    RepRapFirmware 3.2beta4.1 now available
    Beta Firmware
    16
    34
    1.8k
    • KipKundefined
      KipK
      Got a problem updating to latest beta.
      After upgrade printer doesn't connect to wifi anymore.
      When doing M587 I get an error saying another SPI transfer is pending.
      Tryed rebooting but it's still stuck, any tip ?
      Thanks
      Edit: I solved it by manually flashing again the wifi module. Wondering what did happened
        dc42 administrators @KipK
        @KipK said in RepRapFirmware 3.2beta4.1 now available:
        Unfortunately the firmware upload protocol defined by the manufacturer of the wifi chip does not include error detection. It appears that flashing the wifi firmware occasionally appears to succeed but leaves the wifi module running corrupt firmware.
        • smoki3undefined
          smoki3
          After a bit of research I noticed that the filament assignment is handled by the firmware not by DWC.
          So this issue is related to the firmware right?
          https://forum.duet3d.com/topic/20307/duet2sbc-load-filament-not-working
          The duet2sbc doesn't load the filament assigment on start up.
          • BoAundefined
            BoA
            I am checking from time to time M122, and this one is particularly curious result (printing in progress):
            M122
            RepRapFirmware for Duet 3 MB6HC version 3.2-beta4.1 running on Duet 3 MB6HC v1.01 or later (standalone mode)
            Board ID: 08DJM-956L2-G43S8-6J1D6-3SJ6R-KA0YG
            Used output buffers: 1 of 40 (26 max)
            Static ram: 123292
            Dynamic ram: 170684 of which 112 recycled
            Never used RAM 98104, free system stack 116 words
            Tasks: NETWORK(ready,159) ETHERNET(blocked,103) HEAT(blocked,276) CanReceiv(blocked,947) CanSender(blocked,348) CanClock(blocked,349) TMC(blocked,18) MAIN(running,696) IDLE(ready,19)
            Owned mutexes:
            Last reset 03:24:13 ago, cause: software
            Last software reset time unknown, reason: User, GCodes spinning, available RAM 98312, slot 1
            Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0xffffffff Task MAIN
            Error status: 0x00
            MCU temperature: min 39.1, current 39.2, max 39.4
            Supply voltage: min 27.1, current 27.3, max 27.4, under voltage events: 0, over voltage events: 0, power good: yes
            12V rail voltage: min 12.1, current 12.2, max 12.2, under voltage events: 0
            Driver 0: position 19983, ok, reads 22817, writes 0 timeouts 0, SG min/max 0/1023
            Driver 1: position 28137, ok, reads 22817, writes 0 timeouts 0, SG min/max 0/1023
            Driver 2: position 14970, ok, reads 22817, writes 0 timeouts 0, SG min/max 0/168
            Driver 3: position 0, standstill, reads 22817, writes 0 timeouts 0, SG min/max not available
            Driver 4: position 0, standstill, reads 22817, writes 0 timeouts 0, SG min/max 0/0
            Driver 5: position 0, standstill, reads 22817, writes 0 timeouts 0, SG min/max 0/0
            Date/time: 2020-12-14 12:34:38
            Slowest loop: 5.90ms; fastest: 0.26ms
            === Storage ===
            Free file entries: 9
            SD card longest read time 2.4ms, write time 0.0ms, max retries 0
            FreeDm 354 (min 344), maxWait 0ms, bed compensation in use: mesh, comp offset 0.000
            === MainDDARing ===
            Scheduled moves 971089, completed moves 971030, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
            === AuxDDARing ===
            Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = 3 -1 -1 -1
            Heater 0 is on, I-accum = 0.4
            Heater 1 is on, I-accum = 0.4
            Segments left: 1
            Movement lock held by null
            HTTP is idle in state(s) 0
            Telnet is idle in state(s) 0
            File is doing "G1 X91.461 Y150.354 E0.04368" in state(s) 0
            USB is idle in state(s) 0
            Aux is idle in state(s) 0
            Trigger is idle in state(s) 0
            Queue is idle in state(s) 0
            LCD is idle in state(s) 0
            SBC is idle in state(s) 0
            Daemon is idle in state(s) 0
            Aux2 is idle in state(s) 0
            Code queue is not empty:
            Queued 'M106 S127.5�����������������������������������������������������' for move 971061
            Queued 'M106 S76.55�����������������������������������������������������
            ' for move 971063
            2 of 16 codes have been queued.
            === Network ===
            Slowest loop: 14.15ms; fastest: 0.03ms
            HTTP sessions: 1 of 8
            - Ethernet -
            State: active
            Error counts: 0 0 0 0 0
            Socket states: 5 2 2 2 2 2 0 0
            === Filament sensors ===
            Extruder 0: pos 190.90, errs: frame 1 parity 0 ovrun 0 pol 0 ovdue 0
            Extruder 1: pos 0.00, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
            === CAN ===
            Messages queued 20, send timeouts 44, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 47
              Thanks for that. The code to print the queued GCodes assumed that the commands were null-terminated, but they are not. Fixed in next beta/RC.
              BoAundefined 1 Reply Last reply Reply Quote 0
              • BoAundefined
                BoA @dc42
                @dc42 What about move number? They are not consecutive numbers. Is that OK? Was something executed Out-Of-Order ?
                  dc42 administrators @BoA
                  @BoA said in RepRapFirmware 3.2beta4.1 now available:
                  No. A "queued GCode" is one that needs to be delayed until a command that has been put in the movement queue is executed. Only a few command types are queued, for example heat, fan and GPIO commands. Most of the time there will be no commands in that queue. The movement command queue is separate.
                    jay_s_uk
                    @dc42 anything else I can do with this?
                      dc42 administrators @jay_s_uk
                      @jay_s_uk said in RepRapFirmware 3.2beta4.1 now available:
                      With what?
                        jay_s_uk
                        @dc42 sorry, wrong topic
                        • delta1undefined
                          delta1
                          Using Duet Wifi. Upgraded to 3.2-beta4.1. Bed heater disappeared.
                          Config heater info.
                          ; >>>>>>>>>>>>>>>>>> Heaters
                          ;Extruder
                          M143 S300 ; Set maximum heater temperature to 300C
                          M950 H1 C"e0_heat" T1 ;Extruder heater
                          M308 S1 P"spi.cs1" Y"rtd-max31865" R395 F50
                          ;Bed
                          M308 S0 P"bedtemp" Y"thermistor" A"Bed temp" T100000 B4725 C0 R2200 ;Set thermistor + ADC parameters for heater 0
                          M950 H0 C"bedheat" T0
                          M143 H0 S110 ;Bed heat max 110 deg C
                          M307 H1 A385.0 C163.1 D3.3 V23.9 B0; PID ran on 01/12/2020 Heater 1 model: gain 385.0, time constant 163.1, dead time 3.3, max PWM 1.00, calibration voltage 23.9
                          Did the port change?
                            I guess you upgraded from firmware 3.1. You now need to declare the bed heater explicitly using:
                            M140 H0
                            after creating heater 0 with M950.
                            • GTechundefined
                              GTech
                              Yesterday I tried to update to 3.2 Beta 4.1.
                              After the update DCS lost all communiucation to the board.
                              I flashed the board a 2nd time via USB to ensure that firmware was installed properly, which did not change anything.
                              In the end I was forced to roll back to the last stable release by flashing the firmware via USB.
                              root@GPDMk1:/opt/dsf# /opt/dsf/bin/DuetControlServer -l debug
                              Duet Control Server v3.2.0-beta4
                              Written by Christian Hammacher for Duet3D
                              Licensed under the terms of the GNU Public License Version 3
                              [info] Settings loaded
                              [info] Environment initialized
                              [fatal] Could not connect to Duet (Timeout while waiting for transfer ready pin)
                              [debug] System.OperationCanceledException: Timeout while waiting for transfer ready pin
                                 at DuetControlServer.SPI.DataTransfer.WaitForTransfer() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/SPI/DataTransfer.cs:line 1081
                                 at DuetControlServer.SPI.DataTransfer.ExchangeHeader() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/SPI/DataTransfer.cs:line 1122
                                 at DuetControlServer.SPI.DataTransfer.PerformFullTransfer(Boolean connecting) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/SPI/DataTransfer.cs:line 164
                                 at DuetControlServer.SPI.DataTransfer.Init() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/SPI/DataTransfer.cs:line 104
                                 at DuetControlServer.Program.Main(String[] args) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/Program.cs:line 113
                              My setup: Pi4, 4GB + Duet 3 6HC + Panel Duei7
                                The most likely explanation is that you didn't manage to install the correct version of RRF. After flashing via USB and rebooting, if DCS won't connect then you can send M115 from USB to check the RRF version number, and M122 to get a diagnostic report.
                                  Phaedrux Moderator @GTech
                                  @GTech It might also be worth getting a fresh Duet Pi image and redoing the Pi SD card and updating it from there, especially if you're using the same Duet Pi build that came on the card originally.
