    RRF3.2Beta4.1 Heightmap vs. Spindle/Driver Mapping
    2.5k
    • 3dMLundefined
      3dML
      @Frederik said in RRF3.2Beta4.1 Heightmap vs. Spindle/Driver Mapping:
      @3dML when my printhead is homed at x0 y0 (left front corner) the bltouch is around x-3 y-2
      the nozzle x35 y8
      Post the files you use for homing. The DWC tool position should report the exact position of the nozzle.
      • 3dMLundefined
        3dML
        @Phaedrux said in RRF3.2Beta4.1 Heightmap vs. Spindle/Driver Mapping:
        M671 defines the position of the lead screws
        The order must match the order of the motors defined in M584
        In bed.g you probe as close to the lead screws as you can in the same order as the lead screws are defined.
        Have you verified these settings are correct and the motors are positioned in the same order in the M671 as in the M584?
        • Frederikundefined
          Frederik
          @3dML
          I added your if loop to a makro. Works almost perfekt.
          Would it be possible that the measured values are displayed as message or in the console after each move? I stopped the makro after around 10min without knowing if the values are decreasing or what's happening 🙂
          I checked the limits bevor and it's running.
          I also tested several mesh sizes, the resulting height maps are above.
          I think, these values are reasonable to some point, I sliced a X from center of the bed 350mm to the 4 corners with a 50x50 rectangular pattern 150mm from the center.
          I increased the z trigger height to 1.81mm for safety and started a really slow test pattern. Today after Work I will verify it with a good old magnetic base + digital indicator on different spots along the gantry + x and y along he bed corners. Perhaps I can shim it, modifie the mounts or something else
          • Frederikundefined
            Frederik @Phaedrux
            @Phaedrux
            @3dML
            left spindle is connected to 0.2
            back center to 0.3
            front right to 0.4
            the wiring from the specified drivers to the spindles is correct
            i map the Z steppers: Z02:03:04 - that should be ok
            my homeall.g
            ; homeall.g
            ; called to home all axes
            ; generated by RepRapFirmware Configuration Tool v3.1.10 on Sat Dec 19 2020 21:32:05 GMT+0100 (Mitteleuropäische Normalzeit)
            G1 H2 Z5 F6000          ; lift Z relative to current position
            G1 H1 X-425 Y-405 F6000 ; move quickly to X or Y endstop and stop there (first pass)
            G1 H1 X-405             ; home X axis
            G1 H1 Y-405             ; home Y axis
            G1 X5 Y5 F6000          ; go back a few mm
            G1 H1 X-425 F360        ; move slowly to X axis endstop once more (second pass)
            G1 H1 Y-405             ; then move slowly to Y axis endstop
            G90                     ; absolute positioning
            G1 X215 Y210 F6000      ; go to first bed probe point and home Z
            G30                     ; home Z by probing the bed
            homex.g
            ; homex.g
            ; called to home the X axis
            G1 H1 X-425 F6000 ; move quickly to X axis endstop and stop there (first pass)
            G1 X5 F6000       ; go back a few mm
            G1 H2 Z-5 F6000   ; lower Z again
            homey.g
            ; homey.g
            ; called to home the Y axis
            G1 H1 Y-425 F6000 ; move quickly to Y axis endstop and stop there (first pass)
            G1 Y5 F6000       ; go back a few mm
            G1 H1 Y-425 F360  ; move slowly to Y axis endstop once more (second pass)
            G1 H2 Z-5 F1000   ; lower Z again
            homez.g:
            ; homez.g
            ; called to home the Z axis
            G1 H2 Z5 F1000     ; lift Z relative to current position
            G1 X215 Y210 F6000 ; go to first probe point
              Can you show an image marked up with where the motors driven by the 02,03,04 drivers are positioned?
              • 3dMLundefined
                3dML
                @Frederik
                Add an M291 between the M409 and the if statement. I have updated the macro below with this
                M291 P{move.calibration.initial.deviation} S3
                Based upon these values
                M208 X0 Y0 Z0 S1                 ; set axis minima
                M208 X415 Y395 Z400 S0           ; set axis maxima
                G10 P0 X0 Y0 Z0                  ; set tool 0 axis offsets
                the nozzle should be considered at x0 y0 and the BLTouch at x-38 y-10 in the comment below.
                the nozzle x35 y8
                This
                G31 P1000 X0 Y0 Z0.81                                              ; BLTouch offset
                should be updated to this
                G31 P1000 X-38 Y-10 Z0.81                                              ; BLTouch offset
                For M671 move the tool head to the position indicated by the (1) of x0 y(align the nozzle to the spindle). Measure from the center of the nozzle to the center of the spindle and subtract that number from x0. The Y value will be the Y position as indicated by the DWC tool position.
                Next move tool head to position 2 of x(align the nozzle to the spindle) y395. Measure from the center of the nozzle to the center of the spindle and add that number to y395. The X value will be the X position as indicated by the DWC tool position.
                Next move tool head to position 3 of x415 y(align the nozzle to the spindle). Measure from the center of the nozzle to the center of the spindle and add that number to x415. The Y value will be the Y position as indicated by the DWC tool position.
                Update the M671 with the values collected from the above steps.
                M671 X0:215:450 Y80:450:80 S5 				     ; Position of Leadscrews
                Next copy your first G30 command from the 3point calibration
                G30 P0 X40 Y80 Z-99999
                to the console and send it the printer. Once the command has finished record the tool position as indicated by the DWC. Use this x and y value in a G1 x## y## command at the beginning of the 3point calibration followed by G30 to set the z height.
                Update the 3point calibration macro to something like
                M203 Z100 ; set a low z max speed to increase accuracy. Run multiple G30 S-1 to determine the speed needed to achieve the accuracy you need.
                G28
                while true
                        G1 X## Y## ; enter the tool position as indicated by the DWC after running the first G30 command in the 3point calibration
                        G30 ; sets the first point of the 3point calibration as Z0
                	G30 P0 X40 Y80 Z-99999          ; Probe near the front left lead-screw
                        G30 P1 X215 Y395 Z-99999        ; Probe near the rear lead screw
                        G30 P2 X415 Y80 Z-99999 S3      ; Probe near the front right lead-screw
                	M409 K"move.calibration.initial.deviation" ;displays deviation in console
                        M400 ; wait for move to complete
                        M291 P{move.calibration.initial.deviation} S3 ;displays deviation value
                	if move.calibration.initial.deviation <= 0.001  ; change the 0.001 to your needed value
                		echo "Passed"
                                M203 Z1000 ; set this z max speed to match your config file. Note if you cancel this macro by selecting the cancel button on the M291 message box this command will not run. You will need to run this command from the console to restore the max z speed
                		break
                	continue
                Follows these steps above to double check all your setting are correct. Lets the 3point calibration macro run until the deviation no longer decreases and post the results.
                @Phaedrux
                This is my understanding of the calibration process for 3 motor Z axis calibration.
                If something is not correct please update it. This is the process I used to set mine up and it works perfectly.
                Edit: {
                Added M203 to start and end of macro to increase probe accuracy.
                @3dML said in RRF3.2Beta4.1 Heightmap vs. Spindle/Driver Mapping:
                @Frederik
                I have found that slowing down the maximum Z speed can help with tolerance.
                • Frederikundefined
                  Frederik
                  @3dML @Phaedrux
                  this is the online fusion 360 CAD Model of my build. perhaps it helps to show the position oh everything and offsets ....
                  https://myhub.autodesk360.com/ue2c6242f/g/shares/SH56a43QTfd62c1cd9689aec54c27a170106
                  • 3dMLundefined
                    3dML
                    @Frederik
                    The drawing looks correct. My above post still applies.
                    Based on these values
                    all offsets are relative to nozzle position with the tool at x0 y0.
                    Base on that drawing and your height map I'd say the bed has a large sag along the Y axis.
                    In this image your 3point calibration deviation is close to 0 but the sag in the bed is causing the skew in the Heightmap.
                    Frederikundefined 2 Replies Last reply Reply Quote 0
                    • Frederikundefined
                      Frederik @3dML
                      @3dML ok, i will post the values as soon as im finished. i will send the manufacturer a photo, perhaps its was damaged during shipping
                      • Frederikundefined
                        Frederik @3dML
                        @3dML I will save 4 workspace positions on the outer corners so that i am always probing at the same spots, and check the mounting of the bed + possible options for what to improve...
                        right now it sits on 4 silicone pads.
                        i could change to springs or to 4 solid openbuild Blocks
                        @Phaedrux
                        • 3dMLundefined
                          3dML
                          @Frederik
                          Post a picture of the current mount you are using to mount the bed to the z sub-frame. If you are using the mounts I think you are they may be be the cause of sum of the sag.
                          Frederikundefined 1 Reply Last reply Reply Quote 0
                          • Frederikundefined
                            Frederik @3dML
                            @3dML Good Morning,
                            Merry Christmas
                            The last if loop after modifying the accel values of Z to 20 and max speed to 100
                            M98 P"0:/macros/1 test if loop - Z deviation new"
                            Leadscrew adjustments made: 0.351 -1.187 0.554, points used 3, (mean, deviation) before (0.049, 0.626) after (0.000, 0.000)
                            {"key":"move.calibration.initial.deviation","flags":"","result":0.626}
                            Leadscrew adjustments made: 0.346 -0.771 0.107, points used 3, (mean, deviation) before (-0.010, 0.392) after (-0.000, 0.000)
                            {"key":"move.calibration.initial.deviation","flags":"","result":0.392}
                            Leadscrew adjustments made: 0.093 -0.459 0.023, points used 3, (mean, deviation) before (-0.066, 0.200) after (0.000, 0.000)
                            {"key":"move.calibration.initial.deviation","flags":"","result":0.200}
                            Leadscrew adjustments made: 0.077 -0.390 -0.087, points used 3, (mean, deviation) before (-0.095, 0.158) after (0.000, 0.000)
                            {"key":"move.calibration.initial.deviation","flags":"","result":0.158}
                            Leadscrew adjustments made: -0.032 -0.217 -0.052, points used 3, (mean, deviation) before (-0.084, 0.067) after (0.000, 0.000)
                            {"key":"move.calibration.initial.deviation","flags":"","result":0.067}
                            Leadscrew adjustments made: -0.170 -0.222 -0.008, points used 3, (mean, deviation) before (-0.125, 0.068) after (0.000, 0.000)
                            {"key":"move.calibration.initial.deviation","flags":"","result":0.068}
                            Leadscrew adjustments made: -0.142 -0.175 -0.105, points used 3, (mean, deviation) before (-0.137, 0.022) after (-0.000, 0.000)
                            {"key":"move.calibration.initial.deviation","flags":"","result":0.022}
                            Leadscrew adjustments made: -0.15 actual 2 -0.165 -0.158, points used 3, (mean, deviation) before (-0.157, 0.004) after (0.000, 0.000)
                            {"key":"move.calibration.initial.deviation","flags":"","result":0.004}
                            Leadscrew adjustments made: -0.164 -0.177 -0.151, points used 3, (mean, deviation) before (-0.163, 0.008) after (-0.000, 0.000)
                            {"key":"move.calibration.initial.deviation","flags":"","result":0.008}
                            Leadscrew adjustments made: -0.182 -0.158 -0.160, points used 3, (mean, deviation) before (-0.168, 0.008) after (-0.000, 0.000)
                            Leadscrew adjustments made: -0.165 -0.169 -0.172, points used 3, (mean, deviation) before (-0.168, 0.002) after (0.000, 0.000)
                            {"key":"move.calibration.initial.deviation","flags":"","result":0.002}
                            Passed
                            My NOZZLE !!! is now x0 Y0, like you mentioned, and bltouch x-35 y-15 d, i would thay after looking at the different values, the measurements are getting overall closer and more consistent 🙂
                            @3dML
                            Yesterday i changed the mounting from silicone spacers back to the standard springs from the Kit. now its mounted 1:1 like the CAD above wiht 4 springs at the corners
                            • Frederikundefined
                              Frederik @Frederik
                              @3dML
                              the old mounting:
                              at the moment mounted with this original springs:
                              IMG_20201224_102026.jpg ![IMG_20201224_101939.jpg]
                              The openbuild blocks:
                              the subframe assembly from the side:
                              on top is a Prima Creator Magnetic Flex Steel Plate
                              and the Keenovo Silicone Heatpad below + isolating padding
                              • 3dMLundefined
                                3dML
                                @Frederik
                                My guess is excessive force got applied to the center of the bed at some point and the nature of the L brackets with a single bolt allowed them to swivel inward creating the bend in the bed along the Y axis. I don't have any experience with that style of bed mount so not sure what would be the best recommendation for mounting.
                                • Frederikundefined
                                  Frederik @3dML
                                  @3dML The Bed was shipped with DHL Express from Portugal to Germany. Perhaps it got damaged along the way?
                                  What are the most thermal stable and least problematic solutions for the bed ?
                                  i wanted to print a 3 or 4 point kinematic mount like the Hevort V2 without the need of a subframe . only 3x sfu1204 Spindles and a mgn12 or 15 rail behind to eliminate the ply of the floating mount (without FK/BK Blocks).
                                  option 1: borosilikat plate 400x400mm without flex plate or similar
                                  option 2. Aluminium Plate, 10-20mm thick with precision ground surface to +0.025 to -0.025 and flex plate or something like that
                                  option 3 the same precision plate , only with a DIY coating with Ultem Pellets (PEI) solved in dichloromethane
                                  • Frederikundefined
                                    Frederik
                                    the corresponding .csv values:
                                    xmin,xmax,ymin,ymax,radius,xspacing,yspacing,xnum,ynum
                                    10.00,400.00,10.00,390.00,-1.00,43.30,42.20,10,10
                                    0.238, -0.344, -0.824, -1.021, -1.114, -1.004, -0.833, -0.581, -0.169, 0
                                    -0.003, -0.475, -0.694, -0.875, -0.938, -0.924, -0.785, -0.514, -0.146, 0
                                    0.029, -0.307, -0.608, -0.732, -0.866, -0.804, -0.649, -0.469, -0.089, 0
                                    0.132, -0.153, -0.518, -0.618, -0.739, -0.704, -0.600, -0.338, -0.053, 0
                                    0.280, -0.028, -0.245, -0.518, -0.637, -0.599, -0.485, -0.265, 0.003, 0
                                    0.421, 0.117, -0. 114, -0.345, -0.470, -0.528, -0.417, -0.231, 0.083, 0
                                    0.631, 0.253, -0.006, -0.208, -0.333, -0.352, -0.258, -0.115, 0.202, 0
                                    0.842, 0.446, 0.163, -0.082, -0.162, -0.266, -0.206, 0.006, 0.268, 0
                                    1.037, 0.647, 0.309, 0.086, -0.064, -0.107, -0.045, 0.151, 0.456, 0
                                    0, 0, 0, 0, 0, 0, 0, 0, 0,
                                    Thats the last map after i tested a few little things, i thought could help to validate the measurements and improve the probing further:
                                    firmware upgrade to 3.2RC2
                                    Then only for safety 🙂
                                    M997 B121
                                    M997 B0
                                    • new macros with every BLTouch command including the EEProm Conversion request from open drain to 5v and vice versa
                                      additional, i measured how deep the set crew is on top of the BLTouch and tryed if the ^ on the input pin made a difference in accuracy or error count (error on every probing try or only on every 10th...).
                                    1. loosen the mounting screws to the subframe, so that the bed was only held by its own weight on top of the springs to release every little bit of mounting stress like you mentioned above (perhaps a force was applied in the center...).
                                    next, i will rotate the bed 90° and 180 ° to see if the Heightmap in DWC is changing accordingly.
                                    If it doesn't change, i try and change driver 0.3 and 0.4 (Hardware wiring) and check what happens with the compensation map
                                    1. Set the Heater to 120°C, because I thought the thermal expansion could help a little bit, or it flexed while printing PLA with 50°C Bed Temp.
                                    2. Trying to bring it down on the left lower, upper and right corners with the mounting screws and shim it on the right lower corner
                                    • Frederikundefined
                                      Frederik
                                      i made a few tests with different bed mounts.
                                      when i probe 4 points on the outer corners i get these values:
                                      RepRapFirmware height map file v2 generated at 2020-12-28 19:39
                                      10.00,380.00,10.00,380.00,-1.00,350.00,350.00,2,2
                                        0.083, -0.042
                                       -0.082,  0.077
                                      and the corresponding graphic in DWC:
                                      when probing more points i get this values:
                                      RepRapFirmware height map file v2 generated at 2020-12-28 19:52
                                      10.00,380.00,10.00,380.00,-1.00,55.00,55.00,7,7
                                        0.067, -0.716, -1.026, -1.035, -0.892, -0.648, -0.194
                                       -0.543, -0.832, -0.956, -1.031, -0.845, -0.609, -0.239
                                       -0.586, -0.778, -0.884, -0.869, -0.774, -0.577, -0.268
                                       -0.531, -0.686, -0.745, -0.789, -0.716, -0.558, -0.302
                                       -0.446, -0.559, -0.581, -0.624, -0.567, -0.474, -0.275
                                       -0.328, -0.423, -0.451, -0.486, -0.405, -0.334, -0.193
                                       -0.150, -0.201, -0.192, -0.164, -0.126, -0.115, -0.083
                                      • Frederikundefined
                                        Frederik
                                        and this a second map generated right after the first two:
                                        the values from heightmap.csv:
                                        RepRapFirmware height map file v2 generated at 2020-12-28 20:15
                                        10.00,380.00,10.00,360.00,-1.00,37.00,35.00,11,11
                                          0.654,  0.049, -0.369, -0.588, -0.709, -0.703, -0.634, -0.514, -0.327, -0.081,      0
                                          0.105, -0.311, -0.518, -0.634, -0.707, -0.710, -0.635, -0.561, -0.365, -0.162,      0
                                         -0.046, -0.310, -0.495, -0.571, -0.688, -0.729, -0.654, -0.570, -0.404, -0.206,      0
                                         -0.118, -0.321, -0.484, -0.575, -0.659, -0.693, -0.621, -0.582, -0.434, -0.243,      0
                                         -0.121, -0.301, -0.431, -0.529, -0.636, -0.618, -0.610, -0.552, -0.451, -0.276,      0
                                         -0.113, -0.293, -0.383, -0.503, -0.560, -0.549, -0.601, -0.555, -0.456, -0.266,      0
                                         -0.110, -0.225, -0.334, -0.405, -0.512, -0.547, -0.524, -0.474, -0.436, -0.339,      0
                                         -0.051, -0.171, -0.239, -0.339, -0.444, -0.478, -0.474, -0.456, -0.409, -0.342,      0
                                          0.002, -0.133, -0.213, -0.276, -0.329, -0.369, -0.348, -0.359, -0.339, -0.285,      0
                                          0.086, -0.059, -0.100, -0.133, -0.233, -0.228, -0.225, -0.246, -0.260, -0.226,      0
                                          0.116,  0.061,  0.006, -0.048, -0.033, -0.045, -0.047, -0.141, -0.179, -0.155,      0
                                          The heightmap shows a bowl shape. The 4 point map shows that the bed is basically level.
                                          Now the question is whether the mesh compensation is enough to compensate for the shape of the bed surface.
                                          bedlevel_nozzle_0.4_200x200-0.3-0.8.stl
                                          Print a test file once with compensation active and again with it disabled and see if the first layer is better with it active.
                                          • Frederikundefined
                                            Frederik @Phaedrux
                                            @Phaedrux thanks for the file. i will test it and report back whats happening .
                                            the last time i tried a 350x350 X as test, i had to abort the print after i saw that the printed line was getting squished more and more...and before the nozzle starts digging in the bed i stopped the test. that was perhaps 10 cm from the center
                                            parts up to perhaps 8x8cm from the center where i home Z are no problem, but as soon as i try bigger parts with 15x 8 i already can see the height changes in the actual layer
                                            You can see it goog here in the picture below. The actual part is 6.5cm wide
