    problems with pressure advance calibration
    2.1k
    • Vetiundefined
      Veti
      whats your e acceleration. pressure advance needs high numbers for that to work.
      also check out the guide i just posted
      https://forum.duet3d.com/topic/20558/pressure-advance-tuning-like-klipper
      nick9one1undefined 1 Reply Last reply Reply Quote 0
      • Vetiundefined
        Veti
        also what kind of setup do you have?
        direct drive or bowden?
        • nick9one1undefined
          nick9one1
          thanks. about 650mm bowden.
          its a BLVMGN core XY
          M566 X820.00 Y820.00 Z24.00 E300.00            	; set maximum instantaneous speed changes (mm/min)
          M203 X20000.00 Y20000.00 Z600.00 E2000.00      	; set maximum speeds (mm/min)
          M201 X3000.00 Y3000.00 Z100.00 E5000.00        	; set accelerations (mm/s^2)
          M906 X1100 Y1100 Z1100 E1100 I30               	; set motor currents (mA) and motor idle factor in per cent
            nick9one1 @Veti
            @Veti Thanks. Printing your modified test cube now.
            I set M201 X500 Y500 in config.g
            Sliced the cube as per the instructions. 100mm/s, 0.3 layer height, 0% infill, and M572 D0 S{layer_z*0.02} in the layer change g-code.
            the only slight alteration I made was to ensure the later changes were in the middle fo a face, not at the corner. I think its easier to identify the correct pressure advance this way.
            • Vetiundefined
              Veti
              depending on the quality of your bowden tube you might need to go above 1 as 650mm is quite long
              and you dont need infill for the test qube
              nick9one1undefined 1 Reply Last reply Reply Quote 1
                nick9one1 @Veti
                @Veti
                thanks. It was just the top layers I forgot to set to 0. Infill is already 0 with 3 walls.
                  nick9one1
                  ![alt text](image url20201226_170558.jpg )
                  • Vetiundefined
                    Veti
                    that doesnt look to good to begin with.
                    about the middle looks a bit better then the rest.
                      Phaedrux Moderator @nick9one1
                      @nick9one1 said in problems with pressure advance calibration:
                      Increase your E jerk. Try 3000.
                        nick9one1
                        thanks. Increased Ejerk to 3000 and printing again, but only 2 walls this time for speed.
                        The previous print was 100mm/s
                          nick9one1
                          Looking much better at 3000 e jerk. Thanks for that tip.
                          Around halfway looks about the best.
                          I can see the right side of each new layer is changes but not the end of previous layer -how do I tune this?
                          ![alt text](image url20201226_225533.jpg )
                            Run another test but zero in on the area from the middle area and use finer steps between jumps.
                            For the bulge from layer change you can also increase your Z axis jerk and accel a bit more. Try M566 Z60 and M201 Z200 or higher.
                            Do you have retract on layer change enabled in the slicer as well? That can help.
                              nick9one1 @Phaedrux
                              @Phaedrux said in problems with pressure advance calibration:
                              Thank you. Yes I have retract on layer change enabled
                              I've changed the z values you suggested and set the slicer to start the pressure advance at 0.035 in increments to 0.055. Printing now 🙂
                                nick9one1
                                I'm definitely getting closer..
                                I think pressure advance is well tuned now, but I still have extra extrusion on the left.
                                This is with ;
                                M566 Z90
                                M201 Z300
                                my original settings were;
                                M566 Z24
                                M201 Z100
                                  Turn off wipe while retracting and re-run the test.
