    ToolBoard: 2 wires fan, heater fault and how to extrude ?
    5.4k
    • Vetiundefined
      Veti @Pseud3mys
      @Pseud3mys said in ToolBoard: 2 wires fan, heater fault and how to extrude ?:
      I connected the 2 wires fan on OUT2 (3 pins) and when I start it nothing happen (I have tested all wiring possible).
      how did you configure it? post your config.g
      the "slice engineering high temps sensor" return -1.2°C at normal temperature (on Temp0). But It increase with temperature (always wrong but at least connected). Maybe because It for High temperature only.. I can test it for more than 40°C. But Who can have have the right temperature ?
      what values did you use to configure it?
      I have a header fault right after actived it, so I can heat the hotend. Maybe is liked with the wrong temperature ?
      did you pid tune the hotend?
      Who can we move the extruder motor ?? The command is unactived on the web interface. (without hotend on, just to test the motor and wiring)
      see
      https://duet3d.dozuki.com/Wiki/Gcode#Section_M302_Allow_cold_extrudes
      Pseud3mysundefined 2 Replies Last reply Reply Quote 0
      • Pseud3mysundefined
        Pseud3mys
        Here are the motor wiring:
        Motor - toolboard:
        Green - black
        Grey - white
        Yellow - red
        Red - yellow
        Is it the right way to wire it ?
        • Vetiundefined
          Veti
          impossible to tell from that.
          see
          https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Connecting_stepper_motors
          Pseud3mysundefined 1 Reply Last reply Reply Quote 0
            Pseud3mys @Veti
            @Veti I use the RRF config tool:
            [0_1606920783845_config.g](Uploading 100%)
            M308 S0 P"temp0" Y"thermistor" T100000 B4138        ; configure sensor 0 as thermistor on pin temp0
            M950 H0 C"out0" T0                                  ; create bed heater output on out0 and map it to sensor 0
            M307 H0 B1 S1.00                                    ; enable bang-bang mode for the bed heater and set PWM limit
            M140 H0                                             ; map heated bed to heater 0
            M143 H0 S120                                        ; set temperature limit for heater 0 to 120C
            M308 S1 P"121.temp0" Y"thermistor" T100000 B4138    ; configure sensor 1 as thermistor on pin 121.temp0
            M950 H1 C"121.out0" T1                              ; create nozzle heater output on 121.out0 and map it to sensor 1
            M307 H1 B0 S1.00                                    ; disable bang-bang mode for heater  and set PWM limit
            M143 H1 S280                                        ; set temperature limit for heater 1 to 280C
            M308 S2 P"122.temp0" Y"thermistor" T100000 B4138    ; configure sensor 2 as thermistor on pin 122.temp0
            M950 H2 C"122.out0" T2                              ; create nozzle heater output on 122.out0 and map it to sensor 2
            M307 H2 B0 S1.00                                    ; disable bang-bang mode for heater  and set PWM limit
            M143 H2 S280                                        ; set temperature limit for heater 2 to 280C
            M950 F0 C"121.out2" Q500                            ; create fan 0 on pin 121.out2 and set its frequency
            M106 P0 S0 H-1                                      ; set fan 0 value. Thermostatic control is turned off
            M950 F1 C"122.out2" Q500                            ; create fan 1 on pin 122.out2 and set its frequency
            M106 P1 S0 H-1                                      ; set fan 1 value. Thermostatic control is turned off
            • Vetiundefined
              Veti
              B4138 is wrong for that thermistor. look up the correct value in the thermistor documentation.
              or select it in the configtool. that seems to be the one that you use
                Pseud3mys @Veti
                @Veti said in ToolBoard: 2 wires fan, heater fault and how to extrude ?:
                see
                yes I already see the doc, I think it is right. I have just one doubt: can we invert B+ B- with A+ A- ?
                • Vetiundefined
                  Veti @Pseud3mys
                  invert B+ B-
                  do you mean switch the wires? yes. the motor will turn in the other direction
                  or do you mean invert the direction of the stepper motor?
                    Pseud3mys
                    I mean invert A+ with B- and B+ with A- ?
                    • Vetiundefined
                      Veti @Pseud3mys
                      @Pseud3mys
                      like turning the connector 180 degrees?
                      yes that inverts the motor direction
                        Pseud3mys
                        yes, okay thank.
                          Pseud3mys
                          R25 (kΩ): 500 ± 3%
                          β25/85 (K): 3800 ± 2%
                          I find this for the thermistor.
                          M308 S1 P"121.temp0" Y"thermistor" T500000 B3800
                          so I put this, the temp is 12°c when it must be ~19 I think. I have always the fault, do you now what I nead to change ?
                          Vetiundefined dc42undefined 2 Replies Last reply Reply Quote 0
                            Pseud3mys
                            I send M302 P1 to allow cold extrusion, and I test if the command went good:
                            "Cold extrusion is allowed (use M302 P0 to forbid it)"
                            but I still can't use it:Capture.PNG
                              Pseud3mys
                              I test the "extrudeur 2" here, see it heat 5°c and then it stop.
                              • Vetiundefined
                                Veti @Pseud3mys
                                R25 (kΩ): 500 ± 3%
                                in the online configurator
                                https://configtool.reprapfirmware.org/Heaters
                                click on the beta field and in the popup select slice high temperature.
                                  Pseud3mys @Veti
                                  I put this, directly from RRF config tool.
                                  • Vetiundefined
                                    Veti
                                    did you verify that the fans are working? by connecting them to the always on port on the duet 3 mainboard?
                                      Pseud3mys @Veti
                                      @Veti yes, On Vin and GND it work
                                      • Vetiundefined
                                        Veti @Pseud3mys
                                        @Pseud3mys
                                        change the S0 to S1 for testing
                                          Pseud3mys @Veti
                                          @Veti with S0 or S1 It work just when It is at 100% now. But not for all other value it don't work
                                          • Vetiundefined
                                            Veti @Pseud3mys
                                            @Pseud3mys
                                            some fans do not work with pwm.
