    Duet 3 Software reset mid print at seemingly random times
    359
    • sigfriedundefined
      sigfried @Veti
      @Veti This seems to have resolved my issue, running a couple longer prints to confirm. Will resolve once I've got a couple completed prints without a reset.
      • sigfriedundefined
        sigfried
        Alright, so having updated to 3.1.1, I'm still getting resets. Had one long print succeed, then several resets only 10-15 minutes into prints.
          Standalone or SBC?
          Can you include an M122 from after the crashes?
          There has been more improvements to stability in 3.2 which is currently release candidate 2. Up to you if you want to try pre-release firmware or wait for the full release.
          • sigfriedundefined
            sigfried
            Standalone. Here is the text from M122. Are there any risks to trying the pre-release firmware beyond instability?
            RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v1.01 or later (standalone mode)
            Board ID: 08DJM-956BA-NA3TN-6J1D6-3S86P-TVBUT
            Used output buffers: 1 of 40 (17 max)
            Static ram: 154604
            Dynamic ram: 162536 of which 76 recycled
            Exception stack ram used: 312
            Never used ram: 75688
            Tasks: NETWORK(ready,356) ETHERNET(blocked,436) HEAT(blocked,1188) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1424) TMC(blocked,204) MAIN(running,4528) IDLE(ready,76)
            Owned mutexes: LwipCore(NETWORK)
            Last reset 00:00:48 ago, cause: power up
            Last software reset at 2021-01-04 22:41, reason: Memory protection fault, spinning module GCodes, available RAM 75392 bytes (slot 1)
            Software reset code 0x4163 HFSR 0x00000000 CFSR 0x00000082 ICSR 0x04427804 BFAR 0x0100a8e4 SP 0x204128c4 Task NETW
            Stack: 0040f6dd 00406f7c 21000000 004633e8 61000000 10000000 20415abc a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5
            Error status: 0
            MCU temperature: min 28.7, current 37.6, max 37.7
            Supply voltage: min 23.9, current 24.0, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
            12V rail voltage: min 12.0, current 12.1, max 12.2, under voltage events: 0
            Driver 0: standstill, reads 39130, writes 14 timeouts 0, SG min/max 0/0
            Driver 1: standstill, reads 39131, writes 14 timeouts 0, SG min/max 0/0
            Driver 2: standstill, reads 39131, writes 14 timeouts 0, SG min/max 0/0
            Driver 3: standstill, reads 39132, writes 14 timeouts 0, SG min/max 0/0
            Driver 4: standstill, reads 39135, writes 11 timeouts 0, SG min/max 0/0
            Driver 5: standstill, reads 39136, writes 11 timeouts 0, SG min/max 0/0
            Date/time: 2021-01-04 23:27:04
            Slowest loop: 55.65ms; fastest: 0.21ms
            === Storage ===
            Free file entries: 9
            SD card longest read time 2.5ms, write time 0.0ms, max retries 0
            === MainDDARing ===
            === AuxDDARing ===
            Heater 0 is on, I-accum = 0.0
            Heater 1 is on, I-accum = 0.0
            Segments left: 0
            Movement lock held by null
            HTTP is idle in state(s) 0
            Telnet is idle in state(s) 0
            File is doing "M190 S65" in state(s) 0
            USB is idle in state(s) 0
            Aux is idle in state(s) 0
            Trigger is idle in state(s) 0
            Queue is idle in state(s) 0
            LCD is idle in state(s) 0
            SBC is idle in state(s) 0
            Daemon is idle in state(s) 0
            Aux2 is idle in state(s) 0
            Code queue is empty.
            === Network ===
            Slowest loop: 14.34ms; fastest: 0.03ms
            HTTP sessions: 2 of 8
            - Ethernet -
            State: active
            Error counts: 0 0 0 0 0
            === CAN ===
            Messages sent 191, longest wait 0ms for type 0
            === Linux interface ===
            State: 0, failed transfers: 0
            Last transfer: 48175ms ago
            RX/TX seq numbers: 0/1
            SPI underruns 0, overruns 0
            Number of disconnects: 0
            Buffer RX/TX: 0/0-0
            • Vetiundefined
              Veti @sigfried
              @sigfried said in Duet 3 Software reset mid print at seemingly random times:
              no 3.2-rc2 has been stable for me.
              • sigfriedundefined
                sigfried
                Thanks, I'll give 3.2 a try.
                  https://github.com/Duet3D/RepRapFirmware/releases
                  Be sure to read the release notes on the intervening releases.
                  • caviaraundefined
                    caviara
                    This post is deleted!
                      Phaedrux Moderator @sigfried
                      Turns out 3.2 final release is available now.
                      https://github.com/Duet3D/RepRapFirmware/releases/tag/3.2
                      sigfriedundefined 1 Reply Last reply Reply Quote 0
                      • sigfriedundefined
                        sigfried @Phaedrux
                        @Phaedrux Awesome, trying that now. Will report back once I've completed some longer prints.
                        • sigfriedundefined
                          sigfried
                          After a couple days of near continuous printing, it seems like 3.2 has resolved my issue. Marking as solved.
