    Printing
    Example setups and prints
    700
    • Dodgerundefined
      Dodger
      This is driving me mad!
      Attached my config file
      Why am I using pronterface
      a) Because I have always used it since my first printer (an Ormerod 2) bits of which were used to build My Grandfathers 3D Printer
      b)I cannot get the web controller. With USB only connected (no power) and the printer connected both blue lights are on the duet. but try as I may I cannot open the web page
      confConfiguration file for Duet 0.6 (firmware version 1.21)
      ; generated by RepRapFirmware Configuration Tool v3.1.10 on Sun Dec 20 2020 16:32:00 GMT+0000 (Greenwich Mean Time)
      M550 P"Mad Grandfathers 3d Printer" ; set printer name
      M540 PBE:EF:DE:AD:FE:ED ; set custom MAC address
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M552 S1
      G92 X100 Y100 Z100
      M569 P3 S0 ; physical drive 3 goes forwards
      M92 X87.49 Y87.49 Z4000.00 E420.00 ; set steps per mm
      M201 X500.00 Y500.00 Z250.00 E250.00 ; set accelerations (mm/s^2)
      M906 X800 Y1000 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X200 Y200 Z200 S0 ; set axis maxima
      M574 Y1 X1 S1 ; set active high endstops
      M558 P1 H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
      G31 P500 X0 Y0 Z3 ; set Z probe trigger value, offset and trigger height
      M557 X15:195 Y15:195 S20 ; define mesh grid
      M305 P0 T10000 B3988 R4700
      M143 H0 S100
      T0 ; Tools
      ig.g
      • Vetiundefined
        Veti
        @Dodger said in Printing:
        what duet do you have?
        apparently you selected duet 1 in the config tool, yet you write you have a duet 2.
        what firmware version are you running?
        if you are starting new and you have a duet 2 you should update to firmware 3.11.
        see https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware
        do not forget to update the wifi firmware and the duet web control.
        easiest is to update using bossa if you have a very old version.
        then go through these steps.
        https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7
        Dodgerundefined 1 Reply Last reply Reply Quote 0
          Phaedrux Moderator @Dodger
          How are you trying to connect?
          What IP address does the Duet have?
          As this is a wifi, how have you added the SSID and password?
          • Dodgerundefined
            Dodger @Veti
            @Veti the config may say it is for a duet o.6 but has been heavily modified. My firmware is 2.05
            • Dodgerundefined
              Dodger @Phaedrux
              @Phaedrux Long, rather weary, story. I thought I had fried my ethernet duet 2 so bought a wifi one. After a while I got a config file that appeared to do what it should so put it back in the ethernet board. I connected through YAT and for the first time got an IP address, I have now connected direct to my router and the USB cable and the web console actually opens but there is an error message. "Failed to get file list"" directory 0:/macros not found
              • Vetiundefined
                Veti @Dodger
                directory 0:/macros
                just create that folder on the sd card
                see
                https://duet3d.dozuki.com/Wiki/SD_Card
                  When you have a USB terminal up please send M122 and M98 P"config.g" and post the results.
                  What do you have on your SD card? It sounds like you're missing the directory structure. Are you perhaps also missing the web interface files as well?
                  https://duet3d.dozuki.com/Wiki/SD_Card#Section_Creating_the_file_structure
                  • Dodgerundefined
                    Dodger @Phaedrux
                    @Phaedrux Yes I am probably missing something . I have inputted 'Duet2CombinedFirmware.bin' and confirmed that I have 2.05.1 entered. I have also loaded 'iap4e.bin'but I think need a web control input.
                    I suspect that my sys file is in a bit of a mess so will start from the beginning
                    • Dodgerundefined
                      Dodger @Veti
                      @Veti OK so I create a folder but where do the files for that folder come from,?
                      • Vetiundefined
                        Veti @Dodger
                        @Dodger
                        thats where your macros go
                        • Dodgerundefined
                          Dodger @Veti
                          @Veti thanks that seems to have done it
