    Preview version of CNC optimized DWC.
    CNC
    40
    191
    22.8k
    • weed2allundefined
      weed2all @Sindarius
      @Sindarius it looks very good to me...!
      https://www.thingiverse.com/weed2all/designs
      • cjmundefined
        cjm @Sindarius
        @Sindarius I have a decent size screen hooked up to my pi but still struggle to read the tool position when setting up jobs, so the examples of larger fonts look really useful to me.
        I’ve added spindle RPM to the Duet firmware wishlist to see what interest it garners.
        • cjmundefined
          cjm @Sindarius
          @Sindarius All looks good to me too...
          • mikedahlgrenundefined
            mikedahlgren
            @Sindarius WOW! I didn't expect that kind of response, and I think that looks great! Really appreciate the work that you are doing.
            • N7JTIundefined
              N7JTI
              I miss having the Macro's on the front screen. In particular I miss having quick access to "probe z" and "probe xyz". I use my touchplate a lot when setting up jobs. Having said that, overall it is a HUGE improvement over the 3d Printer centric view of the world. I've got a Duet2 on my 3DP and a Duet3 with SBC on my CNC. And I love the board. But working with my 3DP is just different than the CNC. So this is a huge help.
              Sindariusundefined 1 Reply Last reply Reply Quote 0
              • Sindariusundefined
                Sindarius @N7JTI
                @N7JTI Macros make total sense. I’ll need to see where I can work them in.
                  Sindarius @Sindarius
                  Created a new release available here
                  https://github.com/Duet3D/DWC-CNC/releases/tag/CNC02-(3.2.0-RC1)
                  Made the movement buttons on the dashboard a little larger
                  Added macro list to the dashboard
                  Included DRO and Jog plugins for feedback.
                  Plugins you want to try out will need to be turned on in Settings > General > Plugins Tab
                  R4ffersundefined cjmundefined weed2allundefined 3 Replies Last reply Reply Quote 2
                  • R4ffersundefined
                    R4ffers @Sindarius
                    @Sindarius, wow excellent
                    Mb6hc + 3hc + 1lc on Voron V2.4, Mini 5+ exp 2+ on Vzbot 235 AWD, Duet 2 wifi on Ox CNC and Mini 5+ on Millennium Milo v1.5 mini mill.
                    • cjmundefined
                      cjm @Sindarius
                      @Sindarius Really great update, thank you!
                      • Shanian79undefined
                        Shanian79
                        This is great! Thank you! Will this CNC screen format work on a 7i Panel Due?
                        • weed2allundefined
                          weed2all @Sindarius
                          @Sindarius neat!
                            Sindarius @Shanian79
                            @Shanian79 This is just on the DWC
                            • tierodundefined
                              tierod
                              Very exciting !!! Perfect timing for me as I’m moving my duet2 from my old 3d printer to a new diy cnc!
                              Many,many thanks!
                              Rod
                                Sindarius
                                If any of you happen to be using my Gamepad Jogger plugin with the CNC build I have a new version which allows you to bind keyboard keys to commands as well.
                                https://github.com/Sindarius/DWC_GamepadJogger_Plugin/releases/tag/0.2.0
                                markzundefined 1 Reply Last reply Reply Quote 3
                                • whopping pochardundefined
                                  whopping pochard
                                  Ooh, nice! I've been itching to put together a CNC pendant design that could take advantage of this.
                                  • markzundefined
                                    markz @Sindarius
                                    @Sindarius These changes/plugins are just great.
                                    I've got a request for the Jog page plugin.
                                    Having home buttons imho makes little sense there. I maybe home once per day and in normal use if I hit home it's an at-best time-wasting mistake. Plus, I can already do it in the dashboard.
                                    Instead, I'd love it if we had a speed readout/control. Maybe it could have options like Travel, Feed, 20, 40, 60, 80 (mm/sec)?
                                    For the dashboard: I like to go to work 0,0 a lot, but rarely 0,0,0 - for whatever that's worth. My work Z=0 is usually the top of the workpiece, sometimes the top of the bed.
                                    Thanks again for all the work.
                                    Sindariusundefined 1 Reply Last reply Reply Quote 1
                                      Sindarius @markz
                                      @markz Appreciate the feedback!
                                      On the jog control plugin I can look at adding a "go to work 0" button. I'll look into adding travel speed as a set of buttons like the distance that is on there. I have a couple ideas I plan to play with on the jog control but was looking forward to some feedback and ideas.
                                      • tntjetundefined
                                        tntjet
                                        @Sindarius how do I install your plugin for keyboard control?
                                          Sindarius @tntjet
                                          @tntjet You can download the plugin from my GitHub page
                                          To install it take the zip file from the release and upload it using Files > System.
                                          Once the plugin is installed activate it by going to the "Machine Specific" page Plugins tab and start it.
                                          The latest version has the keyboard jogging setup.
                                          tntjetundefined 1 Reply Last reply Reply Quote 0
                                            A Former User @Sindarius
                                            @Sindarius said in Preview version of CNC optimized DWC.:
                                            -> ideas:
                                            Which protocol/standards are you planning to support -> USB and or D-Sub-9 ?
