    rrf3 trigger g30 s-1 problem
    • luca-f13undefined
      luca-f13
      Hello everyone I wish you happy holidays and to not let you get bored during Christmas I ask you my problem
      I went from release 2.05 to 3.1.1 in release 2.05 the commands to calibrate the Z 0 with my bltouch thinking it was child's play having already run it a thousand times.
      then I turn on the printer
      I launch the commands:
      g92 z0
      g1 z10
      g30 s-1
      as part of doing the check the error comes out
      G30 S-1
      Error: Z probe was not triggered during probing move
      cosa sto sbagliando?
      allego config.g
      config.g
      • PCRundefined
        PCR
        post you config.g
        • luca-f13undefined
          luca-f13
          è allegato
          eccolo comunque
          ; Configuration file for Duet Maestro (firmware version 3)
          ; generated by RepRapFirmware Configuration Tool v3.1.10 on Thu Dec 24 2020 09:57:02 GMT+0100 (Ora standard dell’Europa centrale)
          M550 P"draw2-200" ; set printer name
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M569 P4 S1 ; physical drive 4 goes forwards
          M584 X0 Y1 Z2 E3:4 ; set drive mapping
          M92 X100.00 Y100.00 Z400.00 E120.20:120.20 ; set steps per mm
          M566 X900.00 Y900.00 Z12.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
          M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2)
          M906 X1000 Y1000 Z1400 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X220 Y220 Z200 S0 ; set axis maxima
          M574 X1 S1 P"!^xstop" ; configure active-high endstop for low end on X via pin !^xstop
          M574 Y1 S1 P"!^ystop" ; configure active-high endstop for low end on Y via pin !^ystop
          M950 S0 C"^zprobe.mod" ; create servo pin 0 for BLTouch
          M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
          G31 P500 X-28 Y-39.5 Z0.842 ; set Z probe trigger value, offset and trigger height
          M557 X20:200 Y20:200 S45 ; define mesh grid
          M143 H0 S100 ; set temperature limit for heater 0 to 100C
          M308 S1 P"e0temp" Y"thermistor" T100000 B3950 ; configure sensor 1 as thermistor on pin e0temp
          M308 S2 P"e1temp" Y"thermistor" T100000 B3950 ; configure sensor 2 as thermistor on pin e1temp
          M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
          M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
          M143 H2 S280 ; set temperature limit for heater 2 to 280C
          M950 F0 C"!fan0" Q500 ; create fan 0 on pin !fan0 and set its frequency
          M106 P0 S0 H0 T35 ; set fan 0 value. Thermostatic control is turned on
          M106 P1 S1 H1:2 T30 ; set fan 1 value. Thermostatic control is turned on
          M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
          M106 P2 S1 H2:1 T30 ; set fan 2 value. Thermostatic control is turned on
          M563 P0 S"anteriore" D0 H1 F0:1 ; define tool 0
          M563 P1 S"posteriore" D1 H2 F0:2 ; define tool 1
          ; Custom settings
          ; DISPLAY
          M575 P1 S1 B57600
          ; config override.g
          M501
          • luca-f13undefined
            luca-f13
            NO ONE HAS UNDERSTOOD WHERE WRONG
              Phaedrux Moderator @luca-f13
              @luca-f13 said in rrf3 trigger g30 s-1 problem:
              G30 S-1
              Does it trigger with a G30?
              Can you send M122 and M98 P"config.g" and post the results?
                dc42 administrators @Phaedrux
                Does the bltouch pin deploy when you send M401 and retract when you send M402 ?
