    Z axis wont home
    3.4k
      deckingman
      @CaLviNx:
      I'm wondering if there is a need for two sets of M558 and G31 commands
      I'm fairly sure that in config.g, if there are repeated commands, the later one will override the earlier. Or more to the point, they get execute in order. No doubt David will step in if I'm wrong….
      • brianundefined
        brian
        Ok commenting out one line doesnt help.
        Following DC42's guide, and after sending the G30 S-1 command, error message; insufficient axis homed for bed probing. BTW the probe reading is always fluctuating between 954 and 955.
        • brianundefined
          brian
          Strange. If it were just the probe…but i cant homez when only using endstops either, so much something else.
          • elmoretundefined
            elmoret
            If the probe is always reading in the 900s regardless of whether it is touching something, then either the probe is damaged or it is not wired properly. So regardless of .g files, probe homing will not work until the probe readings are correct.
            Please post the config.g and homez.g files that you attempted to use with endstop homing.
            Please also post the results from M119 in the following situations:
            Z-endstop engaged
            Z-endstop released
            Z-probe activated (bed close enough to trigger it)
            Z-probe released (bed far enough away to not trigger it)
            • brianundefined
              brian
              Configuration file for Duet WiFi (firmware version 1.19 beta6) Wifi working, z endstop not working
              ; generated by RepRapFirmware Configuration Tool on Tue Jun 20 2017 17:30:36 GMT-0700 (Pacific Daylight Time)
              M111 S0 ; Debugging off
              G21 ; Work in millimetres
              G90 ; Send absolute coordinates…
              M555 P2 ; Set firmware compatibility to look like Marlin
              M208 X420 Y430 Z650 S0 ; Set axis maxima
              M574 Z0 S0 ; Define active low and unused microswitches no need for this so have changed Z1 to Z0 to indicate no endstop
              M574 X1 Y1 S1 ; Define active high microswitches
              M558 P1 X0 Y0 Z1 H3 F200 T5000 R0 ; smart IR Z probe, used for homing Z axis only, dive height 3mm, probe speed 200mm/min, travel speed 5000mm/min, no recovery time
              G31 P500 X11.0 Y0.5 Z1.0 ; set threshold and offsets
              ;M558 P1 X0 Y0 Z1 H5 F120 T6000 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
              G31 P500 X0 Y0 Z0.1 ; Set Z probe trigger value, offset and trigger height
              M557 X25:175 Y25:175 S25 ; Define mesh grid
              ; homez.g
              ;wiki/Configuring_RepRapFirmware_for_a_Cartesian_printer#Homing_Z_using_a_Z_probe
              G91 ; relative mode
              G1 Z4 F200 ; raise head 4mm to ensure it is above the switch trigger height
              G90 ; back to absolute mode
              G1 X0 Y0 F2000 ; put head wherever you want it to be when you home Z (omit this line if it doesn't matter)
              G91 ; relative mode
              G1 Z-200 S1 F100 ; move Z down until the switch triggers
              G92 Z0.3 ; tell the firmware that we are at Z=0.3mm
              ;G91 ; relative mode
              ;G1 Z4 F200 ; raise head 4mm to ensure it is above the Z probe trigger height
              ;G90 ; back to absolute mode
              ;G1 X100 Y100 F2000 ; put head over the centre of the bed, or wherever you want to probe
              ;G30 ; lower head, stop when probe triggered and set Z to trigger height
              Z-endstop engaged = @ min stop
              Z-endstop released = @ min stop
              Z-probe activated (bed close enough to trigger it) = @ min stop
              Z-probe released (bed far enough away to not trigger it) = @ min stop
                Does the red LED on the sensor light up when the sensor is triggered i.e. close to the bed, and stay off otherwise? If yes and you are getting those readings around 900 then that suggests a faulty connection between the sensor output pin and the Duet.
                • elmoretundefined
                  elmoret
                  Just FYI David, I think he's using an Aus3D sensor.
                  • elmoretundefined
                    elmoret
                    Brian, you are not configuring properly for a Z-endstop:
                    That does not set up a Z-endstop in firmware. You'd need to get rid of the first line and change the second line to:
                    M574 X1 Y1 Z1 S1 ; Define active high microswitches
                    Assuming all three endstops are active high.
                    Please do that and re-run the M119 tests.
                    • brianundefined
                      brian
                      @dc42:
                      No it doesnt. It flashes twice on start up only.
                        That's not right. If you have connected it correctly then it should flash 4 times at startup. Perhaps you have connected the sensor output wire to the MOD pin of the Z probe connector instead of to the IN pin?
                        • brianundefined
                          brian
                          Z-endstop engaged = @ not stopped * this changed
                          • brianundefined
                            brian
                            @dc42:
                            I've connected sensor duetwifi
                            power to 3.3v
                            grnd to mod
                            –-- grnd
                            analogue probe in
                            Looks like i've got Grnd on sensor going to Mod on duet.
                            • elmoretundefined
                              elmoret
                              @brian:
                              This is a step in the right direction, but it seems as though that switch is active low, not active high. I assumed all three endstop switches were the same but is seems that is not the case. Try changing this:
                              to:
                              M574 Z1 S0 ; Define active low microswitches
                              That should set the firmware up to expect an active low microswitch on Z. The above code also assumes your endstop is at the Z-minimum, if it is at the Z-maximum then change to Z2 instead of Z1.
                                Tim, thanks for that. Brian, you had better talk to aus3d if you are using their sensor. It's my sensor (also so!d by Duet3D and Filastruder) that should flash 4 times at startup when connected to a Duet.
                                • brianundefined
                                  brian
                                  @dc42:
                                  I think i have found the error, as i've mount the duet upside down, and with small print its hard to see clearly. I'll check until i'm convinced i see it right.
                                  • brianundefined
                                    brian
                                    I changed the ground on the sensor to the next position on the duet .
                                    It still only flashes twice on start up, but when bed approches the sensor a red led lights up until bed is moved away.
                                    • brianundefined
                                      brian
                                      Now the home z only moves the bed down a bit, but the home all works!!!
                                      • brianundefined
                                        brian
                                        Finally got the z probe offset to work, it resisted a lot, but is good now.
                                        Just want to thank dc42, elmoret, and CaLviNx for getting me thru this.
                                        • fcwiltundefined
                                          fcwilt
                                          Just love a happy ending.
