    Capricorn PTFE Tubing XS- Low Friction
    85
    18.3k
    • Whitewolfundefined
      Whitewolf
      I dont know about suppliers I found it last week when I was browsing their site for a Titan Aero…. My extrusion has improved a bit and the last prints even the very fine details are now being picked up and have perfect perimeters/layers.
      • elmoretundefined
        elmoret
        Nice! Any chance you could post photos?
          Whitewolf
          I will get some to you when i get home tonight
          • saffiundefined
            saffi
            Huh, so this stuff really works? I thought it was just a bunch of ad copy.
            I may have to try some out, the XS is the opaque version that you can't see through, correct?
            Prusa i3 Style Printer with Duet WiFi, E3D Volcano, Bondtech BMG
              Whitewolf
              You can tell just holding it in your hand that there is a big difference. It is slicker than PTFE, stiffer and tighter tolerences.
                Whitewolf
                Yes it is the Opaque one, it is also supposed to be better for flexible filaments, ill be reporting back soon about that as I have some Taulman and matter hackers pro flexibles
                  Whitewolf
                  @elmoret:
                  Here is an LM8UU bearing with PLA 205c and no cooling at about 42mm/s
                  as you can see there are no defects, I will get some more prints tomorrow. I am tired and my kids have seemed to run off with my test prints again.
                    deckingman
                    @Whitewolf. What extruder are you using? I'd guess that you wouldn't want one that bites too deeply into the filament as hobbed bolt marks might cause it to jam with the tube bore being only .05 bigger than the filament OD.
                    Can't find a UK source. In fact, I can't find a UK source for any 1/8mm bore PTFE.
                      Whitewolf
                      It is a printed direct drive (no gearing) the spring is heavy duty even in its lowest setting the hobbed gear is very tight and filament cannot be pushed through without motor off.
                      As you can see from the photos i run the PTFE all the way to the gear (I want to be able to print flexibles from a bowden setup)
                      I have not had jamming issues but so far have only tested on PLA. I have not yet done softer filaments but will do so soon as i finish the pressure advance calibration.
                        Whitewolf
                        I also have the new E3D 0.9 degree stepper motor with titan which i plan to install right next to this one so i can do a side by side comparison
                          deckingman
                          I don't kind of get this 0.9 degree stepper on a Titan thing. I know E3D are selling them and it seems they have the motor made especially for them. But the steps per mm for a Titan with a standard 1.8 degree stepper are a tad over 400 which means that a 0.9 degree stepper will want over 800. Why would one need that sort of resolution? Or is there some other reason for having a 0.9 degree stepper motor on a geared extruder?
                            Whitewolf
                            I dunno, well see…. I think everything comes down to configuration.... thats why I want to do a side by side, I cannot imagine it will give me better resolution than I currently have maybe faster speeds while maintaining resolution, we'll see.
                              Whitewolf
                              If you zoom in on the top of this print you can see the lines… this is .2mm with a .4 nozzle and .4 extrusion width printed at 60mm /s.... really cant see the titan improving that or the 0.9 degree accept maybe at faster speeds
                              • botundefined
                                bot
                                How nicely does the XS stuff cut with a razor knife? Can it easily be "pointed" so it fits between the two drive gears, like normal PTFE tube, or does it crumble or is it hard to cut?
                                *not actually a robot
                                • elmoretundefined
                                  elmoret
                                  @deckingman:
                                  At 0.15mm filament width and 0.05mm layer height, 1mm of print length is 0.0075mm^3 of polymer.
                                  At 800 steps/mm, one step = 0.003mm^3 of polymer. So the benefit really is in very small extrusion widths/layer heights.
                                    Whitewolf
                                    @bot:
                                    Yes there is a photo above with exactly that…. I cut it to a V with scissors
                                      Whitewolf
                                      @elmoret:
                                      @deckingman:
                                      Good to know, thank you
                                        deckingman
                                        Yes. So when I have a nozzle that can print about 2 hairs breadth wide and 3/4 of a hairs breadth tall I might need the extra resolution. Can't see me running out to buy a nozzle that size any time soon.
                                          T3P3Tony administrators
                                          Ian, check this out:
                                          http://e3d-online.com/High-Res-015-Nozzles
                                          Imagine the time it would take to fill your build area with one of those!
                                            Whitewolf
                                            If my wife ever gets into 3d printing jewelry i might pick one of those up lol
