    how to purge the filament from the second extruder
    My Duet controlled machine
    • konte1978undefined
      konte1978
      Hi guys I don't understand how I can control the second extruder in order to purge the filament before processing. For the first time I use these commands:
      G21
      G90
      G92 E0
      G1 E150 F200
      M400
      In Duet Web Control I set the temperature of the second extruder by activating it, but the first extruder always moves.
        Post your config.g so we can see your tool and heater definitions.
        konte1978undefined 1 Reply Last reply Reply Quote 0
          konte1978
          playing I noticed something that I don't think is regular, loading a filament in the first extruder loads it at the same time also on the second one, instead if I load it on the third extruder it loads it well.![alt text])FILAMENTO.png
            konte1978 @Phaedrux
            @Phaedrux ; Configuration file for Duet WiFi (firmware version 3)
            ; generated by RepRapFirmware Configuration Tool v3.1.4 on Fri Jul 17 2020 20:24:58 GMT+0200 (CEST)
            M550 P" CUBE PRO TRIO" ; set printer name
            M552 S1 ; enable network
            M586 P0 S1 ; enable HTTP
            M586 P1 S0 ; disable FTP
            M586 P2 S0 ; disable Telnet
            M569 P4 S1 ; physical drive 4 goes forwards
            M569 P9 S1 ; physical drive 9 goes forwards
            M584 X0 Y1 Z2 E3:4:9 ; set drive mapping
            M350 X16 Y16 Z16 E16:16:16 I1 ; configure microstepping with interpolation
            M92 X87.35 Y87.43 Z1076.77 E82.09:82.09:82.09 ; set steps per mm
            M566 X900.00 Y900.00 Z12.00 E120.00:120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
            M203 X15000.00 Y15000.00 Z1200.00 E600.00:600.00:600.00 ; set maximum speeds (mm/min)
            M201 X500.00 Y500.00 Z250.00 E250.00:250.00:250.00 ; set accelerations (mm/s^2)
            M906 X1500 Y1500 Z800 E1200:1200:1200 I30 ; set motor currents (mA) and motor idle factor in per cent (ho modficato la corrente dei motori dell'estrusore da 800 a 1200)
            M84 S30 ; Set idle timeout
            M208 X0 Y0 Z0 S1 ; Imposta valore minimo deli assi
            M208 X290 Y295.3 Z205 ; imposta il valore massimo degli assi ho tolto il valore S0 ALLA FINE DELLA RIGA
            M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop
            M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
            M950 S0 C"duex.pwm5" ; creare il servo pin 0 per BLTouch
            M558 P9 C"^zprobe.in" H5 F120 T6000 A10 R0.75 S0.02 ; set Z probe type to bltouch and the dive height + speeds
            G31 P25 X-11.70 Y-51.2 Z2.75 ; impostare il valore del trigger della sonda Z, l'offset e l'altezza del trigger
            M557 X12.3:290 Y24.80:295 S20 ; define mesh grid
            ;Piatto riscaldato
            ;M570 H0 P90 T20 ; sto cercando di far aspettare fino che il piatto si riscaldi prima che mi dia errore
            M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp ho modificato il valore dalla B4138 CON 3950
            M143 H0 S110 ; set temperature limit for heater 0 to 120C
            ;Estrusore numero 1
            M308 S1 P"spi.cs1" Y"rtd-max31865" ; configure sensor 1 as thermistor on pin e0temp
            M143 H1 S290; set temperature limit for heater 0 to 120C
            ;Estrusore numero 2
            M308 S2 P"spi.cs2" Y"rtd-max31865" ; configure sensor 2 as thermistor on pin e1temp
            M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
            M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
            M143 H2 S270
            ;Estrusore numero 3
            M308 S3 P"spi.cs3" Y"rtd-max31865" ; M308 S3 P"duex.e2temp" Y"thermistor" T100000 B4725 ; configure sensor 3 as thermistor on pin duex.e2temp
            M950 H3 C"duex.e2heat" T3 ; create nozzle heater output on duex.e2heat and map it to sensor 3
            M143 H3 S270 ; set temperature limit for heater 0 to 120C
            M307 H3 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
            ; Riscaldatore della camera
            M141 H4 ; il riscaldatore 4 è il riscaldatore della camera
            M950 H4 C"duex.e3heat" T4 ; configura l'uscita per il riscaldamento della camera sull pin e della scheda duex
            M308 S4 P"duex.e3temp" Y"thermistor" T100000 B5500 C7.06Ee-8 ; configure sensor 4 as thermistor on pin duex.e2temp
            M143 H4 S70 ; set temperature limit for heater 0 to 120C
            M301 H4 B1 ; utilizzare il controllo bang-bang per il riscaldatore della camera
            M106 P0 C"ESTRUSORI" S0 H3:2:1 T120 ; set fan 0 name and value. Thermostatic control is turned on
            M106 P1 C"NOZZLE" S0 H1:2:3 T45 ; set fan 1 name and value. Thermostatic control is turned on
            M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
            M106 P2 C"LUCI LED" S0 H-1 ; set fan 2 name and value. Thermostatic control is turned off
            M950 F3 C"duex.fan6" Q500 ; create fan 3 on pin duex.fan6 and set its frequency
            M106 P3 C"VENTOLA 6" S0 H-1 ; set fan 3 name and value. Thermostatic control is turned off
            M950 F4 C"duex.fan7" Q500 ; create fan 4 on pin duex.fan7 and set its frequency
            M106 P4 C"VENTOLA 7" S0 H-1 ; set fan 4 name and value. Thermostatic control is turned off
            ; Tools monitoraggio del filamento
            M563 P0 S"estrusore 1" D0 H1 F0:1 ; define tool 0
            M563 P1 S"estrusore 2" D0 H2 F0:1 ; define tool 1
            M563 P2 S"estrusore 3" D2 H3 F0:1 ; define tool 2
            G10 P2 X0 Y0 Z0 ; set tool 2 axis offsets
            G10 P2 R0 S0 ; set initial tool 2 active and standby temperatures to 0C
            ; Sensori di folamento degli estrusori se imposto l'ultima S0 disabilita il confronto tra filamento aspetatto e quello realmente estruso,S1 abilita il controllo
            M591 D0 P5 C"e0stop" R5:190 E3.0 S0 ; ho configurato il filamento del primo estrusore sull'uscita e0stop valori sensibilità filamneto originale R40:120
            M591 D1 P5 C"connlcd.encb" R5:190 E3.0 S1 ; ho configurato il filamento del secondo estrusore sull'uscita stop10(ECN_B) valori sensibilità filamneto originale R40:120
            M591 D2 P5 C"e1stop" R5:190 E3.0 S1 ; ho configurato il filamento del terzo estrusore sull'uscita e1stop valori sensibilità filamneto originale R40:120
            M575 P1 S1 B57600 ;per abilitare lcd paneldue
            M501
            M500
              Phaedrux Moderator @konte1978
              @konte1978 said in how to purge the filament from the second extruder:
              Tool 0 is using Drive 0
              Tool 1 is using Drive 0
              Tool 2 is using Drive 2
              You probably should change Tool1 to use Drive 1.
              Change to D1
              You're also using all the same fans for each tool. Is that correct?
              M500
              Remove M500 from the end of config.g
                konte1978
                First of all, thank you very much, with your help I solved the problem For the extruders I use three fans connected to the same outlet that automatically turns on at 120 degrees. If you see errors in my code or things to improve please tell me. I still have to correct several anomalies but I will ask in another dedicated topic.WhatsApp Image 2020-12-27 at 09.39.37.jpeg
