    Preview version of CNC optimized DWC.
    CNC
    40
    191
    26.5k
    • cjmundefined
      cjm
      Regarding a larger panel for display of bigger coordinates, I’d definitely vote for that for CNC use. It’s a distinguishing feature of other popular CNC interfaces (Mach 3, Linux CNC etc) and I guess reflects the fact that CNCs are generally bigger than 3D printers so when setting up a job you are much further away from the control panel.
      My question about spindle speed was probably a bit off-topic as I was more thinking about monitoring and displaying the actual RPM of the spindle, rather than what it is set to.
      I do use M453 in my CNC config, but note that what is displayed as spindle RPM in DWC is just what the spindle has been commanded to run at, rather than what it is actually running at. This is not the same thing, particularly whilst the spindle ramps up/down in speed and if PWM/analogue control is used to set the speed.
      Many spindles have a spindle speed output giving one pulse per revolution, so in principle a Duet board could use one of the micro’s timers to measure the frequency of this signal and hence the actual RPM of the spindle.
      Why would that be useful? Well, it could be used to do things like ensuring the spindle is fully up to speed after an M3/M4, closing the loop around the spindle speed and enabling DWC to display the actual speed.
      This is analogous to measuring and then controlling and displaying the actual extruder/heated bed temperature in a 3D printer.
      Sindariusundefined 1 Reply Last reply Reply Quote 1
      • Sindariusundefined
        Sindarius @cjm
        @cjm I could see an argument for increasing the size of the tool position fonts and let me play around with that a little bit. But going across the room may need a significantly larger font depending on your distance.
        As far as getting spindle speed feedback I think that would be worth starting a separate topic since that is a much larger topic than the UI alone. I personally do not have a spindle just a simple DeWalt router on my CNC.
        cjmundefined 1 Reply Last reply Reply Quote 0
        • tntjetundefined
          tntjet
          Fantastic work ! love it and works as expected .
            Sindarius
            I could see something like this working for tool position. I don't know if I would go much larger than that though.
              A Former User @cjm
              @cjm
              Another option would be to get a big screen to connect to the raspi -> I read the new raspi supports quite big resolutions
              As long as people with small screens do not get discriminated their screensize I am O.K. with it 😉
                Sindarius
                If you're looking for extra large that you could read from further out I would really say a plugin so we don't impact people who have a computer next to thier machine. Something along this line.
                • mikedahlgrenundefined
                  mikedahlgren
                  I am extremely excited to have a CNC focused release as I have a large CNC router just waiting for a Duet upgrade.
                  Besides making the font larger, the biggest issue I see is how unclear the Duet "machine movement" section is and how easy it is to click on wrong speed. For example the "Jogging" section in this UI is both smaller and easier to use/intuitively understand.
                  Sindariusundefined 1 Reply Last reply Reply Quote 0
                    Sindarius @mikedahlgren
                    @mikedahlgren this is a jog control idea I have been playing with. It is in no way complete but gives an idea of an option.
                    weed2allundefined 1 Reply Last reply Reply Quote 2
                    • weed2allundefined
                      weed2all @Sindarius
                      @Sindarius it looks very good to me...!
                      https://www.thingiverse.com/weed2all/designs
                      • cjmundefined
                        cjm @Sindarius
                        @Sindarius I have a decent size screen hooked up to my pi but still struggle to read the tool position when setting up jobs, so the examples of larger fonts look really useful to me.
                        I’ve added spindle RPM to the Duet firmware wishlist to see what interest it garners.
                        • cjmundefined
                          cjm @Sindarius
                          @Sindarius All looks good to me too...
                            mikedahlgren
                            @Sindarius WOW! I didn't expect that kind of response, and I think that looks great! Really appreciate the work that you are doing.
                            • N7JTIundefined
                              N7JTI
                              I miss having the Macro's on the front screen. In particular I miss having quick access to "probe z" and "probe xyz". I use my touchplate a lot when setting up jobs. Having said that, overall it is a HUGE improvement over the 3d Printer centric view of the world. I've got a Duet2 on my 3DP and a Duet3 with SBC on my CNC. And I love the board. But working with my 3DP is just different than the CNC. So this is a huge help.
                                Sindarius @N7JTI
                                @N7JTI Macros make total sense. I’ll need to see where I can work them in.
                                  Sindarius @Sindarius
                                  Created a new release available here
                                  https://github.com/Duet3D/DWC-CNC/releases/tag/CNC02-(3.2.0-RC1)
                                  Made the movement buttons on the dashboard a little larger
                                  Added macro list to the dashboard
                                  Included DRO and Jog plugins for feedback.
                                  Plugins you want to try out will need to be turned on in Settings > General > Plugins Tab
                                  R4ffersundefined cjmundefined weed2allundefined 3 Replies Last reply Reply Quote 2
                                  • R4ffersundefined
                                    R4ffers @Sindarius
                                    @Sindarius, wow excellent
                                    Mb6hc + 3hc + 1lc on Voron V2.4, Mini 5+ exp 2+ on Vzbot 235 AWD, Duet 2 wifi on Ox CNC and Mini 5+ on Millennium Milo v1.5 mini mill.
                                    • cjmundefined
                                      cjm @Sindarius
                                      @Sindarius Really great update, thank you!
                                      • Shanian79undefined
                                        Shanian79
                                        This is great! Thank you! Will this CNC screen format work on a 7i Panel Due?
                                        • weed2allundefined
                                          weed2all @Sindarius
                                          @Sindarius neat!
                                            Sindarius @Shanian79
                                            @Shanian79 This is just on the DWC
