    Possible to change baby-steps increments?
    504
    • deonholtundefined
      deonholt
      Good day.
      Is it possible to change baby-steps increments? At the moment it is 0.05mm. Just wonder if 0.02mm is possible and how to do it.
      • PCRundefined
        PCR
        Look at the settings in the Webinterface
        deonholtundefined 1 Reply Last reply Reply Quote 0
        • deonholtundefined
          deonholt @PCR
          @PCR
          Thanks, but not possible to change. I can right-click or anything, doesn't seem possible. But I can be missing something.
          This is a screenshot I just took.
          • deonholtundefined
            deonholt
            I read this here:
            This allows for the Z axis to be lowered or raised by small steps - sometimes known as "Baby Stepping". The size of each baby step can be configured in the user interface setting covered later in this manual.
            But I cannot find anything about where to change the increments. 🤔
            https://duet3d.dozuki.com/Wiki/Duet_Web_Control_Manual#Section_G_Code_Console
            • Stephen6309undefined
              Stephen6309
              In Duet Web Control 3.2.0-beta4, it's under Machine-Specific.
              It's in the same place in prevoius versions, IIRC.
              • deonholtundefined
                deonholt @Stephen6309
                @Stephen6309
                Thank you very much.
                I now see I have 1.22.6 🙈
                I will find out how to update it. Is it relatively easy?
                Stephen6309undefined 1 Reply Last reply Reply Quote 0
                  Stephen6309 @deonholt
                  @deonholt Yes, but 3.2.0-beta4 DWC is for firmware version 3.2.0-beta4. It won't work with 1.xx and 2.xx firmwares.
                  • deonholtundefined
                    @Stephen6309
                    Thanks, I seriously need to update but am too afraid. Will have a friend helping me.
                      You can update your firmware and DWC to 2.05.1 without much trouble and the baby stepping adjustment should be present.
                      Just upload this zip file to the system tab in DWC and it should update everything for you.
                      deonholtundefined 1 Reply Last reply Reply Quote 1
                      • deonholtundefined
                        deonholt @Phaedrux
                        @Phaedrux
                        Update: I see now I do have 2.05.1
                        Thank you so much. I really appreciate it. To me fiddling with the firmware of the printer is like doing brain surgery and I have the fear that something big might go wrong. I will make a backup of current files first.
                        Thanks again.
                          Are you now able to set the baby stepping values in the DWC settings pages?
