    z motor not driving when connected to leadscrew
    My Duet controlled machine
    1.8k
      Phaedrux Moderator @Ian Miller
      @Ian-Miller said in z motor not driving when connected to leadscrew:
      Each motor is only rated to 0.33 amps.
      Those are quite small motors. How much does the gantry weigh? How much compliance is there in the gantry? When they aren't perfectly even they are likely binding a bit and the motors aren't very powerful. I think they may not be suitable for your Z axis. Do you have the specs for them?
      • Ian Millerundefined
        Ian Miller
        I tried wiring them in parallel and now neither motor activates whatsoever, but I will work on that.
        As for the motor specs I will post them below. The entire gantry the 2 motors are lifting is between 2.5 and 3 pounds.
          I can't make anything out on that blurry image.
          • Vetiundefined
            Veti
            are you aware that you have bought a cloned board?
            those motors are not suitable for 3d printers
            https://images-na.ssl-images-amazon.com/images/I/A1N+z7VtiNL.pdf
            see
            https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors
            Avoid motors with rated voltage (or product of rated current and phase resistance) > 4V or inductance > 4mH.
              Ian Miller
              I did not realize that those motors were not ok with 3d printers, I'm using them for driving every other axis on this machine and they all 5 seem to be working well. Do you recommend I just get new motors for that axis or is there anything else I can try?
              Btw thank you guys for all the tips and ideas, I'm only 15 and this is my first fully custom printer build.
              • Vetiundefined
                Veti
                M350 X16 Y16:16 Z16 E16 I1 ; configure microstepping with interpolation
                M92 X80.00 Y80.00:80.00 Z1600.00 E420.00 ; set steps per mm
                M566 X900.00 Y900.00:900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
                M203 X6000.00 Y6000.00:600.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
                M201 X500.00 Y500.00:500.00 Z20.00 E250.00 ; set accelerations (mm/s^2)
                M906 X800 Y800:800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
                this is incorrect, y does not allow for double settings.
                delete the second y entry.
                also if your motors are 0.33A you are running them with 0.8A, you might have damaged to motors.
                  I would be reluctant to use those motors. Return them if you can. They may be alright for the other axis at low speeds, but the weight of the Z axis is likely a problem for them.
                  Use that link for choosing motors to try and determine what you need.
                  https://www.omc-stepperonline.com/nema-17-stepper-motor/?mfp=148-bipolar-unipolar[Bipolar],146-rated-current-a[1.0,1,1.2,1.33,1.5,1.68,2.00,2,2.0],71-single-shaft-dual-shaft[Single Shaft],21-shaft-type[D-Cut],22-shaft-diameter-mm[5],151-inductance-mh[2.5,2.6,2.8,3,3.0,3.00,3.2,4.1]
                  Here's a filtered search result that has some good options. Determine if you want/need 0.9 degree motors and how much torque.
                    Ian Miller
                    I'm using 4 of them on the y and 1 on the x and they are providing plenty of power and seem to be accurate. It was only 30$ for 10 so its not a big deal to get new motors. And here is the latest version of the config for those who were concerned with errors.
                    M569 P3 S0 ; physical drive 3 goes forwards
                    M569 p4 s1
                    M584 X0 Y1 Z2 ; set drive mapping
                    M584 E3:4
                    M92 X80 Y80 Z400
                    M92 E429.85:99 ; Set steps per mm
                    M566 X1200 Y1200 Z24 E300 ; Set maximum instantaneous speed changes (mm/min)
                    M203 X30000 Y30000 Z600 E3000:3000 ; Set maximum speeds (mm/min)
                    M201 X500 Y500 Z100 E25:250 ; Set accelerations (mm/s^2)
                    M906 X800 Y800 Z800 E800:800 I30 ; Set motor currents (mA) and motor idle factor in per cent
                    M84 S30 ; Set idle timeout ; Set idle timeout
                    M208 X300 Y300 Z360 S0 ; set axis maxima
                    M574 X1 Y1 Z1 S1 ; Define active high microswitches
                    M558 P5 H5 F500 T4000 X0 Y0 Z1 ; Set Z probe type/mode 5. Not using on XY, but using it on Z.
                    G31 P25 X29 Y-23 Z2.45 ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
                    M557 x50:250 Y50:250 s30
                    ; BLTouch - Heaters
                    M307 H7 A-1 C-1 D-1 ; Disable the 7th Heater to free up PWM channel 5 on the Duex bo
                    M143 S265 ; Set maximum heater temperature to 265C
                    M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1
                    M305 P2 T100000 B4138 C0 R4700
                    M106 P0 C"Controll box fan" S1 ; set fan 0 name and value. Thermostatic control is turned off
                    M106 P1 C"Extruder fans" S1 H1:2 T45 ; set fan 1 name and value. Thermostatic control is turned on
                    M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
                    M106 P2 C"Part cooling fans" S1 H1:2 T45 ; set fan 2 name and value. Thermostatic control is turned off
                    M563 P0 S"Hotend 0" D0 H2 F2 ; define tool 0
                    M563 P1 S"Hotend 1" D1 H1 F2 ; define tool 1
                    G10 P1 X23.2 Y0 Z0 ; set tool 1 axis offsets
                    ; Custom settings
                    m552 s1
                      Ian Miller
                      Do you think these motors would be good?
                      https://www.amazon.com/RTELLIGENT-Stepper-Bipolar-42x42x38mm-42A02C-Dupont/dp/B0817T5SRH/ref=sr_1_17?dchild=1&keywords=42x42x40%2Bmm%2Bnema%2Bmotor&qid=1609188975&sr=8-17&th=1
                      • Vetiundefined
                        Veti
                        stepper online sells good steppers.
                        they are both used in the blv design.
                        https://www.blvprojects.com/blv-mgn-cube-3d-printer
                        and the voron 2.4
                        https://vorondesign.com/sourcing_guide?model=V2.4
                        your thermistor config is wrong. find the correct beta value in your thermistor documentation.
                          Those would be more suitable, yes. But it's hard to say what you really get from amazon and below.
                          It can help to try and understand what kinds of speeds and accelerations you hope to attain and how much mass you're going to be moving around. This would also be a good time to learn how stepper motors work. A little bit of knowledge now will go a long way to avoiding disappointment and frustrations later. Though that's a good way to learn too.
                          Ian Millerundefined 1 Reply Last reply Reply Quote 0
                            A Former User @Ian Miller
                            if the link from Veti is the same motors then they have a very high inductance, which will severely limit the speed you can operate at with a 12v supply, and this becomes a bigger problem when you have two in series on the Z driver .. which explains the error "motor phase A may be disconnected"
                            You'd probably want to take Phaedrux's advice and concider replacing them, but you could lower the current a little and/or increase the 12v supply (but that might create issues with heaters) and also reduce the speed, jerk and acceleration to try to make them work.
                              Ian Miller @Phaedrux
                              @Phaedrux since they are driving leadscrews that are holding a gantry that is about 3 pounds they need to be relatively strong but don't need to be extremely fast. I will pick up some new motors from stepperonline. Thanks for all your help guys.
                                Ian Miller
                                I picked up the new steppers and wired them up to the board. When I try to run them they just seem to be vibrating whether under load or not. When I use the provided jst connectors and run the motor there is nothing at all but when I use the setup for the previous motors they just vibrate. I'm pretty sure this is a wring issue but I'm not exactly sure what it is. I have them set to 1.5 amps witch is their rated current and they are wired in parallel to a single set of pins.
                                  A Former User
                                  maybe this helps?
                                  https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Identifying_the_stepper_motor_phases
                                    Ian Miller
                                    I checked using a multimeter that the pins on the motor were ABAB and wired to the board as AABB. But I'm getting no response whatsoever from the motor. I have tested at both 0.8 and 1.5 amps and also I am running just a single motor to test with no load. The motor doesn't even activate and can be easily turned by hand.
                                    When the motor was vibrating and also not keeping its position while idle, it was wired ABAB on the board.
                                      A Former User
                                      Are you getting any errors from the Duet after wiring them correctly? unfortunately incorrectly wiring can potentially destroy the drivers.
                                        Can you post the results of M122 after trying to move the motor?
                                        Do you get any errors in the console?
                                          @Phaedrux no errors in the console
                                          m122
                                          RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03beta3 running on Duet WiFi 1.02 or later
                                          Board ID: 0JD0M-9P61A-J8PSJ-6J9F6-3S06R-KUQ2S
                                          Used output buffers: 1 of 20 (17 max)
                                          Static ram: 25632
                                          Dynamic ram: 93800 of which 0 recycled
                                          Exception stack ram used: 412
                                          Never used ram: 11228
                                          Tasks: NETWORK(ready,652) HEAT(blocked,1236) MAIN(running,3816) IDLE(ready,196)
                                          Owned mutexes:
                                          Last reset 00:01:10 ago, cause: software
                                          Last software reset time unknown, reason: User, spinning module GCodes, available RAM 11264 bytes (slot 3)
                                          Error status: 0
                                          Free file entries: 10
                                          SD card longest block write time: 89.5ms, max retries 0
                                          MCU temperature: min 34.9, current 35.2, max 35.4
                                          Supply voltage: min 12.0, current 12.1, max 12.2, under voltage events: 0, over voltage events: 0, power good: yes
                                          Driver 0: standstill, SG min/max 421/873
                                          Driver 2: standstill, SG min/max 0/5
                                          Cache data hit count 244424298
                                          Slowest loop: 2.08ms; fastest: 0.08ms
                                          I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
                                          Hiccups: 0, FreeDm: 169, MinFreeDm: 168, MaxWait: 64222ms
                                          Bed compensation in use: none
                                          === MainDDARing ===
                                          Scheduled moves: 5, completed moves: 5, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
                                          === AuxDDARing ===
                                          Segments left: 0, aux move: no
                                          Movement lock held by null
                                          http is idle in state(s) 0
                                          telnet is idle in state(s) 0
                                          file is idle in state(s) 0
                                          serial is idle in state(s) 0
                                          aux is idle in state(s) 0
                                          daemon is idle in state(s) 0
                                          queue is idle in state(s) 0
                                          Code queue is empty.
                                            Ian Miller @A Former User
                                            @bearer is there a certain reason that that would occur? also how does it destroy the drivers?
