    Duet3 6CH + 3CH expansion board - Missing steps.
    153
    8.7k
    • evomotorsundefined
      evomotors @dc42
      @dc42 said in Duet3 6CH + 3CH expansion board - Missing steps.:
      Thanks. I'll do that E drive position reporting check on my tool changer. It may be just a reporting issue.
      @dc42 @Phaedrux
      Here are promised videos. Use bookmarks to go directly to issue.
      XY Motors connected to Duet 3 board
      XY Motors connected to expansion board
      Edit: attaching config files
      xy_on_expansion.config.g
      xy_on_duet3.config.g
      Compressed gcode, renamed to *.txt
      ZR_BearingTopMount_FR.zip.txt
      Diagnostic after failed print (for M122 B1)
      M122 B1
      Diagnostics for board 1:
      Duet EXP3HC firmware version 3.2 (2021-01-05)
      Bootloader ID: not available
      Never used RAM 154728, free system stack 154 words
      HEAT 90 CanAsync 94 CanRecv 84 TMC 30 MAIN 315 AIN 257
      Last reset 08:10:45 ago, cause: power up
      Last software reset data not available
      Driver 0: position -591153, 160.0 steps/mm,  standstill, reads 62793, writes 52 timeouts 0, SG min/max 0/1023
      Driver 1: position -76259, 160.0 steps/mm,  standstill, reads 62795, writes 52 timeouts 0, SG min/max 0/1023
      Driver 2: position 52354, 172.0 steps/mm,  standstill, reads 62807, writes 44 timeouts 0, SG min/max 0/156
      Moves scheduled 4073, completed 4073, in progress 0, hiccups 218
      No step interrupt scheduled
      VIN: 24.7V, V12: 12.3V
      MCU temperature: min 43.8C, current 44.0C, max 44.2C
      Ticks since heat task active 245, ADC conversions started 29445736, completed 29445736, timed out 0
      Last sensors broadcast 0x00000000 found 0 248 ticks ago, loop time 0
      CAN messages queued 122, send timeouts 0, received 269109, lost 0, free buffers 36
      Diagnostic after failed print (for M122)
      M122
      RepRapFirmware for Duet 3 MB6HC version 3.2 running on Duet 3 MB6HC v1.01 or later (SBC mode)
      Board ID: 08DJM-956L2-G43S8-6JKDL-3SJ6L-1802G
      Used output buffers: 1 of 40 (11 max)
      Static ram: 149788
      Dynamic ram: 63136 of which 68 recycled
      Never used RAM 145840, free system stack 128 words
      Tasks: Linux(ready,87) HEAT(blocked,296) CanReceiv(blocked,849) CanSender(blocked,344) CanClock(blocked,352) TMC(blocked,53) MAIN(running,673) IDLE(ready,19)
      Owned mutexes: HTTP(MAIN)
      Last reset 01:37:31 ago, cause: watchdog
      Last software reset at 2021-01-11 20:53, reason: User, none spinning, available RAM 146296, slot 1
      Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task Linu Freestk 0 n/a
      Error status: 0x00
      Aux0 errors 0,0,0
      Aux1 errors 0,0,0
      MCU temperature: min 35.9, current 37.4, max 38.4
      Supply voltage: min 24.1, current 24.3, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
      Driver 0: position 70760, standstill, reads 54741, writes 24 timeouts 0, SG min/max 0/238
      Driver 1: position 8428, standstill, reads 54741, writes 24 timeouts 0, SG min/max 0/236
      Driver 2: position 1039, standstill, reads 54741, writes 24 timeouts 0, SG min/max 0/264
      Driver 3: position 0, standstill, reads 54741, writes 24 timeouts 0, SG min/max 0/255
      Driver 4: position 0, standstill, reads 54754, writes 11 timeouts 0, SG min/max 0/0
      Driver 5: position 0, standstill, reads 54754, writes 11 timeouts 0, SG min/max 0/0
      Date/time: 2021-01-11 22:30:54
      Slowest loop: 187.54ms; fastest: 0.03ms
      === Storage ===
      Free file entries: 10
      DMs created 125, maxWait 272324ms, bed compensation in use: mesh, comp offset 0.000
      === MainDDARing ===
      Scheduled moves 1805, completed moves 1805, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 2], CDDA state -1
      === AuxDDARing ===
      Heater 0 is on, I-accum = 0.4
      Heater 1 is on, I-accum = 0.3
      Segments left: 0
      Movement lock held by null
      Telnet is idle in state(s) 0
      File* is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Queue* is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === CAN ===
      Messages queued 25218, send timeouts 0, received 41, lost 0, longest wait 1ms for reply type 6018, free buffers 48
      === SBC interface ===
      State: 4, failed transfers: 0
      Last transfer: 2ms ago
      RX/TX seq numbers: 13476/13476
      SPI underruns 0, overruns 0
      Number of disconnects: 0, IAP RAM available 0x2c8a8
      Buffer RX/TX: 0/0-0
      === Duet Control Server ===
      Duet Control Server v3.2.0
      Code buffer space: 4096
      Full transfers per second: 35.91
      Maximum length of RX/TX data transfers: 2800/1684
      hackinistratorundefined 1 Reply Last reply Reply Quote 2
        Thanks for the videos. It always helps to be able to see what's going on. Thanks for the time you've put into troubleshooting the issue.
        While we wait for DC42 to get a chance to see your videos, could you do a test print for me using M566 P1 set?
        evomotorsundefined 1 Reply Last reply Reply Quote 0
          evomotors @Phaedrux
          @Phaedrux said in Duet3 6CH + 3CH expansion board - Missing steps.:
          M566 P1
          Sure, do I need another video of it?
            Phaedrux Moderator @evomotors
            @evomotors Let's just see if it makes a difference at all.
            The default jerk policy is 0, which replicates the behaviour of earlier versions of RRF (jerk is only applied between two printing moves, or between two travel moves, and only if they both involve XY movement or neither does). Changing the jerk policy to 1 allows jerk to be applied between any pair of moves.
              evomotors @Phaedrux
              Did test with following config changes.
              M566 X500.00 Y500.00 Z50.00 E3000.00 P1
              Failed the same way
                Thanks for testing.
                • jbarrosundefined
                  jbarros
                  Not trying to hijack the thread but I got "similar" issues on a 6HC + Toolboard running 3.2
                  I only see the issue on round surfaces on which there are no retractions (set at 0.2) and PA from the ~middle of the hole was set from 0.005 to 0 which made it worse?!
                  A previous print with bigger retraction 0.3 and bigger PA 0.02 had issues but not of this magnitude, which is curious.
                  I can start a new thread with all the info if necessary.
                    Phaedrux Moderator @jbarros
                    @jbarros said in Duet3 6CH + 3CH expansion board - Missing steps.:
                    Please do.
                    • hackinistratorundefined
                      hackinistrator @evomotors
                      @evomotors
                      are you 100% sure that its "data loss" causing the issue ?
                      it seems you set everything correctly (i'm far from being expert...) maybe the board ignores your current limit settings .
                      can you try running the same gcode (or simple high accel macro) while the motors disconnected from the load (remove belts) ?
                      i'm not sure its a comm speed issue . maybe the tboard simply ignores motor current settings .
                      evomotorsundefined deckingmanundefined 2 Replies Last reply Reply Quote 0
                        evomotors @hackinistrator
                        @hackinistrator said in Duet3 6CH + 3CH expansion board - Missing steps.:
                        @evomotors
                        I'm not 100% sure that it's caused by data loss. If I set my motors current limits correctly it should not ignore them, unless there is a bug in the firmware.
                        I prefer not to remove belts, but even if I do, what it is going to prove? How can you tell if gantry in the correct position if belts are disconnected?
                        But you maybe correct, it does feels like motors ether underpowered or pulses are irregular on these fast moves. Unfortunately there is no way for me to tell, I don't have oscilloscope on hands. But it should be really easy for @dc42 to test.
                        I'm still waiting for @dc42 to look at the videos and reply.
                          deckingman @hackinistrator
                          @hackinistrator Have you watched the videos that @evomotors posted? If the board ignores the motor current, then it does so selectively at some seemingly random time after a print starts, then restores it again immediately after.
                          hackinistratorundefined 1 Reply Last reply Reply Quote 0
                            evomotors
                            I'm getting lonely here after proving existence of the issue. 👎
                            @dc42 Do you want me to perform some additional tests?
                              Thanks for your patience. He's aware and will respond ASAP.
                                evomotors @Phaedrux
                                Oh thanks! The good news that I'm not alone here.
                                deckingmanundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                  deckingman @evomotors
                                  @evomotors For want of anything better to say or suggest, have you tried commenting out the M593 (DAA) to see if that makes any difference? No reason for suggesting it other than it's something which modifies motion planning, which might get applied to main boards but not expansion boards. I don't know if that's even possible but testing without M593 would at least eliminate it as a potential cause. Just a thought if you've got nothing better to do while you are waiting...........
                                    dc42 administrators @evomotors
                                    @evomotors, I believe at least some of these issues are caused by CAN clock sync jitter, meaning that the expansion board clocks don't run perfectly in sync either the main board. When I measured it, I found that it was higher than I expected, frequently reaching 300us and sometimes more under conditions of high step rates and short move segments. Fortunately we've had a plan to reduce this jitter ever since we designed Duet 3. I've been working on this all day, and the jitter is now reduced to 13us even with heavy traffic. There is the possibility to reduce it still further.
                                    I have two other related issues to investigate before we release an early 3.3 beta.
                                    evomotorsundefined 1 Reply Last reply Reply Quote 1
                                      hackinistrator @deckingman
                                      @deckingman sure , i watched the vid.
                                      i'm not sure if the issue occurs at random time.
                                      if you check the vid , you can see the printer completed pretty fast accel moves without issues while moving on XY plane .
                                      the issue occurred when it was making fast diagonal move - single motor running .
                                      what is the default motor current on those drivers anyways ?
                                      maybe its a good idea to try and reduce motor current on exp. board to very low value and see if it has any effect .
                                      there are no CAN errors so i don't see how it can be comm. error .
                                        T3P3Tony administrators @hackinistrator
                                        @hackinistrator there is some timing jitter (as @dc42 has pointed out) that is not currently reported in 3.2.
                                        @evomotors thanks for all the work in detailing the problem, we are working on it!
                                          evomotors @dc42
                                          @dc42 @T3P3Tony
                                          Thank you for your hard work. Waiting to test the changes.
                                            I am pleased to report that we have made substantial progress on this issue. In addition to fixing the CAN clock jitter, we have identified and fixed an issue that could cause whole moves to be abandoned on CAN-connected expansion boards. We have only been able to reproduce this using high step rates and short moves, however the cause of the issue (floating point rounding error) could conceivably happen at lower step rates too.
                                            I expect to provide unofficial 3.3beta versions of all firmwares tomorrow.
                                            Luke'sLaboratoryundefined evomotorsundefined 2 Replies Last reply Reply Quote 2
