    Triple Z Axis G32 Bed Traming
    2.1k
      A Former User @jay_s_uk
      @jay_s_uk said in Triple Z Axis G32 Bed Traming:
      @fcwilt or the kinematic mount positions
      That's a more accurate explanation
      @fcwilt some printers the lead screws only job is to move the axis, and they can also have pivots used to eliminate over constraining that axis
      • Turricannundefined
        Turricann @fcwilt
        @fcwilt I understand what you mean, i had taken it as the M671 command needed to match the commands in the bed.g
        ie the probe points but i have now updated the potions to match the actual lead screw position leveling seem to work better now but i need to run the leveling process twice as the first run did not adjust the offset correctly.
        output from the console.
        G32
        Leadscrew adjustments made: 1.999 1.920 3.028, points used 3, (mean, deviation) before (-0.548, 3.417) after (-0.000, 0.000)
        Leadscrew adjustments made: 0.057 -0.082 1.163, points used 3, (mean, deviation) before (-2.838, 3.845) after (0.000, 0.000)
        1/2/2021, 5:09:05 PM G32
        Leadscrew adjustments made: 1.166 1.972 2.849, points used 3, (mean, deviation) before (-0.292, 2.602) after (-0.000, 0.000)
        Leadscrew adjustments made: 0.115 -0.163 0.823, points used 3, (mean, deviation) before (-2.285, 3.068) after (0.000, 0.000)
        • fcwiltundefined
          fcwilt @A Former User
          @CaLviNx said in Triple Z Axis G32 Bed Traming:
          That was not the point I was trying to make.
          My question dealt with how it was possible to probe the lead screw position (or the mount position).
          And as we now see the OP misunderstood what the parameters to M671 should have been.
          • fcwiltundefined
            fcwilt @Turricann
            @Turricann said in Triple Z Axis G32 Bed Traming:
            You still seem to be having a problem. On my printer two runs are always enough to get it spot on.
            Does a single G30 to set the Z=0 datum work as expected? If you move to Z=0 is the nozzle touching (or nearly so) the bed?
            Turricannundefined 1 Reply Last reply Reply Quote 0
              Phaedrux Moderator @Turricann
              G1 X0 Y0 F6000 ; go to first probe point
              G30 ; use probe to find Z 0
              The position of the probe for the G30 should match between homez and homeall (and any other place you are setting Z0)
                Turricann @fcwilt
                @fcwilt
                Doing a single G30 probes the bed @X0, Y0(Bed center), Doing a G1 Z0 the nozzle moves so its touching the bed.
                  Turricann @Phaedrux
                  @Phaedrux I see i had not set the probe offset, however the bed is still not tramming correctly any other thoughts ?
                  • fcwiltundefined
                    fcwilt @Turricann
                    @fcwilt
                    Seems like your Z probe is configured and working correctly.
                    Perhaps the following may help:
                    I don't do multiple passes in my bed.g - just one. And I also end the bed.g processing with setting the Z=0 datum at the center of the bed.
                    I obtain multiple passes by ending my homez.g file with two G32 commands.
                      Turricann @fcwilt
                      @fcwilt
                      I have changed the M671 leadscrew Positions from where the leadscrews are to the pivot points under the bed as in @CaLviNx config.g example.
                      The bed leveling now seems more consistant,
                      1/2/2021, 9:51:43 PM G32
                      Leadscrew adjustments made: 0.291 0.320 0.311, points used 3, (mean, deviation) before (0.307, 0.010) after (-0.000, 0.000)
                      1/2/2021, 9:50:43 PM G32
                      Leadscrew adjustments made: 0.307 0.299 0.307, points used 3, (mean, deviation) before (0.305, 0.004) after (-0.000, 0.000)
                      1/2/2021, 9:49:43 PM G32
                      Leadscrew adjustments made: 0.308 0.294 0.297, points used 3, (mean, deviation) before (0.300, 0.005) after (-0.000, 0.000)
                      fcwiltundefined 2 Replies Last reply Reply Quote 0
                      • fcwiltundefined
                        fcwilt @Turricann
                        @fcwilt
                        Did you try adding the G30 in your bed.g file to set the Z=0 datum after the leveling phase?
                        Your bed seems level but has a Z offset.
                        • fcwiltundefined
                          fcwilt @Turricann
                          @dc42 - is that the correct way to set M671 for printers with kinematic mounts?
                          A Former User? jay_s_ukundefined 2 Replies Last reply Reply Quote 0
                            A Former User @fcwilt
                            @fcwilt said in Triple Z Axis G32 Bed Traming:
                            Sigh, this is yet another reason I add a disclaimer....
                            1 Reply Last reply Reply Quote -1
                              jay_s_uk @fcwilt
                              @fcwilt I would've thought gloomyandys answer was sufficient
                              • fcwiltundefined
                                fcwilt @jay_s_uk
                                Why?
                                dc42 did the code - who knows if these special cases were taken into account or if it even matters.
                                Even though I have kinetic mounts specifying the position of the leadscrews works fine.
                                  Phaedrux Moderator @fcwilt
                                  It's an approximation of location at any rate, since you're trying to approach zero, the farther off your estimate is, the longer it takes to reach. It says the position of lead screws, but that's just an assumption that most people will have printers with lead screws and won't have specifically designed pivot points, in which case, the lead screw is the natural pivot point. So technically, M671 is defining the pivot point, but in practice that's most commonly going to be a lead screw, and even more practically, it doesn't matter so much as long as you're "pretty close".
                                  • fcwiltundefined
                                    fcwilt @Phaedrux
                                    @Phaedrux said in Triple Z Axis G32 Bed Traming:
                                    It's an approximation of location at any rate...
                                    Thanks for the feedback. It is consistent with my experiences.
