    Did I fry my new board....
    1.9k
    • Vetiundefined
      Veti
      do not just randomly try wire position
      please follow this guide
      https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Connecting_stepper_motors
      • Harvdog1undefined
        Harvdog1 @Phaedrux
        @Phaedrux
        • Vetiundefined
          Veti
          @Harvdog1 said in Did I fry my new board....:
          you configured e0heat but connected the heater to e1
          you really should be recrimping those connectors.
          Harvdog1undefined 1 Reply Last reply Reply Quote 0
          • Harvdog1undefined
            Harvdog1 @Veti
            @Veti The crimper is in route. The hot end was connected like it is because I did it like one of the you tubers, he had his there. I see it now in position 1 and should be moved over to the left to zero.
            Thank you
            • Vetiundefined
              Veti
              if you follow a guide please have a look at
              https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+1:+Wiring/37
              it should be mostly be the same
              • Harvdog1undefined
                Harvdog1 @Veti
                @Veti The micro swiss hotend is working now, thank you. Is there a way to find out if the drivers are all ok?
                • Vetiundefined
                  Veti
                  you said you had one that is working already.
                  you can move that one to the different ports to test each driver.
                  only move the connector when the duet is powered off.
                  • Harvdog1undefined
                    Harvdog1 @Veti
                    @Veti I did try that with the known good wire, and the others did not work. When I plugged it back into the X, it no longer worked. So they are all down at the moment.
                    • Vetiundefined
                      Veti
                      what command are you using to test the movement?
                      • Harvdog1undefined
                        Harvdog1 @Veti
                        @Veti I did a G1 X10, that kind of thing, did a couple of G1 X-10
                        • Vetiundefined
                          Veti
                          did you issue M564 S0 H0 before like it says in the guide?
                          • Harvdog1undefined
                            Harvdog1 @Veti
                            @Veti said in Did I fry my new board....:
                            M564 S0 H0
                            I dont remember, I have tried so many things. I just did, and got the error of insufficient axes homed
                            • Vetiundefined
                              Veti @Harvdog1
                              you got that error after you put in M564 S0 H0 ?
                              that makes no sense
                              • Harvdog1undefined
                                Harvdog1 @Veti
                                @Veti Sorry, that was the error for the G1 X10. The M564 S0 H0 got a green light, but nothing happened that I can tell.
                                • Vetiundefined
                                  Veti
                                  the command on its own does not do any movements
                                  have you read the linked wiki page?
                                  its described there
                                  https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Checking_connected_stepper_motors
                                  • Harvdog1undefined
                                    Harvdog1 @Veti
                                    @Veti I will read that. X is working now, but goes the wrong way. Y and Z sound like they want to work, but do not go anywhere. Hot end works now. Bed heater is still down. Cant tell which is which as its a white wire. Tried it both way and get the error of rising too slow.
                                    Thank you so much
                                    • Vetiundefined
                                      Veti
                                      as phaedrux wrote, it wont work without pid tuning.
                                      for the motors please use the known good stepper and move them to y and test again.
                                      Harvdog1undefined 2 Replies Last reply Reply Quote 0
                                      • Harvdog1undefined
                                        Harvdog1 @Harvdog1
                                        @Harvdog1 I have been given alot of advice here, and I certainly appreciate it very much. What should my next step be?
                                        • Harvdog1undefined
                                          Harvdog1 @Veti
                                          @Veti Will do
                                          • Harvdog1undefined
                                            Harvdog1 @Harvdog1
                                            I put the cable on Y and Z, left it on the X driver and neither wants to go anywhere. Ge the insufficient axes homed error. Put it back on X, and get that error now, when it did follow the command a few minutes ago.
