    G29 / 3 point bed compensation - always tilted slightly
    1.6k
    • Vetiundefined
      Veti
      post your config.g maybe you set your Dive height wrong
      Martin1454undefined 1 Reply Last reply Reply Quote 0
      • Martin1454undefined
        Martin1454 @Veti
        @Veti
        This is the complete config.g
        ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Oct 12 2020 17:14:31 GMT+0200 (Centraleuropæisk sommertid)
        G90                                          ; send absolute coordinates...
        M83                                          ; ...but relative extruder moves
        M550 P"Duet 3"                               ; set printer name
        M669 K1                                      ; select CoreXY mode
        M569 P0.1 S1                                 ; physical drive 0.1 goes forwards
        M569 P0.2 S1                                 ; physical drive 0.2 goes forwards
        M569 P0.3 S0                                 ; physical drive 0.3 goes forwards
        M569 P0.4 S0                                 ; physical drive 0.4 goes forwards
        M569 P0.5 S0                                 ; physical drive 0.5 goes forwards
        M569 P0.0 S0                                 ; physical drive 0.0 goes forwards
        M584 X0.2 Y0.1 Z0.4:0.3:0.5 E0.0             ; set drive mapping
        M350 X16 Y16 Z16 E16 I1                      ; configure microstepping with interpolation
        M92 X200 Y200 Z800.00 E415.00           	 ; set steps per mm
        M566 X1500.00 Y1500.00 Z12.00 E120.00        ; set maximum instantaneous speed changes (mm/min)
        M203 X8400.00 Y8400.00 Z4000.00 E1200.00      ; set maximum speeds (mm/min)
        M201 X800.00 Y500.00 Z200.00 E250.00          ; set accelerations (mm/s^2)
        M906 X1200 Y1200 Z800 E800 I40                 ; set motor currents (mA) and motor idle factor in per cent
        M84 S30                                      ; Set idle timeout
        M208 X0 Y0 Z0 S1                             ; set axis minima
        M208 X300 Y250 Z480 S0                       ; set axis maxima
        M574 X1 S3                                                          ; Set endstops controlled by motor load detection
        M574 Y1 S3                                                          ; Set endstops controlled by motor load detection
        M574 Z0 															; Set endstop Z to be probe
        M915 X Y H200 S1 R0 F0						 						; set X and Y to sensitivity , do nothing when stall, unfiltered
        M558 P9 C"^io7.in" H5 F100 T6000             ; set Z probe type to bltouch and the dive height + speeds
        M950 S0 C"io7.out"                           ; create servo pin 7 for BLTouch
        G31 P500 X30 Y70 Z1.48                          ; set Z probe trigger value, offset and trigger height
        M557 X40:300 Y80:195 S30                     ; define mesh grid
        ; Define the X and Y coordinates of the leadscrews.
        ; Must come after M584 (Set drive mapping), M667 (Select CoreXY Mode) and M669 (Choosing Kinematics type)
        ; Motor order: Front right (1), front left (2), rear center (3).
        ; Snn Maximum correction in mm to apply to each leadscrew (optional, default 1.0)
        M671 X-55:360:360.0 Y170:40:310 S20 P2
        M308 S0 P"temp2" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
        M950 H0 C"out0" T0                           ; create bed heater output on out0 and map it to sensor 0
        M140 H0                                      ; map heated bed to heater 0
        M143 H0 S120                                 ; set temperature limit for heater 0 to 120C
        M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp2
        M950 H1 C"out1" T1                           ; create nozzle heater output on out1 and map it to sensor 1
        M950 F1 C"out7" Q500 L127 C"Heat sink"             ; create fan 1 on pin out7 and set its frequency
        M106 P1 H1 T45                             ; set fan 1 value. Thermostatic control is turned on
        M950 F0 C"out4" Q500                         ; create fan 0 on pin out4 and set its frequency
        M106 P0 H-1 C"Part cooler"            ; set fan 0 value. Thermostatic control is turned off
        M563 P0 D0 H1 F0                             ; define tool 0
        G10 P0 X0 Y0 Z0                              ; set tool 0 axis offsets
        G10 P0 R0 S0                                 ; set initial tool 0 active and standby temperatures to 0C
        T0                                           ; select first tool
        M501;											Read config override
        • Vetiundefined
          Veti
          @Martin1454 said in G29 / 3 point bed compensation - always tilted slightly:
          thats not the command for Set endstop Z to be probe
          this is
          Your thermistor is configured incorrectly. Find the correct Beta value in your thermistor documentation.
          are these correct? what stepper motors do you have?
            Martin1454 @Veti
            @Veti said in G29 / 3 point bed compensation - always tilted slightly:
            this is
            The motors are all E3D high torque motors rated at 1.6A, except the extruder which is a small pancake stepper - current seems okay on it - Will look into the thermistors and change it from M574 Z0 to Z1 S2
            EDIT: I got the Z0 from the Gcode page
            "The S2 option of M574 is intended for use only when axes other than Z are using the Z probe for homing. The only printers known that do this using Duet electronics are the RepRapPro Ormerod, Huxley Duo, and Mendel Tricolour machines. When using the Z probe to home Z, M574 Z0 should be used."
            • Vetiundefined
              Veti
              so you are running your z steppers with not enought current
              set the current to 1200
                Martin1454 @Veti
                @Veti
                Increased the current to 1200 - still gets the large offset
                • Vetiundefined
                  Veti
                  that make zero sense.
                  G28 Z should establish Z=0 using G30.
                  G29 getting a different offset would mean that the trigger point is different.
                    Phaedrux Moderator @Martin1454
                    G1 X30 Y80 F6000 ; G30 ;
                    G1 X160 Y170 F6000 ; G30
                    Your homeall and homez place the probe at different locations. Make them the same.
                    Martin1454undefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                      Martin1454 @Phaedrux
                      @Phaedrux Hmm....
                      That got me thinking - I Use the X30 Y80 because that places the probe not that far from my first lead screw and that saves time since it doesnt have to move when it starts the 3 point leveling - But! since it is not level when it does the first zeroring of Z, will placeing it off center, make the axis it rotates about not centered also? Or since its a plane, it doesnt matter?
                      But I'll change it when I get home
                      • sinned6915undefined
                        sinned6915
                        Are you certain that you dont have a dropped corner on one of your axis?
                          A Former User
                          You also need to remember there is a huge difference between a surface being level and it being flat...
                          if it ispossible to use a digital inclinometer you can check the level, first zero the inclinometer to the surface the printer sits on (firstly on the X axis) then carry out 3 point leveling and check how level it is, then zero the inclinometer on the surface on the Y axis orientation and carry out the same 3 point leveling and see what it says. and you will have your answer, which i think might be that your bed it level but not completely flat.
                          you can also check that your rails are level too.
                            Martin1454 @sinned6915
                            @sinned6915 said in G29 / 3 point bed compensation - always tilted slightly:
                            Im pretty sure non of the corners is dropped - But even if one corner is lower, shouldent the whole system stay "parallel"?
                            Im wondering if the M561 in my HomeZ.g have anything with the offset to do?
                            sinned6915undefined 1 Reply Last reply Reply Quote 0
                              Martin1454 @A Former User
                              @CaLviNx I dont have one of those tools (yet) but the surface of the bed is a cast aluminium plate that is bought with a really flat surface, so Im suprised if its not flat. As I see it in the first picture, it looks like a flat planar that is just tilted, and not bend.
                              I'm gonna get the offset working again, and then I'll try to place a bit around with the Z-leadscrews placement and see the impact on the leveling.
                                Phaedrux Moderator @Phaedrux
                                @Phaedrux said in G29 / 3 point bed compensation - always tilted slightly:
                                Did this make any difference?
                                  No not really
                                  • Garfieldundefined
                                    Garfield
                                    Unless you spent a lot of money the tolerance for flatness and parallelism in cast aluminium tool plate can vary significantly, many suppliers don't list their tolerances other than the cut dimension. Even in cast plates with a milled finish some twist or unevenness can't be excluded, you also cannot assume that the two faces of the plate are parallel, it also isn't clear how you have mounted / constrained the plate, an over constrained plate can twist and bow as it expands when heated.
                                    I don't understand your commands either - Z screws aren't calibrated with G28 ???
                                    3 Axis Levelling
                                    Either way a Z screw can only adjust if it is free to do so, if it is over constrained you will be over stressing the plate and probably twisting it to some degree depending on your mounting method - don't underestimate the strength of steppers with lead screws. If your mount to the bed is rigid there are limits to how much a z axis can help overcome errors, they may even introduce some.
                                    You need to make sure it is as close to mechanically level as possible in relation to the X and Y axis before trying to take out any error with the Z screws. You then need to ensure that when you do calibrate Z using the steppers that you don't cause binding on the lead screws for one or more steppers.
                                    Mark Rehorst Bed Mounting
                                      sinned6915 @Martin1454
                                      @Martin1454 said in
                                      I don't believe so.
                                      Level is the average of the 3 points that you are probing.
                                      Flatness is what mesh bed leveling is trying to improve.
                                      If your motion system is not parallel to the level plane, then nothing you can do to fix it. Imagine if you have sag in your gantry, you will have a hollow that the controller will try to fox by filling it in wich makes the problem worse.
                                      Not knowing your machine or machanics, I am imagining rods with holders, try loosening and then retightneing the rod holders, or if you can, loosen and them shim them 'down' with a shim of known thickness just to see what the effect is. Even the thickness of a piece of paper will show you clear results.
