    when will the new Z-height actually be saved?
    2.3k
    • holco62undefined
      holco62 @Phaedrux
      @Phaedrux said in when will the new Z-height actually be saved?:
      Post your Cura start gcode. That's where it would be defined.
      Technically you don't need to use start.g at all. You could do it all in Cura.
      M116; Wait
      G28 ; home printer
      G32 ; bed.g for leveling
      Or just use Start.g to preheat. Since it's a progression you can split it up however it makes sense. If you want you can even call a macro file in your slicer start gcode section.
      Sorry for quotting myself yesterday 😊 I was supposed to quote you in my penultimate post, but better late than never, you nailed it again so thank you 👍
      Anycubic Predator - Duet-2 wifi PanelDue - Smart effector
      • holco62undefined
        holco62
        G32 works well in Cura (Extruder Start Gcode), but with the start of a print when all temps have been reached the effector first slowly approaches the bed, just before the nozzle hits the bed, it's homing and then starts the G32 calibration and goes printing.
        Is there any way to skip that initial slowly going to the bed?
        I am also curious if other changes / settings are needed with regard to Cura 4.8 which I have now set as a standard Anycubic Predator, especially stringing (PLA) gives me a hard time to get it right with a Mosquito hotend.
        I shot a short video of it
        https://youtu.be/cFRNCrjWwww
          Everything it does at the start of the print is dictated by the slicer start gcode. Can you copy and paste the first 50 lines or so of a slicer gcode file? Also include your current homedelta, bed.g and config.g so we can see exactly what's going on and can tell you what needs to change.
          • holco62undefined
            holco62
            Cura doesn't let me copy the start G-code, so I took 2 pictures
            I'll post the rest in a moment
            • holco62undefined
              holco62
              homedelta (1).g bed (1).g config (1).g
                Phaedrux Moderator @holco62
                @holco62 said in when will the new Z-height actually be saved?:
                So I don't see G32 in your start gcode, but you say you have it in the Extruder start gcode section? Why there? What else do you have there?
                The reason for the double homing is that you have G28 at the beginning of your bed.g file.
                Can you post the first 50 lines of a sliced gcode file so I can see what the slicer is actually outputting?
                • holco62undefined
                  holco62
                  four_square_retrac.8mm.gcode
                  • holco62undefined
                    holco62
                    The G32 is in the Extruder Start G-code.
                      ;Generated with Cura_SteamEngine 4.8.0
                      T0
                      M190 S60
                      M104 S210
                      M109 S210
                      M82 ;absolute extrusion mode
                      G32
                      G21 ;metric values
                      G90 ;absolute positioning
                      M82 ;set extruder to absolute mode
                      M107 ;start with the fan off
                      G28 ;Home
                      G1 Z15.0 F1000;short move
                      G92 E0 ;zero the extruded length
                      G1 F200 E3 ;extrude 3mm of feed stock adjust so I don't have to remove any filament
                      G92 E0 ;zero the extruded length again
                      G1 F4000 ;move to bed
                      ;Put printing message on LCD screen
                      M117 Printing...
                      ;G5; this is in order to resume on Power failure (only works on SD prints)
                      M83 ;relative extrusion mode
                      G1 F3000 E-8
                      ;LAYER_COUNT:99
                      ;LAYER:0
                      M107
                      G0 F3600 X-20.499 Y-9.085 Z0.25
                      ;TYPE:SKIRT
                      G1 F3000 E8
                      G1 F1800 X-20.49 Y-9.761 E0.02459
                      G1 X-20.438 Y-10.692 E0.03392
                      G1 X-20.306 Y-11.615 E0.03392
                      I think you should remove the G32 from the Extruder start gcode. That's not a usual place to put it.
                      Also remove the G28 from bed.g. It's better to keep the commands separate so it's more clear about what is happening when.
                      Then change your start gcode in cura to be this
                      G21 ;metric values
                      G28 ;Home
                      G32 ; calibration
                      M117 Printing
                      • holco62undefined
                        holco62
                        Works perfectly now 👍 👍 👍
                        https://youtu.be/tdl2iDNiC9Q
                        What did the line "G1 Z15.0 F1000; short move" that has now been removed?
                        Btw, I think it's really remarkable that you can remember all those codes 👌
                          Nothing useful.
                          holco62undefined 1 Reply Last reply Reply Quote 0
                          • holco62undefined
                            holco62
                            Another question 😊
                            If the printer runs the G32 calibration, the nozzle leaves a little filament on each calibration spot, now I wondered if it is possible that after each print job, for example, 50mm retraction takes place so that the hotend is always free of filament, and that after the G32 calibration the 50mm (or more) is immediately re-fed.
                            • holco62undefined
                              holco62 @Phaedrux
                              Nothing useful.
                              Haha, oké
