    After Micro swiss DD upgrade,Extruder skips steps
    164
    12.7k
    • Vetiundefined
      Veti
      remove M401 and M402 from Bed.g
      M92 X79.92 Y79.84 Z797.61 E277.89 ; set steps per mm
      are you sure those measurements are correct and backlash did not play a part in it?
      lui2004undefined 1 Reply Last reply Reply Quote 0
      • lui2004undefined
        lui2004 @Veti
        @Veti
        i have remove the M 401 and 402 from bed.g
        i dont think because after a restart and start printing it will use mesh.
        the rest of config is fine ?
        • Vetiundefined
          Veti @lui2004
          @lui2004
          config otherwise looks fine.
          as i said execture each step from the beginning of the g code file and see with M122 after each if mesh is enable, to see where it gets disabled.
            Phaedrux Moderator @lui2004
            @lui2004 said in After Micro swiss DD upgrade,Extruder skips steps:
            G1 H2 X4 Y4 F600; move slowly 6mm in +X and +Y directions
            It's a minor thing, but you should remove the H2 from that line in your homeall.
            Were you perhaps printing an older gcode file that didn't have G29 S1 in it?
            lui2004undefined 2 Replies Last reply Reply Quote 0
            • lui2004undefined
              lui2004 @Phaedrux
              @Phaedrux
              how does it look ? like this:
              G1 X4 Y4 F600; move slowly 6mm in +X and +Y directions
                Yes.
                The H2 means to move without regard to endstop, which is fine for the Z axis because it hasn't been homed yet, but in the case of the X Y axis it should already be homed, so normal movement should work fine. If for some reason the homing move failed, the H2 would still allow the axis to move, which can make for a confusing error.
                • lui2004undefined
                  lui2004 @Phaedrux
                  @Phaedrux said in After Micro swiss DD upgrade,Extruder skips steps:
                  after a restart it works all fine with mesh active
                  • lui2004undefined
                    lui2004
                    @Veti @Phaedrux
                    After your great work to help me to solve my problem,i think i have good print results,take a look.
                    Printed with Black PLA at 200°C and Bed 50°C
                    and here Bridge test and overhangs:
                    • Vetiundefined
                      Veti
                      yes that is a very good benchy
                        Great looking prints.
                        • lui2004undefined
                          lui2004
                          i will say THANK YOU to @Phaedrux @Veti for your patience with me to solve my problems 👍 👍
                          i have learn a lot about 3D and RepRap👍
                          i think the post can be mark as solved 😊
