    Weird magnetic filament sensor values
    Filament Monitor
    filament sensor filament monitor magnetic filament monitor
    607
    • hbarundefined
      hbar
      I am getting weird values and not enough movement alerts from the magnetic filament sensor lately. I had been using it with some success until today. I was wondering if anyone had any ideas. I am running Duet 2 wifi with firmware version 3.1.1.
      M591 D0
      Duet3D rotating magnet filament monitor v3 on pin e0stop, disabled, sensitivity 24.55mm/rev, allow 20% to 140%, check every 45.0mm, version 3, mag 130 agc 120, measured sensitivity 15521.55mm/rev, min -33% max 476% over 1546.1mm
      Thanks in advance
      • alankilianundefined
        alankilian
        It might be a good idea to open it up and see if the magnet shaft is still able to rotate with low friction or if it's jammed somehow.
        • hbarundefined
          hbar
          When I opened it up there was some ground up filament in the sensor. I haven't done any long running prints but this looks to have been the problem. Thanks!
            alankilian
            YEAH!
            That's great to hear.
              dc42 administrators @hbar
              @hbar said in Weird magnetic filament sensor values:
              M591 D0
              Thanks in advance
              The "agc 120" value is very close to the upper limit, and suggests that either the washer magnet has weakened or it is not close enough to the sensor chip. The agc should normally be below 100.
              hbarundefined 1 Reply Last reply Reply Quote 0
                A Former User @alankilian
                @alankilian I am experiencing the same issue with theese values:
                M591 D0
                Duet3D rotating magnet filament monitor v3 on pin e0stop, enabled, sensitivity 24.75mm/rev, allow 65% to 130%, check every 3.0mm, version 3, mag 130 agc 98, measured sensitivity 24.83mm/rev, min 96% max 104% over 709.1mm
                I'm a little afraid to open the sensor...isn't it "dangerous" to open the case? Aren't there little screws of little springs who could jump out? Isn't there the chance to compromize some alingment? Thanks!
                  droftarts administrators @A Former User
                  @the_dragonlord @alankilian
                  See the troubleshooting section here: https://duet3d.dozuki.com/Wiki/Duet3dFilamentMonitor_RotatingMagnetVersion#Section_Errors_during_operation
                  See https://duet3d.dozuki.com/Wiki/Duet3dFilamentMonitor_RotatingMagnetVersion#Section_Assembly
                  There's a spring, but it's not that small. And you're actually trying to improve alignment!
                    A Former User @droftarts
                    @droftarts said in Weird magnetic filament sensor values:
                    ok, thanks
                    • BoAundefined
                      BoA
                      I will join this, as I bought second magnet filament monitor, and it barely works. Also I have:
                      Duet3D rotating magnet filament monitor v3 on pin io7.in, enabled, sensitivity 25.40mm/rev, allow 50% to 150%, check every 12.7mm, version 3, mag 126 agc 128, no calibration data
                      agc 128 I belive is the limit of this value. I tried to sand down an enclosure a little, but no luck.
                        alankilian
                        You can test by putting something nonconducting on the PCB and setting the magnet on top of the sensor IC to see if you can get the AGC down by putting the magnet closer.
                        Then, put some clay or something on the IC and assemble the unit.
                        Disassemble the unit and measure the thickness of the clay to see how far away from the sensor your magnet is when assembled.
                        Sand to adjust the clearance to match the thickness of the whatever-you-used in the first step.
                        • hbarundefined
                          hbar @dc42
                          @dc42 Thanks for pointing that bit out. I had missed that on the docs site. I filed it down some and it seems to be at a more acceptable range.
