    G29 / 3 point bed compensation - always tilted slightly
    1.5k
    • Vetiundefined
      Veti
      that make zero sense.
      G28 Z should establish Z=0 using G30.
      G29 getting a different offset would mean that the trigger point is different.
        Phaedrux Moderator @Martin1454
        @Martin1454 said in G29 / 3 point bed compensation - always tilted slightly:
        G1 X30 Y80 F6000 ; G30 ;
        G1 X160 Y170 F6000 ; G30
        Your homeall and homez place the probe at different locations. Make them the same.
        Martin1454undefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
        • Martin1454undefined
          Martin1454 @Phaedrux
          @Phaedrux Hmm....
          That got me thinking - I Use the X30 Y80 because that places the probe not that far from my first lead screw and that saves time since it doesnt have to move when it starts the 3 point leveling - But! since it is not level when it does the first zeroring of Z, will placeing it off center, make the axis it rotates about not centered also? Or since its a plane, it doesnt matter?
          But I'll change it when I get home
          • sinned6915undefined
            sinned6915
            Are you certain that you dont have a dropped corner on one of your axis?
            Martin1454undefined 1 Reply Last reply Reply Quote 0
              A Former User
              You also need to remember there is a huge difference between a surface being level and it being flat...
              if it ispossible to use a digital inclinometer you can check the level, first zero the inclinometer to the surface the printer sits on (firstly on the X axis) then carry out 3 point leveling and check how level it is, then zero the inclinometer on the surface on the Y axis orientation and carry out the same 3 point leveling and see what it says. and you will have your answer, which i think might be that your bed it level but not completely flat.
              you can also check that your rails are level too.
                Martin1454 @sinned6915
                @sinned6915 said in G29 / 3 point bed compensation - always tilted slightly:
                Im pretty sure non of the corners is dropped - But even if one corner is lower, shouldent the whole system stay "parallel"?
                Im wondering if the M561 in my HomeZ.g have anything with the offset to do?
                sinned6915undefined 1 Reply Last reply Reply Quote 0
                  Martin1454 @A Former User
                  @CaLviNx I dont have one of those tools (yet) but the surface of the bed is a cast aluminium plate that is bought with a really flat surface, so Im suprised if its not flat. As I see it in the first picture, it looks like a flat planar that is just tilted, and not bend.
                  I'm gonna get the offset working again, and then I'll try to place a bit around with the Z-leadscrews placement and see the impact on the leveling.
                    Phaedrux Moderator @Phaedrux
                    @Phaedrux said in G29 / 3 point bed compensation - always tilted slightly:
                    Did this make any difference?
                      No not really
                      • Garfieldundefined
                        Garfield
                        Unless you spent a lot of money the tolerance for flatness and parallelism in cast aluminium tool plate can vary significantly, many suppliers don't list their tolerances other than the cut dimension. Even in cast plates with a milled finish some twist or unevenness can't be excluded, you also cannot assume that the two faces of the plate are parallel, it also isn't clear how you have mounted / constrained the plate, an over constrained plate can twist and bow as it expands when heated.
                        I don't understand your commands either - Z screws aren't calibrated with G28 ???
                        3 Axis Levelling
                        Either way a Z screw can only adjust if it is free to do so, if it is over constrained you will be over stressing the plate and probably twisting it to some degree depending on your mounting method - don't underestimate the strength of steppers with lead screws. If your mount to the bed is rigid there are limits to how much a z axis can help overcome errors, they may even introduce some.
                        You need to make sure it is as close to mechanically level as possible in relation to the X and Y axis before trying to take out any error with the Z screws. You then need to ensure that when you do calibrate Z using the steppers that you don't cause binding on the lead screws for one or more steppers.
                        Mark Rehorst Bed Mounting
                          sinned6915 @Martin1454
                          @Martin1454 said in
                          I don't believe so.
                          Level is the average of the 3 points that you are probing.
                          Flatness is what mesh bed leveling is trying to improve.
                          If your motion system is not parallel to the level plane, then nothing you can do to fix it. Imagine if you have sag in your gantry, you will have a hollow that the controller will try to fox by filling it in wich makes the problem worse.
                          Not knowing your machine or machanics, I am imagining rods with holders, try loosening and then retightneing the rod holders, or if you can, loosen and them shim them 'down' with a shim of known thickness just to see what the effect is. Even the thickness of a piece of paper will show you clear results.
