    when will the new Z-height actually be saved?
    2.3k
      Everything it does at the start of the print is dictated by the slicer start gcode. Can you copy and paste the first 50 lines or so of a slicer gcode file? Also include your current homedelta, bed.g and config.g so we can see exactly what's going on and can tell you what needs to change.
      • holco62undefined
        holco62
        Cura doesn't let me copy the start G-code, so I took 2 pictures
        I'll post the rest in a moment
        Anycubic Predator - Duet-2 wifi PanelDue - Smart effector
        • holco62undefined
          holco62
          homedelta (1).g bed (1).g config (1).g
            Phaedrux Moderator @holco62
            @holco62 said in when will the new Z-height actually be saved?:
            (Extruder Start Gcode),
            So I don't see G32 in your start gcode, but you say you have it in the Extruder start gcode section? Why there? What else do you have there?
            The reason for the double homing is that you have G28 at the beginning of your bed.g file.
            Can you post the first 50 lines of a sliced gcode file so I can see what the slicer is actually outputting?
            • holco62undefined
              holco62
              four_square_retrac.8mm.gcode
              • holco62undefined
                holco62
                The G32 is in the Extruder Start G-code.
                  ;Generated with Cura_SteamEngine 4.8.0
                  T0
                  M190 S60
                  M104 S210
                  M109 S210
                  M82 ;absolute extrusion mode
                  G32
                  G21 ;metric values
                  G90 ;absolute positioning
                  M82 ;set extruder to absolute mode
                  M107 ;start with the fan off
                  G28 ;Home
                  G1 Z15.0 F1000;short move
                  G92 E0 ;zero the extruded length
                  G1 F200 E3 ;extrude 3mm of feed stock adjust so I don't have to remove any filament
                  G92 E0 ;zero the extruded length again
                  G1 F4000 ;move to bed
                  ;Put printing message on LCD screen
                  M117 Printing...
                  ;G5; this is in order to resume on Power failure (only works on SD prints)
                  M83 ;relative extrusion mode
                  G1 F3000 E-8
                  ;LAYER_COUNT:99
                  ;LAYER:0
                  M107
                  G0 F3600 X-20.499 Y-9.085 Z0.25
                  ;TYPE:SKIRT
                  G1 F3000 E8
                  G1 F1800 X-20.49 Y-9.761 E0.02459
                  G1 X-20.438 Y-10.692 E0.03392
                  G1 X-20.306 Y-11.615 E0.03392
                  I think you should remove the G32 from the Extruder start gcode. That's not a usual place to put it.
                  Also remove the G28 from bed.g. It's better to keep the commands separate so it's more clear about what is happening when.
                  Then change your start gcode in cura to be this
                  G21 ;metric values
                  G28 ;Home
                  G32 ; calibration
                  M117 Printing
                  • holco62undefined
                    holco62
                    Works perfectly now 👍 👍 👍
                    https://youtu.be/tdl2iDNiC9Q
                    What did the line "G1 Z15.0 F1000; short move" that has now been removed?
                    Btw, I think it's really remarkable that you can remember all those codes 👌
                      Nothing useful.
                      holco62undefined 1 Reply Last reply Reply Quote 0
                      • holco62undefined
                        holco62
                        Another question 😊
                        If the printer runs the G32 calibration, the nozzle leaves a little filament on each calibration spot, now I wondered if it is possible that after each print job, for example, 50mm retraction takes place so that the hotend is always free of filament, and that after the G32 calibration the 50mm (or more) is immediately re-fed.
                        • holco62undefined
                          holco62 @Phaedrux
                          @Phaedrux said in when will the new Z-height actually be saved?:
                          Nothing useful.
                          Haha, oké
