    Duet2 WiFi Firmware on Raise 3d E2 ?
    Firmware installation
    10.9k
    • Proschi3Dundefined
      Proschi3D @Veti
      @Veti this was not a good idea.
      the printer does not start anymore
      Love my Duet 3 Mini.
      https://www.instagram.com/proschi3d
      https://youtube.com/@proschi3d
      https://www.proschi3d.de
        jay_s_uk
        This should get you back up and running
        https://drive.google.com/file/d/1X7L8mZ71x0eZNYgMeaI8VubTBc1Uk9uV/view?usp=sharing
        i have built it from the raise3d sources
        Proschi3Dundefined 1 Reply Last reply Reply Quote 0
          Proschi3D
          (>>) Error: M997: In-application programming binary "Duet2CombinedIAP.bin" not found<LF>ok<LF>Error: M997: In-application programming binary "Duet2CombinedIAP.bin" not found<LF>ok<LF>
            jay_s_uk
            What version are you trying to flash so we can point you at the right file
              Proschi3D
              @Proschi78 said in Duet2 WiFi Firmware on Raise 3d E2 ?:
              RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02(RTOS) running on Duet WiFi 1.02 o
                Proschi3D
                these data are on the original sd card
                  Proschi3D @jay_s_uk
                  @jay_s_uk do you think version 3.3 would work with the bin file you gave me?
                    jay_s_uk @Proschi3D
                    @Proschi78 that bin file is 2.02 built from the raise3d sources.
                    If you want to install RRF 3 you first have to go to 3.0 using the zip file from here https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
                      Proschi3D @jay_s_uk
                      @jay_s_uk 3.0 dont work on the printer
                      • Vetiundefined
                        Veti
                        you can still go klipper with mainsail
                        that will give you a good alternative.
                          Proschi3D @Veti
                          @Veti first I want to get the board running again
                          • Vetiundefined
                            Veti
                            have you tried these firmwares
                            https://www.raise3d.com/download/motion-controller-board-firmware-all-versions/
                              jay_s_uk @Proschi3D
                              @Proschi78 the iap from here should work https://github.com/Duet3D/RepRapFirmware/releases/download/2.03/iap4e.bin
                                Proschi3D @jay_s_uk
                                @jay_s_uk with 2.02 ?
                                  jay_s_uk
                                  @Proschi78 yes
                                  Proschi3Dundefined 2 Replies Last reply Reply Quote 0
                                    Proschi3D @jay_s_uk
                                    @jay_s_uk ok i will test it
                                      Proschi3D @jay_s_uk
                                        jay_s_uk
                                        you need to rename it to match the missing file
                                          Proschi3D @jay_s_uk
                                            jay_s_uk
                                            have you uploaded the file i sent you to the same place?
