    Z axis wont home
    3.4k
    • fcwiltundefined
      fcwilt
      Refresh my memory - what type of printer do you have? XY? Delta?
      • brianundefined
        brian
        cartesian
        • fcwiltundefined
          fcwilt
          @brian:
          cartesian
          What part moves in the Z axis - the hot end or the table?
          On such a printer what does the Z axis home to - the min or max value?
          • brianundefined
            brian
            @ CaLviNx
            Yes i have the ir probe connected and led flashes (4 times i think), on power up.
            Have changed the m574 as you directed.
            Uncommented the M558 lines.
            Ran the M119 with bed lowered it states z endstop at min, z probe at min. homez and homeall still the same that is they home the x and y but not the z axis. It seems to ignore the G30 command.
            I can still print as before by manually moving bed up to nozzle resetting z position to 0, lowering the bed then printing.
            Also the led for the z axis on the board does light up still when triggered and goes off as bed lowers.
            config file now;
            M111 S0 ; Debugging off
            G21 ; Work in millimetres
            G90 ; Send absolute coordinates…
            M555 P2 ; Set firmware compatibility to look like Marlin
            M208 X420 Y430 Z650 S0 ; Set axis maxima
            M574 Z0 S0 ; Define active low and unused microswitches -- changed Z1 to Z0 to indicate no endstop
            M574 X1 Y1 S1 ; Define active high microswitches
            M558 P1 X0 Y0 Z1 H3 F200 T5000 R0 ; smart IR Z probe, used for homing Z axis only, dive height 3mm, probe speed 200mm/min, travel speed 5000mm/min, no recovery time
            G31 P500 X11.0 Y0.5 Z1.0 ; set threshold and offsets
            M558 P1 X0 Y0 Z1 H5 F120 T6000 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds --uncommented june 25
            G31 P500 X0 Y0 Z0.1 ; Set Z probe trigger value, offset and trigger height --uncommented june 25
            M557 X25:175 Y25:175 S25 ; Define mesh grid
            • brianundefined
              brian
              I dont know, so will comment out one.
                deckingman
                @CaLviNx:
                I'm wondering if there is a need for two sets of M558 and G31 commands
                I'm fairly sure that in config.g, if there are repeated commands, the later one will override the earlier. Or more to the point, they get execute in order. No doubt David will step in if I'm wrong….
                • brianundefined
                  brian
                  Ok commenting out one line doesnt help.
                  Following DC42's guide, and after sending the G30 S-1 command, error message; insufficient axis homed for bed probing. BTW the probe reading is always fluctuating between 954 and 955.
                  • brianundefined
                    brian
                    Strange. If it were just the probe…but i cant homez when only using endstops either, so much something else.
                    • elmoretundefined
                      elmoret
                      If the probe is always reading in the 900s regardless of whether it is touching something, then either the probe is damaged or it is not wired properly. So regardless of .g files, probe homing will not work until the probe readings are correct.
                      Please post the config.g and homez.g files that you attempted to use with endstop homing.
                      Please also post the results from M119 in the following situations:
                      Z-endstop engaged
                      Z-endstop released
                      Z-probe activated (bed close enough to trigger it)
                      Z-probe released (bed far enough away to not trigger it)
                      • brianundefined
                        brian
                        Configuration file for Duet WiFi (firmware version 1.19 beta6) Wifi working, z endstop not working
                        ; generated by RepRapFirmware Configuration Tool on Tue Jun 20 2017 17:30:36 GMT-0700 (Pacific Daylight Time)
                        M574 Z0 S0 ; Define active low and unused microswitches no need for this so have changed Z1 to Z0 to indicate no endstop
                        ;M558 P1 X0 Y0 Z1 H5 F120 T6000 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
                        ; homez.g
                        ;wiki/Configuring_RepRapFirmware_for_a_Cartesian_printer#Homing_Z_using_a_Z_probe
                        G91 ; relative mode
                        G1 Z4 F200 ; raise head 4mm to ensure it is above the switch trigger height
                        G90 ; back to absolute mode
                        G1 X0 Y0 F2000 ; put head wherever you want it to be when you home Z (omit this line if it doesn't matter)
                        G91 ; relative mode
                        G1 Z-200 S1 F100 ; move Z down until the switch triggers
                        G92 Z0.3 ; tell the firmware that we are at Z=0.3mm
                        ;G91 ; relative mode
                        ;G1 Z4 F200 ; raise head 4mm to ensure it is above the Z probe trigger height
                        ;G90 ; back to absolute mode
                        ;G1 X100 Y100 F2000 ; put head over the centre of the bed, or wherever you want to probe
                        ;G30 ; lower head, stop when probe triggered and set Z to trigger height
                        Z-endstop engaged = @ min stop
                        Z-endstop released = @ min stop
                        Z-probe activated (bed close enough to trigger it) = @ min stop
                        Z-probe released (bed far enough away to not trigger it) = @ min stop
                          Does the red LED on the sensor light up when the sensor is triggered i.e. close to the bed, and stay off otherwise? If yes and you are getting those readings around 900 then that suggests a faulty connection between the sensor output pin and the Duet.
                          • elmoretundefined
                            elmoret
                            Just FYI David, I think he's using an Aus3D sensor.
                            • elmoretundefined
                              elmoret
                              Brian, you are not configuring properly for a Z-endstop:
                              That does not set up a Z-endstop in firmware. You'd need to get rid of the first line and change the second line to:
                              M574 X1 Y1 Z1 S1 ; Define active high microswitches
                              Assuming all three endstops are active high.
                              Please do that and re-run the M119 tests.
                              • brianundefined
                                brian
                                @dc42:
                                No it doesnt. It flashes twice on start up only.
                                  That's not right. If you have connected it correctly then it should flash 4 times at startup. Perhaps you have connected the sensor output wire to the MOD pin of the Z probe connector instead of to the IN pin?
                                  • brianundefined
                                    brian
                                    Z-endstop engaged = @ not stopped * this changed
                                    • brianundefined
                                      brian
                                      @dc42:
                                      I've connected sensor duetwifi
                                      power to 3.3v
                                      grnd to mod
                                      –-- grnd
                                      analogue probe in
                                      Looks like i've got Grnd on sensor going to Mod on duet.
                                      • elmoretundefined
                                        elmoret
                                        @brian:
                                        This is a step in the right direction, but it seems as though that switch is active low, not active high. I assumed all three endstop switches were the same but is seems that is not the case. Try changing this:
                                        to:
                                        M574 Z1 S0 ; Define active low microswitches
                                        That should set the firmware up to expect an active low microswitch on Z. The above code also assumes your endstop is at the Z-minimum, if it is at the Z-maximum then change to Z2 instead of Z1.
                                          Tim, thanks for that. Brian, you had better talk to aus3d if you are using their sensor. It's my sensor (also so!d by Duet3D and Filastruder) that should flash 4 times at startup when connected to a Duet.
                                          • brianundefined
                                            brian
                                            @dc42:
                                            I think i have found the error, as i've mount the duet upside down, and with small print its hard to see clearly. I'll check until i'm convinced i see it right.
