    Chiron+Duet3+BlTouch
    2.3k
    • razrudyundefined
      razrudy
      I am trying to set the Z offset but apparently I have a problem and not sure if it's a mechanic one or I am missing something
      Every time I run G30 S-1 in the same spot I get wrong values...always decreasing with 0.005 or something like this...
      I am using
      G30
      ;Manually lower the nozzle close the build plate
      G92 Z0
      G1 Z10
      G30 S-1
      And after each move I get a value with 0.005-0.002 difference
      02/01/2021, 16:34:26: G1 XY0
      02/01/2021, 16:36:57: G30
      02/01/2021, 16:43:21: G92 Z0
      02/01/2021, 16:43:46: G30 S-1: Stopped at height 1.435 mm
      02/01/2021, 16:43:58: G1 Z10
      02/01/2021, 16:44:06: G30 S-1: Stopped at height 1.433 mm
      02/01/2021, 16:44:10: G1 Z10
      02/01/2021, 16:44:19: G30 S-1: Stopped at height 1.430 mm
      02/01/2021, 16:44:24: G1 Z10
      02/01/2021, 16:44:32: G30 S-1: Stopped at height 1.425 mm
      02/01/2021, 16:44:39: G1 Z10
      02/01/2021, 16:44:48: G30 S-1: Stopped at height 1.423 mm
      02/01/2021, 16:44:53: G1 Z10
      02/01/2021, 16:45:02: G30 S-1: Stopped at height 1.415 mm
      02/01/2021, 16:45:09: G1 Z10
      I also have problems with mesh bed compensation...it doesn't compensate on the left side. 3/4 of the build plate is coming up nice but the left side the nozzle is always low.
      My build plate is crap but until I decide which one to get and replace it I am wondering why the mesh is not applied on the left side.
      Maybe because the gantry doesn't properly level with the build plate? Or because the probe is at X42 offset and can't get to X0-X5 for probing?
      What's the right order for levelling all this?
      I am running 4 points G32 without gantry levelling until I get a good level bed and after that I run
      G29 X42:400 Y0:400 P5 and M374( map save)
      Load map at the start with M375
        Phaedrux Moderator @razrudy
        @razrudy said in Chiron+Duet3+BlTouch:
        M558 P9 C"^io5.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds G31 P500 X41.13 Y2.69 Z1.543 ; set Z probe trigger value, offset and trigger height
        You can try improving the repeatability of the BLTouch by changing your M558 and G31 as follows
        M558 P9 C"^io5.in" H5 F60 T6000 R0.2 A10
        G31 P25 X41.13 Y2.69 Z1.543
        See if that helps.
        • razrudyundefined
          razrudy
          So the new BLT settings didn't help. I am still getting differences at every single probe and maybe once in 7-8 I get twice the same reading.
          Maybe this happens because I have flexible couplers on the Z ?
          Now I am trying to figure out why my heightmap is always ~1mm up on the heightmap tab.
          No matter what I am trying I am always ending with this....what I am missing?
          I redid multiple times the z calibration using M561 , G92 Z0 , G30 S-1 and setting the new offset and always I end up with this. Maybe this also affect the mesh compensation?
          Everything is working except this mesh/leveling thing.
          ; Configuration file for Duet 3 (firmware version 3) with SBC
          ; Configuration for Chiron+Titan Aero+Volcano+BlTouch
          G21                                                        ; works in mm
          G90                                                        ; send absolute coordinates...
          M83                                                        ; ...but relative extruder moves
          M550 P"Chiron"                                             ; set printer name
          M569 P0.0 S1                                               ; physical drive 0.0 goes forwards X
          M569 P0.1 S0                                               ; physical drive 0.1 goes backwards Y
          M569 P0.2 S0                                               ; physical drive 0.2 goes bacwards ZL
          M569 P0.3 S0                                               ; physical drive 0.3 goes backwards ZR
          M569 P0.4 S1 D2                                            ; physical drive 0.4 goes forwards E
          M584 X0 Y1 Z2:3 E4                                         ; set drive mapping
          M350 X16 Y16 Z16 E16 I1                                    ; configure microstepping with interpolation
          M92  X80 Y100 Z400 E407.5                                  ; set steps per mm
          M566 X1200 Y1200 Z12 E120                                  ; set maximum instantaneous speed changes (mm/min)
          M203 X9000 Y9000 Z180 E1200                                ; set maximum speeds (mm/min)
          M201 X1000 Y800 Z250 E250                                  ; set accelerations (mm/s^2)
          M906 X1100 Y1100 Z1100 E1100 I30                           ; set motor currents (mA) and motor idle factor in per cent
          M84 S30                                                    ; Set idle timeout
          M208 X-6.0 Y-9.0 Z0 S1                                     ; set axis minima
          M208 X400 Y400 Z445 S0                                     ; set axis maxima-need to remeasure this
          M671 X-40:440 Y200:200                                     ; leadscrews position at right and left of the X axis
          M574 X1 S1 P"!io0.in"                                      ; configure active-high endstop for low end on X via pin io0.in
          M574 Y1 S1 P"!io1.in"                                      ; configure active-high endstop for low end on Y via pin io1.in
          ;M574 Z1 S1 P"io2.in+io3.in"                               ; configure active-high endstop for low end on Z via pin-for original endstop's
          M574 Z1 S2                                                 ; endstop set to z-probe
          ;Stall Detection
          ;M915 P0 S-5 F0 H200 R0                                    ; P=drive motor , S= sensitivite , H=motorstep/sec ( check home file)
          M950 S0 C"io5.out"                                         ; create servo pin 0 for BLTouch
          M558 P9 C"^io5.in" H5 F60 T6000 R0.2 A10                   ; set Z probe type to bltouch and the dive height + speeds
          G31 P500 X41.13 Y2.69 Z1.378                              ; set Z probe trigger value, offset and trigger height
          M557 X42:380 Y0:400 P3                                     ; define mesh grid
          ; Piezo Z-probe
          ;M558 P8 C"io5.in" I1 R0.4 F300 X0 Y0 Z1                   ;new piezo
          ;G31 X0 Y0 Z-0.1 P100                                      ;new piezo
          M308 S0 P"temp0" Y"thermistor" T100000 B4138               ; configure sensor 0 as thermistor on pin temp0
          M950 H0 C"out0" T0                                         ; create bed heater output on out0 and map it to sensor 0
          M307 H0 A110.3 C842.7 D1.1 S0.5 V23.8 B0                   ; disable bang-bang mode for the bed heater and set PWM limit
          M140 H0                                                    ; map heated bed to heater 0
          M143 H0 S120                                               ; set temperature limit for heater 0 to 120C
          M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8      ; configure sensor 1 as thermistor on pin temp1
          M950 H1 C"out1" T1                                         ; create nozzle heater output on out1 and map it to sensor 1
          M307 H1 A373.1 C420.1 D3.0 S0.5 V24.1 B0                   ; disable bang-bang mode for heater  and set PWM limit
          M143 H1 S285                                               ; set temperature limit for heater 1 to 285C
          M950 F0 C"out4" Q25000                                     ; create fan 0 on pin out4 and set its frequency
          M106 P0 S0 H1 T45                                          ; set fan 0 value. Thermostatic control is turned on
          M950 F1 C"out5" Q25000                                     ; create fan 1 on pin out5 and set its frequency
          M106 P1 S0 H1 T45                                          ; set fan 1 value. Thermostatic control is turned on
          M950 F2 C"out7" Q25000                                     ; create fan 2 on pin out7 and set its frequency
          M106 P2 S0 H-1                                             ; set fan 2 value. Thermostatic control is turned off
          ;M950 F3 C"out8" Q500                                      ; create fan 3 on pin out8 and set its frequency
          ;M106 P3 S0 H-1                                            ; set fan 3 value. Thermostatic control is turned off
          M563 P0 D0 H1 F0:2                                         ; define tool 0
          G10 P0 X-6.0 Y-7.0 Z0                                    ; set tool 0 axis offsets
          G10 P0 R0 S0                                               ; set initial tool 0 active and standby temperatures to 0C
          ;M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"        ; set voltage thresholds and actions to run on power loss
          M564 H0                                                  ; moving axes before/without homing
          ;M591 P1 C"io4.in" S1 D0                                   ; filament run out sensor - work in progress
          And here are the last outputs for G30 S-1
          03/01/2021, 15:13:54: G30 S-1: Stopped at height 0.068 mm
          03/01/2021, 15:14:03: G1 Z10
          03/01/2021, 15:14:21: G30 S-1: Stopped at height 0.075 mm
          03/01/2021, 15:14:24: G1 Z10
          03/01/2021, 15:14:39: G30 S-1: Stopped at height 0.070 mm
          03/01/2021, 15:14:43: G1 Z10
          03/01/2021, 15:14:59: G30 S-1: Stopped at height 0.065 mm
          03/01/2021, 15:17:59: Upload of config.g successful after 0s
          03/01/2021, 15:18:00: : Warning: Firmware reset imminent
          03/01/2021, 15:18:00: : Connection to Duet established
          03/01/2021, 15:18:00: Connection interrupted, attempting to reconnect...: DCS has been stopped
          03/01/2021, 15:18:09: Connection established
          03/01/2021, 15:21:33: : Warning: the height map has a substantial Z offset. Suggest use Z-probe to establish Z=0 datum, then re-probe the mesh.
          03/01/2021, 15:21:33: G29: 9 points probed, min error 0.506, max error 0.940, mean 0.783, deviation 0.134
          Height map saved to file heightmap.csv
          03/01/2021, 15:38:52: G30
          03/01/2021, 15:41:22: G92 Z0
          03/01/2021, 15:41:40: G1 Z10
          03/01/2021, 15:41:55: G30 S-1: Stopped at height 1.668 mm
          03/01/2021, 15:41:58: G1 Z10
          03/01/2021, 15:42:12: G30 S-1: Stopped at height 1.665 mm
          03/01/2021, 15:42:14: G1 Z10
          03/01/2021, 15:42:29: G30 S-1: Stopped at height 1.663 mm
          03/01/2021, 15:42:41: G1 Z10
          03/01/2021, 15:42:54: G30 S-1: Stopped at height 1.670 mm
          03/01/2021, 15:43:02: G1 Z10
          03/01/2021, 15:43:20: G30 S-1: Stopped at height 1.668 mm
          03/01/2021, 15:44:05: Upload of config.g successful after 0s
          03/01/2021, 15:44:06: : Warning: Firmware reset imminent
          03/01/2021, 15:44:07: : Connection to Duet established
          03/01/2021, 15:44:07: Connection interrupted, attempting to reconnect...: DCS has been stopped
          03/01/2021, 15:44:15: Connection established
          03/01/2021, 15:50:35: : Warning: the height map has a substantial Z offset. Suggest use Z-probe to establish Z=0 datum, then re-probe the mesh.
          03/01/2021, 15:50:35: G29: 9 points probed, min error 0.550, max error 1.164, mean 0.872, deviation 0.180
          03/01/2021, 18:13:07: G30
          03/01/2021, 18:14:56: G92 Z0
          03/01/2021, 18:15:06: G1 Z10
          03/01/2021, 18:15:23: G30 S-1: Stopped at height -1.138 mm
          03/01/2021, 18:15:26: G1 Z10
          03/01/2021, 18:15:43: G30 S-1: Stopped at height -1.140 mm
          03/01/2021, 18:15:46: G1 Z10
          03/01/2021, 18:16:05: G30 S-1: Stopped at height -1.145 mm
          03/01/2021, 18:16:36: G1 Z10
          03/01/2021, 18:16:52: G30 S-1: Stopped at height -1.133 mm
          03/01/2021, 18:16:57: G1 Z10
          03/01/2021, 18:17:24: G30 S-1: Stopped at height -1.143 mm
          03/01/2021, 19:26:40: M561
          03/01/2021, 19:27:14: G92 Z0
          03/01/2021, 19:28:08: G30 S-1: Stopped at height 1.395 mm
          03/01/2021, 19:28:13: G1 Z5
          03/01/2021, 19:28:23: G1 Z10
          03/01/2021, 19:28:36: G30 S-1: Stopped at height 1.395 mm
          03/01/2021, 19:28:41: G1 Z10
          03/01/2021, 19:28:59: G30 S-1: Stopped at height 1.388 mm
          03/01/2021, 19:29:13: G1 Z10
          03/01/2021, 19:29:16: G1 Z10
          03/01/2021, 19:29:18: G1 Z10
          03/01/2021, 19:29:35: G30 S-1: Stopped at height 1.388 mm
          03/01/2021, 19:29:38: G1 Z10
          03/01/2021, 19:30:01: G30 S-1: Stopped at height 1.385 mm
          03/01/2021, 19:30:14: G1 Z10
          03/01/2021, 19:30:27: G1 Z10
          03/01/2021, 19:30:39: G30 S-1: Stopped at height 1.375 mm
          03/01/2021, 19:30:49: G1 Z10
          03/01/2021, 19:31:16: G30 S-1: Stopped at height 1.372 mm
          03/01/2021, 19:32:07: G1 Z10
          03/01/2021, 19:32:52: G30 S-1: Stopped at height 1.378 mm
          03/01/2021, 19:35:32: Upload of config.g successful after 0s
          03/01/2021, 19:35:34: : Warning: Firmware reset imminent
          03/01/2021, 19:35:34: : Connection to Duet established
          03/01/2021, 19:35:34: Connection interrupted, attempting to reconnect...: DCS has been stopped
          03/01/2021, 19:35:43: Connection established
          03/01/2021, 19:39:46: : Warning: the height map has a substantial Z offset. Suggest use Z-probe to establish Z=0 datum, then re-probe the mesh.
          03/01/2021, 19:39:47: G29: 9 points probed, min error 0.474, max error 1.061, mean 0.821, deviation 0.175
          I am out of ideas and most likely it's just a small mistake somewhere but can't figure out where the problem is
          • stuartofmtundefined
            stuartofmt
            I had the same heightmap offset problem a couple of days ago. The documentation is a bit ambiguous. I seem to have solved the problem by doing this in the calibration run (I use a macro).
            ; Heat Bed and Hotend - Home and Calibrate
            T0				;make sure the tool is selected
            G90 			; use absolute coordinates
            M83 			; extruder relative mode
            M117 "Setting Calibration Temperatures"
            <snip>
            M290 R0 S0		;remove any babysteps
            M561            ; reset any bed compensation
            M117 "Performing Mesh Calibration"
            G28             ; must be homed first
            G30				; Perform a single probe to establish Z=0 (should already be at center because of home)
            G29 S0			; perform mesh calibration save and load
            I did a reboot at this point but am not sure if it's at all required.
            Then this at the start of the print job
            T0             ; turn on the tool
            M561           ; Remove any Bed Compensation
            <snip>
            G28 ; home all
            G30  ; probe bed just to make sure
            G29 S1  ; enable mesh leveling
            <snip>
            I suspect there may be redundancy in my codes but .....
            razrudyundefined 1 Reply Last reply Reply Quote 0
            • razrudyundefined
              razrudy
              That's something I was thinking that there is some residue code that can't be seen on files and messing everything. think I will just save the config and make a new sd card and see how the things are working. ...after I will try your code.
                That could be part of it.
                @Phaedrux said in Chiron+Duet3+BlTouch:
                You forgot to change it to G31 P25
                This would indicate that you're not setting Z0 correctly before running G29 to create a mesh.
                When you're doing G92 Z0 you've moved the nozzle to touch the bed first, right?
                The inconsistency could certainly be from movement in the Z axis couplers.
                • razrudyundefined
                  razrudy @stuartofmt
                  @stuartofmt said in Chiron+Duet3+BlTouch:
                  <snip>
                  @stuartofmt this also worked for me..at least visual is now back in the right place...I will run a print and see how it goes. And now I have the home point at Z0.0
                  • razrudyundefined
                    razrudy @Phaedrux
                    😱 how did I miss that?
                    I am following the guide on dozuki
                    Cancel any currently active mesh compensation with M561
                    Use the X and Y jog buttons to position the nozzle over the centre of the bed
                    Jog the nozzle down until it is just touching the bed or just gripping a sheet of paper. If the firmware doesn't let you jog it down far enough, send M564 S0 to disable axis limits.
                    Once you have the nozzle touching the bed, send command G92 Z0 to tell the firmware that the head is at Z=0
                    Jog the head up by 5 to 10mm
                    Send command G30 S-1. The nozzle will descend or the bed rise until the probe triggers and the Z height at which the probe stopped will be reported. If you are using a nozzle-contact Z probe, the trigger height will be slightly negative. For any other type of Z probe where the probe triggers before the nozzle contacts the bed, it will be positive.
                    Repeat from step 5 two or three times to make sure that the trigger height is consistent.
                    In Duet Web Control, go to Settings -> System Editor and edit the config.g file. Set the Z parameter in the G31 command to the trigger height that was reported. Save the file.
                    Open config-override.g and check that there are no G31 commands in it. If you find any, delete those lines and save the file.
                    To apply the new trigger height, restart the Duet by sending M999 or pressing Emergency Stop.
                    The only difference is that I point the probe to the middle of the bed not the nozzle.
                    M561
                    Probe pin to centre of the bed
                    Lower nozzle to touch the bed( paper method)
                    G92 Z0
                    G1 Z10
                    G30 S-1
                      G28 ; must be homed first G30 ; Perform a single probe to establish Z=0 (should already be at center because of home)
                      This is a pretty ambiguous combination because we can't see what the homeall is doing to home the Z axis, and we have no idea what XY location the G30 is being done in.
                      The important thing to remember is that the Z0 position is set in the same XY position whenever you set it. Your homeall, homez, and any other time you use G30 must be in the same position before and after G29 is used to create or load the height map. This is because the shape of the bed may give you a different z height depending on the XY location.
                      stuartofmtundefined 1 Reply Last reply Reply Quote 0
                        stuartofmt @Phaedrux
                        @Phaedrux
                        In my case homeall.g looks like this (homez sets to the same position) ... But I think you also answered one of the ambiguities in the documentation i.e. what coordinate (XY) is the bed height relative to. Seems the answer is "Wherever you set your Z-home"? EDIT: which needs be the same as your Z=0 datum.?
                        G91 ; relative mode
                        G0 H2 Z10 F200 ; raise head above Z probe trigger height
                        G0 H1 X-240 Y-240 F3000 ; move up to 240mm in the -X and -Y directions until the homing switches are triggered
                        G0 H2 X5 Y5 F600; move slowly 5mm in +X and +Y directions
                        G0 H1 X-10 Y-10 ; move up to 10mm in the -X and -Y directions until the homing switches are triggered
                        G90 ; back to absolute mode
                        G1 X110 Y110 F2000 ; put head over the center of the bed, or wherever you want to probe
                        G30 ; lower head, stop when probe triggered and set Z to trigger height
                        • razrudyundefined
                          razrudy
                          Yes I made sure that every mesh starts from the same point....
                          Looking at the DWC now before I run this macro my home position was X-12 and Y-14 instead of the real X-6 Y-7 so I had something doubled in my steps. Now everything is normal only by running that macro.
                          I suspect there was something related to baby steps but I never went more then 3mm up/down during printing and it's just strange how it was exactly double compared with the original values.
                          Also tried to manually delete the heightmap , any mesh level maps I had saved and using G29 S2 with no result
                          Now I am trying to figure out how I can do a mesh level starting from the centre of the bed instead of the home position because my centre bed is the lowest point.
                          G28
                          M98 P"move_probe_center _bed.g"
                          G29 S0
                          will work or how it will be the best?
                          Making specific points for probing on the bed.g will work?
                          Thinking that the lowest point will be under Z0 and I may not get the nozzle down enough...or it will compensate below Z0?
                          • razrudyundefined
                            razrudy
                            I am back on the same situation....tried to do a print and there was no mesh compensation applied. after I cancelled the print I did a G29 and my height map is back "in air" with ~1mm......time to reset everything and start from scratch
                              Maybe reshare all your gcode files including start gcode
                              • razrudyundefined
                                razrudy
                                ........and now my home position is again at Z-12 Y-16 instead of X-6 Y-7 but visual is where it should be.
                                I have no idea why this is happening......I will keep the same config for couple more days maybe there is a bug or something.......
                                ; bed.g
                                G29  ; probe the bed and enable compensation
                                ;G30 P0 X42 Y0 Z-99999 ; probe near a leadscrew
                                ;G30 P1 X358 Y0 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
                                ; config-override.g file generated in response to M500 at 2020-12-31 13:29
                                ;nothing on here
                                ; Configuration for Chiron+Titan Aero+Volcano+BlTouch+ SBC Pi4
                                G21                                                        ; works in mm
                                M208 X-6.0 Y-9.0 Z-20 S1                                   ; set axis minima
                                ;Stall Detection
                                G31 P25 X41.13 Y2.69 Z0                                    ; set Z probe trigger value, offset and trigger height
                                ; Piezo Z-probe
                                G10 P0 X0 Y0 Z0                                    ; set tool 0 axis offsets
                                ; homeall.g
                                ; called to home all axes
                                G91                    ; relative positioning
                                G1 H2 Z10 F6000        ; lift Z 10mm relative to current positio
                                M280 P0 S90            ; retract probe pin , just in case it is deployed after emergency stop
                                ; first move/home Y axis
                                G1 H1 Y-415 F1800        ; move quickly to Y axis endstops and stop there
                                P4 P500                  ; wait 500ms
                                G1 Y5 F6000              ; go back 5mm
                                G4 P500                  ; wait 500ms
                                G1 H1 Y-415 F360         ; move slowly to Y axis endstop once more (second pass)
                                ;second move/home X axis
                                G1 H1 X-405 F1800       ; move quickly to X axis endstops and stop there
                                G1 X5 F1800             ; go back 5mm
                                G1 H1 X-405 F360        ; move slowly to X axis endstop once more (second pass)
                                ;third move/home Z axis
                                G30 H1 Z-455 F360       ; move Z down stopping at the endstop -for BLT
                                ;G1 H1 Z-455 F360       ; move Z down stopping at the endstop -for original enstops
                                ;G1 Z5 F100             ; lift Z relative to current position 5mm
                                G90                     ; absolute positioning
                                ;G92 Z5                 ; set Z position to axis minimum (you may want to adjust this)
                                ; homex.g
                                ;For stall detection/sensorless homing
                                ;M201 X500         ; lower motor ascceleration to 500mm/m
                                ;G91               ; relative positioning
                                ;G1 H2 X0.5 F10000 ; energise motor
                                ;M400              ; wait to make sure every command has been executed
                                ;G4 P100           ; wait 1ms
                                ;M913 X50          ; reduce motor current to half
                                G1 Z5 F6000        ; lift Z relative to current position
                                G1 H1 X-405 F1800  ; move quickly to X axis endstop and stop there (first pass)
                                G1 H2 Z-5 F6000    ; lower Z again
                                ;M400
                                ;G4 P100
                                ;M913 X100         ; motor current back to initial
                                ;M210 X1000        ; motor acceleration back to initial
                                ; homey.g
                                G1 H1 Y-415 F1800  ; move quickly to Y axis endstop and stop there (first pass)
                                G1 H2 Y5 F6000     ; go back a few mm
                                ; homez.g
                                G1 H2 Z5 F6000       ; lift Z relative to current position
                                G30 H1 Z-455 F1800   ; move Z down until the endstop is triggered-for BLT
                                ;G1 H1 Z-455 F1800    ; move Z down until the endstop is triggered - for original endstops
                                ;G4 P500              ; wait 500ms
                                ;G1 Z5 F100           ; lift Z 5mm relative to current position
                                ;G90                  ; absolute positioning
                                ;G92 Z5              ; set Z position to axis minimum (you may want to adjust this) +5mm
                                ;M564 H0                                                  ; moving axes before/without homing
                                ; deployprobe.g
                                ; called to deploy a physical Z probe
                                ; generated by RepRapFirmware Configuration Tool v3.1.10 on Wed Dec 16 2020 15:18:40 GMT+0000 (Greenwich Mean Time)
                                M280 P0 S10 ; deploy BLTouch
                                ; retractprobe.g
                                ; called to retract a physical Z probe
                                M280 P0 S90 ; retract BLTouch
                                M98 P"homeall.g"                ; run home all command
                                G30 P0 X42 Y0 Z-99999           ; probe near a leadscrew , the left one
                                G30 P1 X400 Y0 Z-99999 S2       ; probe near oposite leadscrew and calibrate 2 motors
                                ; stop.g
                                ; called when M0 (Stop) is run (e.g. when a print from SD card is cancelled)
                                ; generated by RepRapFirmware Configuration Tool v3.1.10 on Wed Dec 16 2020 15:18:41 GMT+0000 (Greenwich Mean Time)
                                M83               ; relative extruder moves
                                G1 E-10 F3600     ; retract 10mm of filament
                                G1 Z5 F360        ; lift Z by 5mm
                                G1 X0 Y405 F6000  ; go to X=0 Y=405
                                Hope I didn't forget something
                                  There are some problems in there. I'll reply again when I'm back at my PC later.
                                    It's a bit hard to tell from your copy and paste which files are which. It looks like the homing files got pasted into the config.g portion? And that all might be in the middle of bed.g?
                                    Where is that from?
                                    In homeall.g don't use M280 P0 S90 to retract the pin. Use M402 instead. That way the firmware is made aware of the pin retraction.
                                    Also in homeall and homez, G30 H1 Z-455 F360 is not a valid way to use G30. It's just G30 by itself. The speed is set by the M558 command in your config.g. The H1 etc etc will be ignored probably.
                                    • razrudyundefined
                                      razrudy @Phaedrux
                                      Where is that from?
                                      This is just a macro I am using to home all and level the gantry. My plan is/was to use this and after that to run G32 or just a single probe and load height map. I level the bed with the stock endstops because I know they are in the same spot always and to make sure the things are as square as possible. After I am doing this I disable the stock end stops and use only the BLT......because the stock endstops are about 7-9mm above bed surface...still trying to figure out how can I use them always and use the BLT only for mesh compensation
                                      Ok I will change this.....
                                      Yes everything is ignored after G30....just copied the normal end stops and changed G1 to G30
                                      bed.g
                                      config.g
                                      config-override.g
                                      deployprobe.g
                                      homeall.g
                                      homex.g
                                      homey.g
                                      homez.g
                                      level_gantry.g
                                      pause.g
                                      resume.g
                                      retractprobe.g
                                      sleep.g stop.g
                                        A Former User
                                        This post is deleted!
                                          In homex: The G1 Z5 should have H2, otherwise it will complain if Z isn't homed first. Also remove the G90 and second G91. You just need to be in relative mode for those moves. Also, if you're using stall detection on X and Y, it's pointless to do a back off and second homing pass. A single fast homing pass is all you need.
                                          ;homex.g
                                          In homeY the same thing goes for the G1 Z5 move needing H2. And the removal of the G90 and second G91 for the same reason. Also here if you are using stall detection, only ne pass is needed. If you are using an endstop switch, then the back off move should NOT have H2.
                                          ;homey.g
                                          In your homeall and homez you should be positioning your probe at the center of the bed before sending G30.
                                          You don't need all of the G4 pause commands in there either.
                                          Your bed.g and level gantry macro could be the same thing. And I would leave G29 as a separate command rather than using it in G32 (bed.g)
                                          ; bed.g
                                          G28 ; home all
                                          G28 Z ; home z again to reset Z0
                                          ; homeall.g
                                          M402 ; retrack probe in case it's deployed
                                          G1 X150 Y150			; move probe to bed center
                                          G30        				; move Z down stopping at the endstop -for BLT
                                          G1 X0 Y0 Z10			; move to parking position
                                          ; homex.g
                                          ; homey.g
                                          G1 Y5 F6000     ; go back a few mm
                                          ; homez.g
                                          G1 X150 Y150 		; position probe at center of the bed
                                          G30    ; move Z down until the endstop is triggered-for BLT
                                          I cleaned up your files a bit.
                                          • razrudyundefined
                                            razrudy
                                            Thanks....I will upload the new files and see how it's working. I will do 2 separate sd cards....I will use them in a fresh install and on the old one . Just testing to see if this will fix the map height thing.
