    Where's the Duet Wifi 3?
    68
    4.1k
    • Vetiundefined
      Veti @BDubs
      @BDubs said in Where's the Duet Wifi 3?:
      Faster processor speed (300Mhz vs 120MHz)
      thats where the pi comes in, give you even faster speed and wifi
      BDubsundefined 1 Reply Last reply Reply Quote 0
      • BDubsundefined
        BDubs
        Yeah...'high end' is fine with me. I want the flagship model and don't mind paying for it.
        I guess my point is, take any device/appliance that has/had wifi, then 'upgrade' it with better components, like the processor, drivers and IO, but then arbitrarily remove the wifi from it?...I don't get it.
        I mean, why would I want to buy another Wifi 2 (which is 5yrs old now) ? No doubt, it's still a great piece of hardware...but I'd prefer the latest and greatest in Wifi form.
        Imagine if they came out with a laptop that didn't support wifi - RJ45 only...BUT if you plug in a RPi to it, you can get wifi again. Right?
        I'm disappointed nobody chimed in on the first post or two saying something to the effect of, "Oh yeah, the Wifi 3 is coming 2nd Q 21 - It's gonna be great!" But alas...no. 'Budget" aka 'Diet coke' mini 5 or Duet 3 with RPi are the choices.
        As a customer I'm thinking to myself, "Wow this Wifi 2 is great! ~ I can hardly wait to buy a Wifi 3!" But it's not the same thing...there's not even a provision on the Duet 3 for a NRF24L01 Wireless Module to plug in ... It just seems awfully backwards to me.
        elmoretundefined 1 Reply Last reply Reply Quote 1
        • BDubsundefined
          BDubs @Veti
          @Veti said in Where's the Duet Wifi 3?:
          I get the wifi part. What 'speed' are you referring to exactly? The speed of what is better because of the RPi?
          • Vetiundefined
            Veti @BDubs
            the pi 4 has a 4x 1,8 ghz processor. it handles data transfer and processing in sbc mode
            BDubsundefined A Former User? 2 Replies Last reply Reply Quote 0
            • BDubsundefined
              BDubs @Veti
              I don't know what SBC is in this context.
              So far, data transfer via Duet 2 has not been a problem/slow for me. My understanding is the entire GCode file is transferred in its entirety to the SD card before any motion takes place. The onboard processor then parses out chunks of the code and loads it into the buffer and does all its look-ahead calculations - on the Duet. There is (or rather there should not be) any GCode commands flying through the air via wifi during the print, aside from feedback updating the console or changes you've made on screen, such as baby stepping or adjusting fans etc. - which are handled/calculated on the Duet board and not your PC/phone et al. The Duet simply transforms the existing file and settings...
              So...the RPi can have a gajillion Ghz processor on it and it won't make the Duet processor run any faster. File transfer may be faster due to newer wireless hardware on the RPi, but aside from this, I don't think anyone will see a huge difference vs the Wifi 2 or what could have been the Wifi 3. You still have to go through your router...
              Stephen6309undefined Vetiundefined 2 Replies Last reply Reply Quote 0
              • Stephen6309undefined
                Stephen6309 @BDubs
                @BDubs The PI4 can use the 5ghz wifi, and it's faster than the 2.4ghz wifi that the Duet 2 uses.
                • Vetiundefined
                  Veti @BDubs
                  @BDubs
                  sbc stands for single board computer. the pi in this case
                  the onboard sd card slot is not used in sbc mode. the pi acts as a virtual sd card slot.
                  the calculation for the movement actually happen on the pi in this case and not the duet processor.
                  think of it like klipper.
                  • elmoretundefined
                    elmoret
                    Embedded options for wifi (ESP chips) are really not great. The Pi's wifi is considerably better.
                    What is the difference between buying a Duet 3 6HC + Raspberry Pi and the board you propose? I'm not sure I see the issue here, and the Raspberry Pi offers a whole lot more functionality than just wifi.
                    • elmoretundefined
                      elmoret @BDubs
                      NRF24s are not wifi devices, for starters.
                      • BDubsundefined
                        BDubs
                        I used the NRF24 as an example...not getting caught up in the technical minutia - I don't think it's outside the realm of reasonable expectation to desire a Duet Wifi 3. Why doesn't the Duet 3 use similar wifi hardware as the RPi? (I say this redundantly...with partial wishful thinking)
                        OK...well I guess the only way is to use a RPi then. Why my reluctance to it? Because it took me like 2 days just to cobble together a PiHole and sudo this and that isn't 2nd nature...there are so many things with Linux where it is assumed you know (or should know) something and you have to go half way around the world to figure out what that is exactly. Granted, many things are just download and install - but it's another layer of expertise you need over the Wifi 2. My time for learning is short and prone to frequent interruption...
                        I guess I'll have to bite the bullet...albeit reluctantly. Thanks for the replies.
                        elmoretundefined 1 Reply Last reply Reply Quote 0
                          The reason for the Pi is that it opens up a lot of additional functionality like large touch screen displays, wifi connectivity, post processing, plugins, etc.
                          There is a premade image for the Pi that comes loaded with everything required. So if you managed a PiHole this is a walk in the park.
                          Your request for a wifi version of the Duet 3 is noted.
                          • oliofundefined
                            oliof
                            I found using a little travel access point like the GL.inet AR-300 brings wifi to the ethernet only devices (like the duet 0.6 board on the Ormerod i am still working on ... although that's currently running a duet3 mini), with very little hassle.
                            • elmoretundefined
                              elmoret @BDubs
                              Lots of reasons.
                              • The parts used by the Raspberry Pi are not used in an off-the-shelf module, so it would require doing some pretty complicated RF design
                              • Using off the shelf/already certified modules like the ESP or Raspberry Pi simplifies regulatory requirements (you can't just design your own radio transmitter/receiver and sell it)
                              I'm not sure I understand the difference between a "NRF24 style" module/board and a RPi, why the former is acceptable and the latter isn't. SD card images already exist for a RaspberryPi/Duet3 setup.
                              Or, as has been suggested in this thread, you can just use a ethernet to wifi bridge. ~$20, and no "sudo-ing".
                              • hackinistratorundefined
                                hackinistrator
                                i also hate rpi and other types of toy computers .
                                if the board is meant for the industry or professionals - they dont use those toy computers also.
                                i read duet 3 documentation and it seems it can run in stand alone mode ,connected via Ethernet port .
                                so its like duet 2 ethernet i guess.
                                i dont think the rpi is doing any movement calculaions or anything related . rpi is used for UI and plug-ins only.
                                Phaedruxundefined A Former User? 2 Replies Last reply Reply Quote -1
                                  Phaedrux Moderator @hackinistrator
                                  @hackinistrator correct. An the Pi isn't the only SBC you can use. And you can use it standalone like an ethernet, and if you want to add wifi there are wifi to ethernet bridge adapters you can get that work well. And if they fail you don't have to desolder a component to replace it. Plus the adapter is likely to support 5ghz networks or whatever future wifi standard that comes along. It's alot easier to change along the way. Ethernet is a good solid default connection. There are options all around.
                                    A Former User @hackinistrator
                                    @hackinistrator said in Where's the Duet Wifi 3?:
                                    pretty sure i just watched a Jeff Gerling video showing statistics from Raspberry Pi Trading that almost half of the 35 million Pi's sold, were sold to industry clients.
                                    but this does seem to be the thread for venting so maybe i should take my facts elsewhere.
                                    BDubsundefined fcwiltundefined 2 Replies Last reply Reply Quote 6
                                    • BDubsundefined
                                      BDubs
                                      Wifi options duly noted...
                                      I think rj45 to wifi is a cludge...not quite as elegant as the wifi2 arrangement. I picture a beautifully well thought out control box, and then there's this 'thing' that doesn't belong you have to do something with.
                                      5GHz isn't the end all be all over 2.4 - for instance, 5Ghz might be faster if you are close to the access point, but 2.4 has a much longer range.
                                      Question: is the Beaglebone green or black compatible with the Duet 3?
                                        A Former User @BDubs
                                        This post is deleted!
                                        • BDubsundefined
                                          BDubs @A Former User
                                          @bearer said in Where's the Duet Wifi 3?:
                                          I'll take the brunt of the complaining comment. I only bought several Duets and peripherals so as a paying customer not 100% satisfied with the upgrade path, I'm entitled to my opinion. God forbid anyone should think differently from the herd. Seems to be a theme in 2020... just go along with the herd... hey NOPE!
                                          Please list the number of commercial or industrial motion controllers that use raspberry pi computers on them. Sorry to burst anyone's bubble but a Smoothieboard is not commercial and not anywhere near industrial.
                                          • fcwiltundefined
                                            fcwilt @A Former User
                                            @bearer
                                            Indeed those small SBCs, like the PI are far from "toys" and are widely used in many fields.
                                            My car has over 100 very small computers with far less capability than a PI.
                                            BDubsundefined 1 Reply Last reply Reply Quote 1
