    Did I fry my new board....
    1.9k
    • Harvdog1undefined
      Harvdog1 @Veti
      @Veti The crimper is in route. The hot end was connected like it is because I did it like one of the you tubers, he had his there. I see it now in position 1 and should be moved over to the left to zero.
      Thank you
      • Vetiundefined
        Veti
        @Harvdog1 said in Did I fry my new board....:
        if you follow a guide please have a look at
        https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+1:+Wiring/37
        it should be mostly be the same
        Harvdog1undefined 1 Reply Last reply Reply Quote 0
        • Harvdog1undefined
          Harvdog1 @Veti
          @Veti The micro swiss hotend is working now, thank you. Is there a way to find out if the drivers are all ok?
          • Vetiundefined
            Veti
            you said you had one that is working already.
            you can move that one to the different ports to test each driver.
            only move the connector when the duet is powered off.
            • Harvdog1undefined
              Harvdog1 @Veti
              @Veti I did try that with the known good wire, and the others did not work. When I plugged it back into the X, it no longer worked. So they are all down at the moment.
              • Vetiundefined
                Veti
                what command are you using to test the movement?
                • Harvdog1undefined
                  Harvdog1 @Veti
                  @Veti I did a G1 X10, that kind of thing, did a couple of G1 X-10
                  • Vetiundefined
                    Veti
                    did you issue M564 S0 H0 before like it says in the guide?
                    • Harvdog1undefined
                      Harvdog1 @Veti
                      @Veti said in Did I fry my new board....:
                      M564 S0 H0
                      I dont remember, I have tried so many things. I just did, and got the error of insufficient axes homed
                      • Vetiundefined
                        Veti @Harvdog1
                        you got that error after you put in M564 S0 H0 ?
                        that makes no sense
                        • Harvdog1undefined
                          Harvdog1 @Veti
                          @Veti Sorry, that was the error for the G1 X10. The M564 S0 H0 got a green light, but nothing happened that I can tell.
                          • Vetiundefined
                            Veti
                            the command on its own does not do any movements
                            have you read the linked wiki page?
                            its described there
                            https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Checking_connected_stepper_motors
                            • Harvdog1undefined
                              Harvdog1 @Veti
                              @Veti I will read that. X is working now, but goes the wrong way. Y and Z sound like they want to work, but do not go anywhere. Hot end works now. Bed heater is still down. Cant tell which is which as its a white wire. Tried it both way and get the error of rising too slow.
                              Thank you so much
                              • Vetiundefined
                                Veti
                                as phaedrux wrote, it wont work without pid tuning.
                                for the motors please use the known good stepper and move them to y and test again.
                                Harvdog1undefined 2 Replies Last reply Reply Quote 0
                                • Harvdog1undefined
                                  Harvdog1 @Harvdog1
                                  @Harvdog1 I have been given alot of advice here, and I certainly appreciate it very much. What should my next step be?
                                  • Harvdog1undefined
                                    Harvdog1 @Veti
                                    @Veti Will do
                                    • Harvdog1undefined
                                      Harvdog1 @Harvdog1
                                      I put the cable on Y and Z, left it on the X driver and neither wants to go anywhere. Ge the insufficient axes homed error. Put it back on X, and get that error now, when it did follow the command a few minutes ago.
                                      • Vetiundefined
                                        Veti @Harvdog1
                                        you need to issue M564 S0 H0 after each restart
                                        • Harvdog1undefined
                                          Harvdog1 @Phaedrux
                                          @Phaedrux said in Did I fry my new board....:
                                          M98 P"config.g"
                                          M98 P"config.g"
                                          HTTP is enabled on port 80
                                          FTP is disabled
                                          TELNET is disabled
                                          Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
                                          Error: Pin 'fan1' is not free
                                          Error: Fan number 2 not found
                                          Error: in file macro line 69 column 10: M591: string expected
                                          • Harvdog1undefined
                                            Harvdog1 @Veti
                                            @Veti Hello,
                                            I have tested all drivers with the known good stepper, and all drivers work. My X axis is working properly. The Y stepper motor wants to do something, as it gives off some power like it wants to move the Y axis, but it does not move the table. The Z stepper does not do anything at all when given a command to move. The E gets an error and wants a tool assigned I think.
                                            Vetiundefined A Former User? 2 Replies Last reply Reply Quote 0
