    z motor not driving when connected to leadscrew
    My Duet controlled machine
    1.8k
    • Vetiundefined
      Veti
      are you aware that you have bought a cloned board?
      those motors are not suitable for 3d printers
      https://images-na.ssl-images-amazon.com/images/I/A1N+z7VtiNL.pdf
      see
      https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors
      Avoid motors with rated voltage (or product of rated current and phase resistance) > 4V or inductance > 4mH.
      • Ian Millerundefined
        Ian Miller
        I did not realize that those motors were not ok with 3d printers, I'm using them for driving every other axis on this machine and they all 5 seem to be working well. Do you recommend I just get new motors for that axis or is there anything else I can try?
        Btw thank you guys for all the tips and ideas, I'm only 15 and this is my first fully custom printer build.
        • Vetiundefined
          Veti
          @Ian-Miller said in z motor not driving when connected to leadscrew:
          M350 X16 Y16:16 Z16 E16 I1 ; configure microstepping with interpolation
          M92 X80.00 Y80.00:80.00 Z1600.00 E420.00 ; set steps per mm
          M566 X900.00 Y900.00:900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X6000.00 Y6000.00:600.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
          M201 X500.00 Y500.00:500.00 Z20.00 E250.00 ; set accelerations (mm/s^2)
          M906 X800 Y800:800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
          this is incorrect, y does not allow for double settings.
          delete the second y entry.
          also if your motors are 0.33A you are running them with 0.8A, you might have damaged to motors.
            I would be reluctant to use those motors. Return them if you can. They may be alright for the other axis at low speeds, but the weight of the Z axis is likely a problem for them.
            Use that link for choosing motors to try and determine what you need.
            https://www.omc-stepperonline.com/nema-17-stepper-motor/?mfp=148-bipolar-unipolar[Bipolar],146-rated-current-a[1.0,1,1.2,1.33,1.5,1.68,2.00,2,2.0],71-single-shaft-dual-shaft[Single Shaft],21-shaft-type[D-Cut],22-shaft-diameter-mm[5],151-inductance-mh[2.5,2.6,2.8,3,3.0,3.00,3.2,4.1]
            Here's a filtered search result that has some good options. Determine if you want/need 0.9 degree motors and how much torque.
              Ian Miller
              I'm using 4 of them on the y and 1 on the x and they are providing plenty of power and seem to be accurate. It was only 30$ for 10 so its not a big deal to get new motors. And here is the latest version of the config for those who were concerned with errors.
              M569 P3 S0 ; physical drive 3 goes forwards
              M569 p4 s1
              M584 X0 Y1 Z2 ; set drive mapping
              M584 E3:4
              M92 X80 Y80 Z400
              M92 E429.85:99 ; Set steps per mm
              M566 X1200 Y1200 Z24 E300 ; Set maximum instantaneous speed changes (mm/min)
              M203 X30000 Y30000 Z600 E3000:3000 ; Set maximum speeds (mm/min)
              M201 X500 Y500 Z100 E25:250 ; Set accelerations (mm/s^2)
              M906 X800 Y800 Z800 E800:800 I30 ; Set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout ; Set idle timeout
              M208 X300 Y300 Z360 S0 ; set axis maxima
              M574 X1 Y1 Z1 S1 ; Define active high microswitches
              M558 P5 H5 F500 T4000 X0 Y0 Z1 ; Set Z probe type/mode 5. Not using on XY, but using it on Z.
              G31 P25 X29 Y-23 Z2.45 ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
              M557 x50:250 Y50:250 s30
              ; BLTouch - Heaters
              M307 H7 A-1 C-1 D-1 ; Disable the 7th Heater to free up PWM channel 5 on the Duex bo
              M143 S265 ; Set maximum heater temperature to 265C
              M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1
              M305 P2 T100000 B4138 C0 R4700
              M106 P0 C"Controll box fan" S1 ; set fan 0 name and value. Thermostatic control is turned off
              M106 P1 C"Extruder fans" S1 H1:2 T45 ; set fan 1 name and value. Thermostatic control is turned on
              M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
              M106 P2 C"Part cooling fans" S1 H1:2 T45 ; set fan 2 name and value. Thermostatic control is turned off
              M563 P0 S"Hotend 0" D0 H2 F2 ; define tool 0
              M563 P1 S"Hotend 1" D1 H1 F2 ; define tool 1
              G10 P1 X23.2 Y0 Z0 ; set tool 1 axis offsets
              ; Custom settings
              m552 s1
                Ian Miller
                Do you think these motors would be good?
                https://www.amazon.com/RTELLIGENT-Stepper-Bipolar-42x42x38mm-42A02C-Dupont/dp/B0817T5SRH/ref=sr_1_17?dchild=1&keywords=42x42x40%2Bmm%2Bnema%2Bmotor&qid=1609188975&sr=8-17&th=1
                • Vetiundefined
                  Veti
                  stepper online sells good steppers.
                  they are both used in the blv design.
                  https://www.blvprojects.com/blv-mgn-cube-3d-printer
                  and the voron 2.4
                  https://vorondesign.com/sourcing_guide?model=V2.4
                  your thermistor config is wrong. find the correct beta value in your thermistor documentation.
                    Phaedrux Moderator @Ian Miller
                    Those would be more suitable, yes. But it's hard to say what you really get from amazon and below.
                    It can help to try and understand what kinds of speeds and accelerations you hope to attain and how much mass you're going to be moving around. This would also be a good time to learn how stepper motors work. A little bit of knowledge now will go a long way to avoiding disappointment and frustrations later. Though that's a good way to learn too.
                    Ian Millerundefined 1 Reply Last reply Reply Quote 0
                      A Former User @Ian Miller
                      if the link from Veti is the same motors then they have a very high inductance, which will severely limit the speed you can operate at with a 12v supply, and this becomes a bigger problem when you have two in series on the Z driver .. which explains the error "motor phase A may be disconnected"
                      You'd probably want to take Phaedrux's advice and concider replacing them, but you could lower the current a little and/or increase the 12v supply (but that might create issues with heaters) and also reduce the speed, jerk and acceleration to try to make them work.
                        Ian Miller @Phaedrux
                        @Phaedrux since they are driving leadscrews that are holding a gantry that is about 3 pounds they need to be relatively strong but don't need to be extremely fast. I will pick up some new motors from stepperonline. Thanks for all your help guys.
                          Ian Miller
                          I picked up the new steppers and wired them up to the board. When I try to run them they just seem to be vibrating whether under load or not. When I use the provided jst connectors and run the motor there is nothing at all but when I use the setup for the previous motors they just vibrate. I'm pretty sure this is a wring issue but I'm not exactly sure what it is. I have them set to 1.5 amps witch is their rated current and they are wired in parallel to a single set of pins.
                            A Former User
                            maybe this helps?
                            https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Identifying_the_stepper_motor_phases
                              Ian Miller
                              I checked using a multimeter that the pins on the motor were ABAB and wired to the board as AABB. But I'm getting no response whatsoever from the motor. I have tested at both 0.8 and 1.5 amps and also I am running just a single motor to test with no load. The motor doesn't even activate and can be easily turned by hand.
                              When the motor was vibrating and also not keeping its position while idle, it was wired ABAB on the board.
                                A Former User
                                Are you getting any errors from the Duet after wiring them correctly? unfortunately incorrectly wiring can potentially destroy the drivers.
                                  Can you post the results of M122 after trying to move the motor?
                                  Do you get any errors in the console?
                                    @Phaedrux no errors in the console
                                    m122
                                    RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03beta3 running on Duet WiFi 1.02 or later
                                    Board ID: 0JD0M-9P61A-J8PSJ-6J9F6-3S06R-KUQ2S
                                    Used output buffers: 1 of 20 (17 max)
                                    Static ram: 25632
                                    Dynamic ram: 93800 of which 0 recycled
                                    Exception stack ram used: 412
                                    Never used ram: 11228
                                    Tasks: NETWORK(ready,652) HEAT(blocked,1236) MAIN(running,3816) IDLE(ready,196)
                                    Owned mutexes:
                                    Last reset 00:01:10 ago, cause: software
                                    Last software reset time unknown, reason: User, spinning module GCodes, available RAM 11264 bytes (slot 3)
                                    Error status: 0
                                    Free file entries: 10
                                    SD card longest block write time: 89.5ms, max retries 0
                                    MCU temperature: min 34.9, current 35.2, max 35.4
                                    Supply voltage: min 12.0, current 12.1, max 12.2, under voltage events: 0, over voltage events: 0, power good: yes
                                    Driver 0: standstill, SG min/max 421/873
                                    Driver 2: standstill, SG min/max 0/5
                                    Cache data hit count 244424298
                                    Slowest loop: 2.08ms; fastest: 0.08ms
                                    I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
                                    Hiccups: 0, FreeDm: 169, MinFreeDm: 168, MaxWait: 64222ms
                                    Bed compensation in use: none
                                    === MainDDARing ===
                                    Scheduled moves: 5, completed moves: 5, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
                                    === AuxDDARing ===
                                    Segments left: 0, aux move: no
                                    Movement lock held by null
                                    http is idle in state(s) 0
                                    telnet is idle in state(s) 0
                                    file is idle in state(s) 0
                                    serial is idle in state(s) 0
                                    aux is idle in state(s) 0
                                    daemon is idle in state(s) 0
                                    queue is idle in state(s) 0
                                    Code queue is empty.
                                      Ian Miller @A Former User
                                      @bearer is there a certain reason that that would occur? also how does it destroy the drivers?
                                        the reason is that you effectively end up wiring the high side of one h-bridge in the driver to the low side of the other h-bridge effectively a dead short on the output and that can result in a short circuit current that causes the mosfet that makes up the h-bridge to fail.
                                        another common cause for failed drivers are connecting or disconnecting motors with the power on.
                                        however, hopefully its just a config issue.
                                          @bearer If it were a driver issue would there be any ways to know, like does it look like other blown out chips?
                                            There might be some visible damage on the driver, but not necessarily.
                                            Best option would be to use the process of elimination. Ensure your motor phases are paired correctly and connect the motor to one of the other drivers and see if it works there. If it does, then the driver itself may have failed. If it doesn't, then it might be the motor has a problem, so try another one. Or it may mean those motors just aren't suitable.
