    After Micro swiss DD upgrade,Extruder skips steps
    164
    12.7k
    • Vetiundefined
      Veti
      i dont see anything in the g code that would deactivate the mesh compensation.
      lui2004undefined 1 Reply Last reply Reply Quote 0
      • lui2004undefined
        lui2004 @Veti
        @Veti
        Strange Things 😁
        Can i post my config and homing files to check if its all ok ?
        • Vetiundefined
          Veti @lui2004
          @lui2004
          sure
          you could also execute each line one by one from the start g code and check after each line if mesh compensation is on.
          • lui2004undefined
            lui2004 @Veti
            @Veti
            ok thanks a lot 😉
            bed.g:
            ; bed.g
            ; generated by RepRapFirmware Configuration Tool v2 on Tue May 07 2019 23:06:50 GMT+0100 (British Summer Time)
            ;M561 ; clear any bed transform
            ;G29  ; probe the bed and enable compensation
            G28 ; home
            M401 ; deploy Z probe
            G30 P0 X45 Y24 Z-99999 ; hinten rechts
            G30 P1 X198.8 Y24 Z-99999 ; hinten links
            G30 P2 X198 Y194 Z-99999 ; vorne links
            G30 P3 X45 Y194 Z-99999 S4 ; vorne rechts and report adjustments needed
            M402 ; retract probe
            config-override.g:
            ; config-override.g file generated in response to M500 at 2020-12-14 19:28
            ; Heater model parameters
            M307 H0 A153.1 C665.9 D6.9 S1.00 V24.2 B0
            M307 H1 A384.5 C134.9 D2.9 S1.00 V24.3 B0
            ; Workplace coordinates
            G10 L2 P1 X0.00 Y0.00 Z0.00
            G10 L2 P2 X0.00 Y0.00 Z0.00
            G10 L2 P3 X0.00 Y0.00 Z0.00
            G10 L2 P4 X0.00 Y0.00 Z0.00
            G10 L2 P5 X0.00 Y0.00 Z0.00
            G10 L2 P6 X0.00 Y0.00 Z0.00
            G10 L2 P7 X0.00 Y0.00 Z0.00
            G10 L2 P8 X0.00 Y0.00 Z0.00
            G10 L2 P9 X0.00 Y0.00 Z0.00
            config.g:
            G90                                      ; Send absolute coordinates...
            M83                                      ; ...but relative extruder moves
            M550 P"Ender 5"                          ; Set machine name
            M552 S1                                  ; Enable network
            M586 P0 S1                               ; Enable HTTP
            M586 P1 S0                               ; Disable FTP
            M586 P2 S0                               ; Disable Telnet
            M569 P0 S1                               ; Physical drive 0 goes forwards
            M569 P1 S1                               ; Physical drive 1 goes forwards
            M569 P2 S0                               ; Physical drive 2 goes backwards
            M569 P3 S1                              ; Physical drive 3 goes forwards
            M584 X0 Y1 Z2 E3                               ; set drive mapping
            M350 X16 Y16 Z16 E16 I1							; configure microstepping with interpolation
            M92 X79.92 Y79.84 Z797.61 E277.89             ; set steps per mm
            M566 X900.00 Y900.00 Z60.00 E4000.00      ; Set maximum instantaneous speed changes (mm/min)
            M203 X30000.00 Y30000.00 Z600.00 E8000.00  ; Set maximum speeds (mm/min)
            M201 X500.00 Y500.00 Z200.00 E8000.00          ; set accelerations (mm/s^2)
            M906 X800 Y800 Z800 E1400 I30                   ; set motor currents (mA) and motor idle factor in per cent
            M84 S30                                  ; Set idle timeout
            M208 X0 Y0 Z0 S1                         ; Set axis minima
            M208 X235 Y235 Z300 S0                   ; Set axis maxima
            M574 X1 S1 P"xstop"                            ; configure active-high endstop for low end on X via pin xstop
            M574 Y1 S1 P"ystop"                            ; configure active-high endstop for low end on Y via pin ystop
            M574 Z1 S2 									   ; configure Z-probe endstop for low end on Z
            ;Filament Sensors
            M591 D0 P2 C"!e0_stop" S1   			   ;Extruder 1(0)
            M950 S0 C"exp.heater7"                         ; create servo pin 0 for BLTouch
            M558 P9 C"^zprobe.in" H5 F120 T6000           ; set Z probe type to bltouch and the dive height + speeds
            G31 P500 X41.2 Y4.5 Z2.786                  ; set Z probe trigger value, offset and trigger height
            ;M557 X41.2:221.2 Y4.5:219.5 S20                       ; define mesh grid
            M557 X41.2:219 Y15:195 S20
            M671 X28.8:198.8:198:28.8 Y24:24:194:194
            M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
            M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
            M307 H0 B0 S1.00                               ; disable bang-bang mode for the bed heater and set PWM limit
            M140 H0                                        ; map heated bed to heater 0
            M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
            M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8; configure sensor 1 as thermistor on pin e0temp
            M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
            M143 H1 S280 								   ; set temperature limit for heater 1 to 300C
            M307 H1 B0 S1.00
            M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
            M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
            M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
            M106 P1 S1 H1 T45                              ; set fan 1 value. Thermostatic control is turned on
            M563 P0 D0 H1                            ; Define tool 0 S3D
            G10 P0 X0 Y0 Z0                          ; Set tool 0 axis offsets
            G10 P0 R0 S0                             ; Set initial tool 0 active and standby temperatures to 0C
            M572 D0 S0.05 ; Pressure Advance
            M207 P0 S0.45 R0 F2100 T2100 Z0 ; Firmware Retraction
            M204 P500 T2000
            M501
            homeall.g:
            ; homeall.g
            ; called to home all axes
            ; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Jul 28 2020 08:52:12 GMT+0200 (Mitteleuropäische Sommerzeit)
            G91 ; relative mode
            G1 H2 Z4 F200 ; raise head 4mm
            G1 H1 X-240 Y-240 F3000 ; move up to 240mm in the -X and -Y directions until the homing switches are triggered
            G1 H2 X4 Y4 F600; move slowly 6mm in +X and +Y directions
            G1 H1 X-10 Y-10 ; move up to 10mm in the -X and -Y directions until the homing switches are triggered
            G90 ; back to absolute mode
            G1 X73 Y106 F2000 ; put head over the centre of the bed, or wherever you want to probe
            G30 ; lower head, stop when probe triggered and set Z to trigger height
            homex.g:
            ; homex.g
            ; called to home the X axis
            G91 ; relative mode
            G1 H2 Z4 F200 ; raise head to avoid dragging nozzle over the bed
            G1 H1 X-240 F3000 ; move up to 240mm in the +X direction, stopping if the homing switch is triggered
            G1 X-4 F600 ; move slowly 4mm in the -X direction
            G1 H1 X10 ; move slowly 10mm in the +X direction, stopping at the homing switch
            G1 H2 Z-4 F200 ; lower the head again
            homey.g:
            ; homey.g
            ; called to home the Y axis
            G91 ; relative mode
            G1 H1 Y-240 F3000 ; move up to 240mm in the -X direction, stopping if the homing switch is triggered
            G1 X4 F600 ; move slowly 4mm in the +X direction
            G1 H1 X-10 ; move slowly 10mm in the -X direction, stopping at the homing switch
            homez.g:
            ; homez.g
            ; called to home the Z axis
            ; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Jul 28 2020 08:52:37 GMT+0200 (Mitteleuropäische Sommerzeit)
            G91               ; relative positioning
            G1 H2 Z5 F6000    ; lift Z relative to current position
            G90               ; absolute positioning
            G1 X73 Y106 F6000 ; go to first probe point
            G30               ; home Z by probing the bed
            • Vetiundefined
              Veti
              remove M401 and M402 from Bed.g
              are you sure those measurements are correct and backlash did not play a part in it?
              • lui2004undefined
                lui2004 @Veti
                @Veti
                i have remove the M 401 and 402 from bed.g
                i dont think because after a restart and start printing it will use mesh.
                the rest of config is fine ?
                • Vetiundefined
                  Veti @lui2004
                  @lui2004
                  config otherwise looks fine.
                  as i said execture each step from the beginning of the g code file and see with M122 after each if mesh is enable, to see where it gets disabled.
                    Phaedrux Moderator @lui2004
                    @lui2004 said in After Micro swiss DD upgrade,Extruder skips steps:
                    It's a minor thing, but you should remove the H2 from that line in your homeall.
                    Were you perhaps printing an older gcode file that didn't have G29 S1 in it?
                    lui2004undefined 2 Replies Last reply Reply Quote 0
                    • lui2004undefined
                      lui2004 @Phaedrux
                      @Phaedrux
                      how does it look ? like this:
                      G1 X4 Y4 F600; move slowly 6mm in +X and +Y directions
                        Yes.
                        The H2 means to move without regard to endstop, which is fine for the Z axis because it hasn't been homed yet, but in the case of the X Y axis it should already be homed, so normal movement should work fine. If for some reason the homing move failed, the H2 would still allow the axis to move, which can make for a confusing error.
                        • lui2004undefined
                          lui2004 @Phaedrux
                          @Phaedrux said in After Micro swiss DD upgrade,Extruder skips steps:
                          after a restart it works all fine with mesh active
                          • lui2004undefined
                            lui2004
                            @Veti @Phaedrux
                            After your great work to help me to solve my problem,i think i have good print results,take a look.
                            Printed with Black PLA at 200°C and Bed 50°C
                            and here Bridge test and overhangs:
                            • Vetiundefined
                              Veti
                              yes that is a very good benchy
                                Great looking prints.
                                • lui2004undefined
                                  lui2004
                                  i will say THANK YOU to @Phaedrux @Veti for your patience with me to solve my problems 👍 👍
                                  i have learn a lot about 3D and RepRap👍
                                  i think the post can be mark as solved 😊
