problems with pressure advance calibration
2.1k
    nick9one1 @Veti
    @Veti Thanks. Printing your modified test cube now.
    I set M201 X500 Y500 in config.g
    Sliced the cube as per the instructions. 100mm/s, 0.3 layer height, 0% infill, and M572 D0 S{layer_z*0.02} in the layer change g-code.
    the only slight alteration I made was to ensure the later changes were in the middle fo a face, not at the corner. I think its easier to identify the correct pressure advance this way.
      Veti
      depending on the quality of your bowden tube you might need to go above 1 as 650mm is quite long
      and you dont need infill for the test qube
      undefined 1 Reply Last reply 26 Dec 2020, 15:26 Reply Quote 1
        nick9one1 @Veti
        @Veti
        thanks. It was just the top layers I forgot to set to 0. Infill is already 0 with 3 walls.
          nick9one1
          ![alt text](image url20201226_170558.jpg )
            Veti
            that doesnt look to good to begin with.
            about the middle looks a bit better then the rest.
              Phaedrux Moderator @nick9one1
              @nick9one1 said in problems with pressure advance calibration:
              M566 X820.00 Y820.00 Z24.00 E300.00
              Increase your E jerk. Try 3000.
                nick9one1
                thanks. Increased Ejerk to 3000 and printing again, but only 2 walls this time for speed.
                The previous print was 100mm/s
                  nick9one1
                  Looking much better at 3000 e jerk. Thanks for that tip.
                  Around halfway looks about the best.
                  I can see the right side of each new layer is changes but not the end of previous layer -how do I tune this?
                  ![alt text](image url20201226_225533.jpg )
                    Run another test but zero in on the area from the middle area and use finer steps between jumps.
                    For the bulge from layer change you can also increase your Z axis jerk and accel a bit more. Try M566 Z60 and M201 Z200 or higher.
                    Do you have retract on layer change enabled in the slicer as well? That can help.
                    undefined 1 Reply Last reply 27 Dec 2020, 10:24 Reply Quote 0
                      nick9one1 @Phaedrux
                      @Phaedrux said in problems with pressure advance calibration:
                      Thank you. Yes I have retract on layer change enabled
                      I've changed the z values you suggested and set the slicer to start the pressure advance at 0.035 in increments to 0.055. Printing now 🙂
                        nick9one1
                        I'm definitely getting closer..
                        I think pressure advance is well tuned now, but I still have extra extrusion on the left.
                        This is with ;
                        M566 Z90
                        M201 Z300
                        my original settings were;
                        M566 Z24
                        M201 Z100
                          Turn off wipe while retracting and re-run the test.
                          14 out of 16
