    Distribution & Toolboard connection Problems
    1.6k
    • Frederikundefined
      Frederik
      @dc42 Thank you, Problem Solved.
      I rewired the distro and toolboard + making new crimps for my vin cables.
      i was measuring the 24v on the bottom of the connector and checked the polarity.
      But somehow the connection made no contact to the toolboard.when plugged in
      I also updated my duet3 to RRF 3.2beta4.1
      now the blue led is on and the red led is constantly on like the diag led on the duet 3, but not flashing. Is the firmware wrong?
      What is the next thing to check?
      Pressing the 2 buttons while starting the board doesn't change the led signals.
      Is there another way to reset the toolboard and check the CAN connection?
      Regards
        A Former User
        it might not matter, but the tool distribution board you showed is missing a bypass jumper on the 4th unused output and doesn't show the jumper for the 1st you're actually using.
        Frederikundefined 1 Reply Last reply Reply Quote 1
        • Frederikundefined
          Frederik @A Former User
          @bearer thanks for pointing that out. I uploaded the wrong photo. The jumpers are both removed from the first port with the cable and are set in every else slot.IMG_20201210_061343.jpg
          I test both ways. With only one of the two jumpers removed and both jumpers removed. The same result in the console and no change in led behavior.
          • Frederikundefined
            Frederik
            M122
            RepRapFirmware for Duet 3 MB6HC version 3.2-beta4 running on Duet 3 MB6HC v1.01 or later (SBC mode)
            Board ID: 08DJM-956BA-NA3TN-6J9DL-3S46S-99AUT
            Used output buffers: 1 of 40 (11 max)
            Static ram: 123212
            Dynamic ram: 138092 of which 24 recycled
            Never used RAM 130864, free system stack 200 words
            Tasks: Linux(ready,101) HEAT(blocked,298) CanReceiv(blocked,947) CanSender(blocked,371) CanClock(blocked,356) TMC(blocked,54) MAIN(running,1189) IDLE(ready,19)
            Owned mutexes: HTTP(MAIN)
            Last reset 00:01:10 ago, cause: power up
            Last software reset at 2020-12-10 01:00, reason: User, GCodes spinning, available RAM 130864, slot 2
            Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0xffffffff Task Linu
            Error status: 0x00
            MCU temperature: min 26.1, current 35.2, max 35.3
            Supply voltage: min 24.0, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
            12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
            Driver 0: position 0, standstill, reads 21528, writes 14 timeouts 0, SG min/max 0/0
            Driver 1: position 0, standstill, reads 21529, writes 14 timeouts 0, SG min/max 0/0
            Driver 2: position 0, standstill, reads 21530, writes 14 timeouts 0, SG min/max 0/0
            Driver 3: position 0, standstill, reads 21533, writes 11 timeouts 0, SG min/max 0/0
            Driver 4: position 0, standstill, reads 21534, writes 11 timeouts 0, SG min/max 0/0
            Driver 5: position 0, standstill, reads 21532, writes 14 timeouts 0, SG min/max 0/0
            Date/time: 2020-12-10 06:17:24
            Slowest loop: 0.90ms; fastest: 0.12ms
            === Storage ===
            Free file entries: 10
            === MainDDARing ===
            Scheduled moves 0, completed moves 0, StepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
            === AuxDDARing ===
            Segments left: 0
            Movement lock held by null
            Telnet is idle in state(s) 0
            File is idle in state(s) 0
            USB is idle in state(s) 0
            Aux is idle in state(s) 0
            Queue is idle in state(s) 0
            LCD is idle in state(s) 0
            SBC is idle in state(s) 0
            Daemon is idle in state(s) 0
            Aux2 is idle in state(s) 0
            Code queue is empty.
            === CAN ===
            Messages queued 158, send timeouts 510, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 47
            === SBC interface ===
            State: 0, failed transfers: 0
            Last transfer: 19ms ago
            RX/TX seq numbers: 1334/1335
            SPI underruns 0, overruns 0
            Number of disconnects: 0, IAP RAM available 0x20a28
            Buffer RX/TX: 0/0-0
            === Duet Control Server ===
            Duet Control Server v3.2.0-beta4
            Code buffer space: 4096
            Full transfers per second: 0.11
            • Frederikundefined
              Frederik
              M997 B121 S3
              Error: M997: Response timeout: CAN addr 121, req type 6024, RID=14
              everything I try only generates this timeouts. M115, M122, M997... Are there other parts to test with the multimeter to ensure that I got a working unit?
              • Vetiundefined
                Veti @Frederik
                @Frederik said in Distribution & Toolboard connection Problems:
                this would indicate that there is something wrong with your can wiring.
                Frederikundefined 1 Reply Last reply Reply Quote 0
                • Frederikundefined
                  Frederik @Veti
                  @Veti I use a straight through 4 pin can cable that I made with the lc1 connector pack
                  • Vetiundefined
                    Veti
                    have you done the simple setup and tested that?
                    https://d17kynu4zpq5hy.cloudfront.net/igi/duet3d/IgXsNbOKcEAWjeNO.huge
                    also check the continuity of your can wiring. a bad crimp here will also be a headache.
                    • Frederikundefined
                      Frederik @Veti
                      @Veti I would try if I'd had a 120ohm resistor and a spare rj11 cable at Hand. I can source a bunch of those resistors later at my local electro shop.
                      • Frederikundefined
                        Frederik
                        @Veti i checked for continuity with the multimeter. Seems to be OK
                        • Vetiundefined
                          Veti @Frederik
                          for the entire chain? with the distribution board?
                          • Frederikundefined
                            Frederik
                            Could a short to the stepper motor metal case cause the board to behave like that?
                            • Frederikundefined
                              Frederik @Veti
                              @Veti only the can cable.
                              Main - > distro is the original cable that comes with the distro board
                              • Vetiundefined
                                Veti @Frederik
                                @Frederik
                                please check the entire chain.
                                pull out the plug on the duet 3 and the 1lc and check the resistance for the L and H can cable with the toolboard beeing in place
                                  You can reset the tool board by powering up the system while holding both buttons on the tool board down.
                                  • Frederikundefined
                                    Frederik @Veti
                                    @Veti ~0.9ohm for a 2m long CAN cable. Measured on the back solder spots on the lc1 and the distro board. Consistent over all 4 pins
                                    • Frederikundefined
                                      Frederik @dc42
                                      @dc42 how long should I press the buttons? I tried holding perhaps 30 sec. But it don't do anything. Should there a message in the console?
                                      • Vetiundefined
                                        Veti @Frederik
                                        that is not what i asked
                                          dc42 administrators @Frederik
                                          You only need to hold the buttons down while you turn on the power. You can release them one second after the LEDs on the tool board indicate that it has power.
                                          • Frederikundefined
                                            Frederik @Veti
                                            @Veti sry, the probe tips of my fluke aren't small enough to reach the connectors. I have to look in my office if there is a smaller one. But I thought this value could get you in the right direction till I found a better way to probe the boards
                                            @dc42 thanks, good to know. Could it be that the firmware update from 3.1.1 to 3.2beta4.1 didn't get to the lc1?
                                            I have the 2 boards with me and a cc/cv lab powersupply at work. So I can do different tests if you like
