEEEERRRRYYY SSSSLLLLOOOOOOOOWWWWLLLLYYY changing signal from your optical interruptor.
                                        The Saleae trace you posted shows the Schmitt trigger working PERFECTLY!!!
                                        You're only getting one transition for each fuzzy/mushy/multiple-edge-bouncing-ball transition you see in the optical-interrupter output Saleae signal.
                                          That is fantastic to hear!
                                          I went ahead and passed the signal through the adjacent inverter. I don't know why, but it makes me smile.
                                            JohnOCFII
                                            Another test before I swap encoder wheels. Very consistent results. This was a 3D Benchy.
                                            Pulse-type filament monitor on pin !e1stop, disabled, sensitivity 4.000mm/pulse, allowed movement 30% to 1500%, check every 5.0mm, measured sensitivity 4.034mm/pulse, measured minimum 91%, maximum 109% over 871.3mm
