    Duet3 6CH + 3CH expansion board - Missing steps.
    153
    8.7k
    • evomotorsundefined
      evomotors @Phaedrux
      @Phaedrux said in Duet3 6CH + 3CH expansion board - Missing steps.:
      The way you have the jumpers set the Pi is powering the Duet.
      See here: https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Hardware_Overview#Section_5V
      To power them separately only the Internal 5V En jumper should be installed.
      So I was confused about this statement on https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Wiring_Diagram:
      The default 5V power configuration is Internal-5V-EN jumpered, 5V->SBC jumpered (the Duet is powering the SBC) , SBC->5V not jumpered. If you want the SBC to provide 5V to the Duet then remove the jumper from Internal-5V-EN and place a jumper on SBC-5V (leaving the 5V->SBC jumper in place). NOTE this bypasses the 5V protection and a fault on the SBC may damage the Duet.
        evomotors
        Corrected the jumpers, didn't fix my issue.
          @evomotors, I would still like to see an photo of a print that is problematic when the extruder is controlled by an expansion board, together with the GCode. Without that, I don't really know what issue it is that you are reporting.
          PS - are you using high extruder microstepping? I am doing a test print of a cylinder using a tool board to drive the extruder, which I was hopeful would show up any problems, in particular the effect of CAN clock sync jitter. The only way I can get it to produce hiccups is to run it at high speed and use x256 extruder microstepping.
          evomotorsundefined 1 Reply Last reply Reply Quote 0
            evomotors @dc42
            @dc42 said in Duet3 6CH + 3CH expansion board - Missing steps.:
            No high micro stepping, I did posted my config as you requested previously in this thread.. it's all there, I also posted gcode file.
            I'm not even looking on hiccups any longer. you can see the E driver position and compare it with what it should be according to filament usage.
              dc42 administrators @evomotors
              Thanks. I'll do that E drive position reporting check on my tool changer. It may be just a reporting issue.
              evomotorsundefined 2 Replies Last reply Reply Quote 0
                evomotors @dc42
                To prove the point I will be posting 2 videos today. One where XY connected to Duet3 and another where XY connected to 3CH expansion board. Both videos will demonstrate printing first few layers of exactly the same g-code file on the same printer. It's easier to see the issue where it starts shifting layers.
                  evomotors @dc42
                  @dc42 @Phaedrux
                  Here are promised videos. Use bookmarks to go directly to issue.
                  XY Motors connected to Duet 3 board
                  XY Motors connected to expansion board
                  Edit: attaching config files
                  xy_on_expansion.config.g
                  xy_on_duet3.config.g
                  Compressed gcode, renamed to *.txt
                  ZR_BearingTopMount_FR.zip.txt
                  Diagnostic after failed print (for M122 B1)
                  M122 B1
                  Diagnostics for board 1:
                  Duet EXP3HC firmware version 3.2 (2021-01-05)
                  Bootloader ID: not available
                  Never used RAM 154728, free system stack 154 words
                  HEAT 90 CanAsync 94 CanRecv 84 TMC 30 MAIN 315 AIN 257
                  Last reset 08:10:45 ago, cause: power up
                  Last software reset data not available
                  Driver 0: position -591153, 160.0 steps/mm,  standstill, reads 62793, writes 52 timeouts 0, SG min/max 0/1023
                  Driver 1: position -76259, 160.0 steps/mm,  standstill, reads 62795, writes 52 timeouts 0, SG min/max 0/1023
                  Driver 2: position 52354, 172.0 steps/mm,  standstill, reads 62807, writes 44 timeouts 0, SG min/max 0/156
                  Moves scheduled 4073, completed 4073, in progress 0, hiccups 218
                  No step interrupt scheduled
                  VIN: 24.7V, V12: 12.3V
                  MCU temperature: min 43.8C, current 44.0C, max 44.2C
                  Ticks since heat task active 245, ADC conversions started 29445736, completed 29445736, timed out 0
                  Last sensors broadcast 0x00000000 found 0 248 ticks ago, loop time 0
                  CAN messages queued 122, send timeouts 0, received 269109, lost 0, free buffers 36
                  Diagnostic after failed print (for M122)
                  M122
                  RepRapFirmware for Duet 3 MB6HC version 3.2 running on Duet 3 MB6HC v1.01 or later (SBC mode)
                  Board ID: 08DJM-956L2-G43S8-6JKDL-3SJ6L-1802G
                  Used output buffers: 1 of 40 (11 max)
                  Static ram: 149788
                  Dynamic ram: 63136 of which 68 recycled
                  Never used RAM 145840, free system stack 128 words
                  Tasks: Linux(ready,87) HEAT(blocked,296) CanReceiv(blocked,849) CanSender(blocked,344) CanClock(blocked,352) TMC(blocked,53) MAIN(running,673) IDLE(ready,19)
                  Owned mutexes: HTTP(MAIN)
                  Last reset 01:37:31 ago, cause: watchdog
                  Last software reset at 2021-01-11 20:53, reason: User, none spinning, available RAM 146296, slot 1
                  Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task Linu Freestk 0 n/a
                  Error status: 0x00
                  Aux0 errors 0,0,0
                  Aux1 errors 0,0,0
                  MCU temperature: min 35.9, current 37.4, max 38.4
                  Supply voltage: min 24.1, current 24.3, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
                  12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
                  Driver 0: position 70760, standstill, reads 54741, writes 24 timeouts 0, SG min/max 0/238
                  Driver 1: position 8428, standstill, reads 54741, writes 24 timeouts 0, SG min/max 0/236
                  Driver 2: position 1039, standstill, reads 54741, writes 24 timeouts 0, SG min/max 0/264
                  Driver 3: position 0, standstill, reads 54741, writes 24 timeouts 0, SG min/max 0/255
                  Driver 4: position 0, standstill, reads 54754, writes 11 timeouts 0, SG min/max 0/0
                  Driver 5: position 0, standstill, reads 54754, writes 11 timeouts 0, SG min/max 0/0
                  Date/time: 2021-01-11 22:30:54
                  Slowest loop: 187.54ms; fastest: 0.03ms
                  === Storage ===
                  Free file entries: 10
                  DMs created 125, maxWait 272324ms, bed compensation in use: mesh, comp offset 0.000
                  === MainDDARing ===
                  Scheduled moves 1805, completed moves 1805, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 2], CDDA state -1
                  === AuxDDARing ===
                  Heater 0 is on, I-accum = 0.4
                  Heater 1 is on, I-accum = 0.3
                  Segments left: 0
                  Movement lock held by null
                  Telnet is idle in state(s) 0
                  File* is idle in state(s) 0
                  USB is idle in state(s) 0
                  Aux is idle in state(s) 0
                  Queue* is idle in state(s) 0
                  LCD is idle in state(s) 0
                  SBC is idle in state(s) 0
                  Daemon is idle in state(s) 0
                  Aux2 is idle in state(s) 0
                  Code queue is empty.
                  === CAN ===
                  Messages queued 25218, send timeouts 0, received 41, lost 0, longest wait 1ms for reply type 6018, free buffers 48
                  === SBC interface ===
                  State: 4, failed transfers: 0
                  Last transfer: 2ms ago
                  RX/TX seq numbers: 13476/13476
                  SPI underruns 0, overruns 0
                  Number of disconnects: 0, IAP RAM available 0x2c8a8
                  Buffer RX/TX: 0/0-0
                  === Duet Control Server ===
                  Duet Control Server v3.2.0
                  Code buffer space: 4096
                  Full transfers per second: 35.91
                  Maximum length of RX/TX data transfers: 2800/1684
                  hackinistratorundefined 1 Reply Last reply Reply Quote 2
                    Thanks for the videos. It always helps to be able to see what's going on. Thanks for the time you've put into troubleshooting the issue.
                    While we wait for DC42 to get a chance to see your videos, could you do a test print for me using M566 P1 set?
                      evomotors @Phaedrux
                      M566 P1
                      Sure, do I need another video of it?
                        Phaedrux Moderator @evomotors
                        @evomotors Let's just see if it makes a difference at all.
                        The default jerk policy is 0, which replicates the behaviour of earlier versions of RRF (jerk is only applied between two printing moves, or between two travel moves, and only if they both involve XY movement or neither does). Changing the jerk policy to 1 allows jerk to be applied between any pair of moves.
                          evomotors @Phaedrux
                          Did test with following config changes.
                          M566 X500.00 Y500.00 Z50.00 E3000.00 P1
                          Failed the same way
                            Thanks for testing.
                            • jbarrosundefined
                              jbarros
                              Not trying to hijack the thread but I got "similar" issues on a 6HC + Toolboard running 3.2
                              I only see the issue on round surfaces on which there are no retractions (set at 0.2) and PA from the ~middle of the hole was set from 0.005 to 0 which made it worse?!
                              A previous print with bigger retraction 0.3 and bigger PA 0.02 had issues but not of this magnitude, which is curious.
                              I can start a new thread with all the info if necessary.
                                Phaedrux Moderator @jbarros
                                @jbarros said in Duet3 6CH + 3CH expansion board - Missing steps.:
                                Please do.
                                • hackinistratorundefined
                                  hackinistrator @evomotors
                                  @evomotors
                                  are you 100% sure that its "data loss" causing the issue ?
                                  it seems you set everything correctly (i'm far from being expert...) maybe the board ignores your current limit settings .
                                  can you try running the same gcode (or simple high accel macro) while the motors disconnected from the load (remove belts) ?
                                  i'm not sure its a comm speed issue . maybe the tboard simply ignores motor current settings .
                                  evomotorsundefined deckingmanundefined 2 Replies Last reply Reply Quote 0
                                    evomotors @hackinistrator
                                    @hackinistrator said in Duet3 6CH + 3CH expansion board - Missing steps.:
                                    @evomotors
                                    I'm not 100% sure that it's caused by data loss. If I set my motors current limits correctly it should not ignore them, unless there is a bug in the firmware.
                                    I prefer not to remove belts, but even if I do, what it is going to prove? How can you tell if gantry in the correct position if belts are disconnected?
                                    But you maybe correct, it does feels like motors ether underpowered or pulses are irregular on these fast moves. Unfortunately there is no way for me to tell, I don't have oscilloscope on hands. But it should be really easy for @dc42 to test.
                                    I'm still waiting for @dc42 to look at the videos and reply.
                                      deckingman @hackinistrator
                                      @hackinistrator Have you watched the videos that @evomotors posted? If the board ignores the motor current, then it does so selectively at some seemingly random time after a print starts, then restores it again immediately after.
                                      hackinistratorundefined 1 Reply Last reply Reply Quote 0
                                        evomotors
                                        I'm getting lonely here after proving existence of the issue. 👎
                                        @dc42 Do you want me to perform some additional tests?
                                          Thanks for your patience. He's aware and will respond ASAP.
                                            evomotors @Phaedrux
                                            Oh thanks! The good news that I'm not alone here.
                                            deckingmanundefined dc42undefined 2 Replies Last reply Reply Quote 0
