    Resume print
    1.1k
    • GT1Zaundefined
      GT1Za
      Hi everyone,
      I'm having an issue when I pause and resume a print, normally to change filament.
      The pause works flawlessly, which then enables me to switch filament. But when I resume, it homes the print head to the bottom left and then moves in a diagonal position to where it left, sounds good in theory, but the problem is that it often crosses the print before its reached the z height and knocks the print off the bed.
      Is there a way to get the resume to first travel to the correct z height then move to the x/y coords?
      • MikeSundefined
        MikeS
        On resume.g add this line at the start:
        G1 R1 Z5 F6000
        Change F6000 with your move speed. This wil first go 5mm above the position of the last print move before pause occurs.
          Can you post your pause and resume files?
          What firmware version are you running?
          • GT1Zaundefined
            GT1Za
            hi,
            sorry my resume looks like the below:
            G1 R1 X0 Y0 Z5 F6000 ; go to 5mm above position of the last print move
            G1 R1 X0 Y0 ; go back to the last print move
            M83 ; relative extruder moves
            G1 E10 F3600 ; extrude 10mm of filament
            @MikeS I see your line was already there. Any other ideas?
            • MikeSundefined
              MikeS
              @GT1Za first line is not the same...it has X0 Y0 which moves the head to pause position while lifting and is causing your problem. Add the line i told you at the beginning and it should first go 5mm above pause position and then move to where you hit pause. First thing i learn using duet is to give a read at the gcode documentation...it is really worth the time!
              GT1Zaundefined 1 Reply Last reply Reply Quote 0
              • GT1Zaundefined
                GT1Za @MikeS
                @MikeS ahh thanks, I didn't think the x0 y0 would make a difference considering x0 y0 is the front left of my bed and not the center.
                I'll give it a try and see.
                  I lift the head 5mm in the pause.g file after retracting and before moving to where I want the head while paused. While paused, it remains 5mm above the pause point. Then in resume.g I use G1 R1 X0 Y0 followed by G1 R1 X0 Y0 Z0.
                  • GT1Zaundefined
                    GT1Za
                    @dc42 would you mind copy and pasting your pause and resume codes?
                      dc42 administrators @GT1Za
                      @GT1Za said in Resume print:
                      ; Pause macro file
                      if state.currentTool != -1
                        G1 E-4 F2500		; retract 4mm
                      G91					; relative moves
                      G1 Z5 F5000			; raise nozzle 5mm
                      G90					; absolute moves
                      G1 X0 Y85 F10000
                      ;M106 S0
                      ; Resume macro file
                      G1 R1 X0 Y0 Z2 F5000	; move to 2mm above resume point
                      G1 R1 X0 Y0 Z0		; lower nozzle to resume point
                        G1 E4 F2500		; undo the retraction
                      • GT1Zaundefined
                        GT1Za
                        @dc42 I have tried to use your script but im still battling with the same issue.
                        In short, whats happeing is that when I pause, the print head moves to the front right of the bed as it should. I can then do the filament change or whatever is required, but when I resume the print, the print head moves in a diagonal motion to where it left, but often it hasnt reached the required height before it starts passing over the model and knocks it off the bed.
                        Is there a way to get the print head to only move to the Z height and not xy?
                        Alternatively on the pause to remain at its current (or slightly raised height) rather than it lowering to the normal starting z position?
                        For info there is the pause and resume:
                        Pause:
                        ; pause.g
                        ; called when a print from SD card is paused
                        ; generated by RepRapFirmware Configuration Tool v2.1.8 on Wed May 06 2020 11:04:16 GMT+0200 (South Africa Standard Time)
                        G1 E-2 F3600 ; retract 2mm of filament
                        G91 ; relative positioning
                        G1 Z5 F360 ; lift Z by 5mm
                        G90 ; absolute positioning
                        G1 X0 Y0 F6000 ; go to X=0 Y=0
                        Resume:
                        ; resume.g
                        ; called before a print from SD card is resumed
                        G1 R1 X0 Y0 Z0 ; go back to the last print move
                        G1 E2 F3600 ; extrude 2mm of filament
                          Can you post your config.g? Do you have other tool offsets?
                          • GT1Zaundefined
                            GT1Za @Phaedrux
                            @Phaedrux here is the config. Left out the networking part
                            M584 X0 Y1 Z2:4 E3 ; two Z motors connected to driver outputs Z and E1
                            M671 X-20:220 Y0:0 S0.5 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
                            M208 X-5:205 Y0:200 ; X carriage moves from -5 to 205, Y bed goes from 0 to 200
                            M92 X80.00 Y80.00 Z400.00 E408 ; set steps per mm
                            M566 X500.00 Y500.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
                            M203 X12000.00 Y12000.00 Z300.00 E3600.00 ; set maximum speeds (mm/min)
                            M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
                            M906 X800 Y800 Z900 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
                            M84 S30 ; Set idle timeout
                            M208 X0 Y-22.5 Z-2.5 S1 ; set axis minima
                            M208 X500 Y500 Z500 S0 ; set axis maxima
                            M558 P9 H5 F120 T6000 A2 ; set Z probe type to bltouch and the dive height + speeds
                            G31 P500 X-30.8 Y0 Z2.55 ; set Z probe trigger value, offset and trigger height
                            M557 X15:445 Y15:445 S20 ; define mesh grid
                            M305 P0 T100000 B4138 R2200 ; set thermistor + ADC parameters for heater 0
                            M305 P1 T100000 B4138 R2200 ; set thermistor + ADC parameters for heater 1
                            M106 P0 S1 I0 F500 H1 T30 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
                              I don't see anything unusual in there, unless you've got something in the homing files or start gcode?
                              • GT1Zaundefined
                                GT1Za
                                @Phaedrux I really dont think its the start code haha... but for safety sake here it is:
                                G28
                                G92 E0 ;Reset Extruder
                                G1 Z2.0 F3000 ;Move Z Axis up
                                G1 X10.1 Y20 Z0.28 F5000.0 ;Move to start position
                                G1 X10.1 Y200.0 Z0.28 F1500.0 E15 ;Draw the first line
                                G1 X10.4 Y200.0 Z0.28 F5000.0 ;Move to side a little
                                G1 X10.4 Y20 Z0.28 F1500.0 E30 ;Draw the second line
                                • GT1Zaundefined
                                  GT1Za
                                  S5 V2.mp4
                                  @Phaedrux @dc42
                                  Sorry guys I thought maybe a video to show this is the easiest.
                                  As you can see, when you hit resume, the nozzle drops from the correct height to resume, to x0 y0 z0 and then starts moving to go back to the resume point. This almost always knocks the print off the bed... How do I correct that?
                                    Phaedrux Moderator @GT1Za
                                    @GT1Za Is the video supposed to be only 3 seconds long? Though it looks like it's moving at a diagonal.
                                    Again, I ask what firmware version are you using? Send M115.
                                    • GT1Zaundefined
                                      GT1Za @Phaedrux
                                      @Phaedrux sorry I missed you asking for the firmware.
                                      The video was only 3 seconds because the forum will only allow a 4mb upload.
                                      Firmware is 2.02RC5
                                        Firmware is 2.02RC5
                                        I would suggest updating your firmware first. There were some issues in that time frame for resuming.
                                        Download this zip file, and in DWC, upload it to the system tab. Don't extract it first.
                                        • GT1Zaundefined
                                          GT1Za @Phaedrux
                                          @Phaedrux the reason I havent done this is because, well as you can see im not the greatest at firmware. My understanding is that most of the code for the config etc has changed? If I upload this wont it break my existing?
                                            No, 2.05 won't require changes to your config. RRF3 would require changes.
                                            GT1Zaundefined 2 Replies Last reply Reply Quote 0
