    Duet 3 Mini 5+ : Initial announcement
    288
    31.0k
      A Former User @lodger
      @lodger said in Duet 3 Mini 5+ : Initial announcement:
      @Thalios How can you get it in the US before we can get one in the UK...lol . How dare E3d Have a holiday at this time of year......lol
      mine has been sitting in "customs" since the 23rd and i just know it wont arrive before the 1st then they are going to try and shaft me on vat and duty as brexshit came into full play, then the fight begins.
      • jchodakowskiundefined
        jchodakowski
        Is there a board DXF available for creating a mount?
          A Former User @jchodakowski
          @jchodakowski said in Duet 3 Mini 5+ : Initial announcement:
          the dimensions should suffice
          jchodakowskiundefined Chrissundefined jbarrosundefined 4 Replies Last reply Reply Quote 1
            jchodakowski @A Former User
            @CaLviNx thanks!
            • Chrissundefined
              Chriss @A Former User
              I ordered my boards from overseas now. I know, that does not make any sense, but E3D are to slow for me at the moment.
              Btw: The first holder for the new kid on the block:
              https://www.thingiverse.com/thing:4699948
              Not fancy but it should do it's job.
              Cheers, Chriss
              • oc_geekundefined
                oc_geek
                Speaking of which... any news on stocks ? (please including the expansion card...what's the name for it 2+ ?)
                  A Former User
                  It would appear the mini-5+ has the same hole spacing/foot print as the Duet-2 as my mini-5+ fitted on the same mount as the Duet-2
                  oc_geekundefined 1 Reply Last reply Reply Quote 0
                  • oc_geekundefined
                    oc_geek @A Former User
                    @CaLviNx yes if you check drawings same placement
                    Chrissundefined 1 Reply Last reply Reply Quote 0
                    • Chrissundefined
                      Chriss @oc_geek
                      🙂 I got my board 2 minutes ago.
                      It traveled from the USA to good old Germany faster than the guys in the UK made it available on there stock. Strange world....
                        T3P3Tony administrators @oc_geek
                        @oc_geek Not sure why e3d did not list their stocks before the Christmas break, hopefully they will soon.
                        The mini 2+ will go into production next week.
                        Stocks of the mini 5+ will start to go out to our other resellers next week. We have not got enough from this production run for all of them
                        oc_geekundefined lodgerundefined 3 Replies Last reply Reply Quote 1
                        • Chrissundefined
                          @CaLviNx said in Duet 3 Mini 5+ : Initial announcement:
                          I'm sorry but the drawing do not seams to be accurate. I designed a holder based on the drawing and the board do not fit.
                          So I measured a hole distance :
                          Long site: 115mm
                          Sort site: 92mm
                          The drawing says:
                          Long site: 115mm
                          Sort site: 96mm
                          I'm sorry, but the 96 must be wrong. I measured 92mm, and the printed 96mm part is to wide that the board to not fit.
                          Cheers, Chriss
                          • Dougal1957undefined
                            Dougal1957 @Chriss
                            @Chriss check the drawing again the 96 is from the edge of the board and the holes are 4 in from that edge making 92 as per your measurements
                            Doug
                            • jbarrosundefined
                              jbarros @A Former User
                              When using an acrylic or other material to install the electronics, a PDF(or other) with accurate size that can be used as a template to print and mark the holes is of much help.
                              • Chrissundefined
                                Chriss @Dougal1957
                                @Dougal1957
                                Wow.. you are right....
                                This is so hard... the drawing shows the distance from hole to hole on the long site. And the distance from the board "west site" to the hole center at the "east site". Wow.... they fooled me... again. 😉
                                  Overall dimensions and mounting hole positions on the Duet 3 Mini are the same as for the Duet WiFi/Ethernet. However, the motor connectors are on the opposite side of the board compared to Duet 2.
                                  • oc_geekundefined
                                    oc_geek @T3P3Tony
                                    @T3P3Tony Do you confirm the official name of the expansion is going to be "Mini 2+" cse noone of the resellers know about its existance... thanks
                                      A Former User @Chriss
                                      @Chriss said in Duet 3 Mini 5+ : Initial announcement:
                                      @Dougal1957
                                      measure twice, cut once.............
                                        @oc_geek yes it is. and we have not got any to send to the resellers, and no pictures to setup the product listing yet so thats why they are not setup for it yet.
                                        • lodgerundefined
                                          lodger @T3P3Tony
                                          @T3P3Tony
                                          Will you be listing it on your site. I perfer to buy from yourselfs ... E3D already get to much money out of me ...LOL
                                            @lodger TBC at this point when we reopen retail sales.
