it seems to be a problem with the firmware in particular rotary delta kinematics
@Orang_ said in Rotary delta calibration not implemented?:
G1 F500 G0 F500
That won't have any effect on the G30 moves. You'll need to do something like this.
; bed.g ; called to perform automatic delta calibration via G32 ; ; generated by RepRapFirmware Configuration Tool v3.2.1 on Mon Jan 11 2021 22:12:55 GMT+0200 (Восточная Европа, стандартное время) M561 ; clear any bed transform G28 M566 X400 Y400 Z400 ; set maximum instantaneous speed changes (mm/min) M203 X6000 Y6000 Z6000 ; set maximum speeds (mm/min) M201 X400 Y400 Z400 ; set accelerations (mm/s^2) G30 P0 X0.00 Y80.00 Z-99999 H33.385 G30 P1 X69.28 Y-40.00 Z-99999 H33.385 G30 P2 X-69.28 Y-40.00 Z-99999 H33.385 G30 P3 X0.00 Y40.00 Z-99999 H33.385 G30 P4 X34.64 Y-20.00 Z-99999 H33.385 G30 P5 X-34.64 Y-20.00 Z-99999 H33.385 G30 P6 X0 Y0 Z-99999 S6 M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min) M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z500.00 E1000.00 ; set accelerations (mm/s^2) You might also want to reduce the travel speed in M558
M558 P5 C"^zstop" H5 F120 T1000
hiccups 37
That's much better
Also, is your motor current set appropriately for your motors? 60-85% of rated max is the rule of thumb.
@Phaedrux said in Rotary delta calibration not implemented?:
yes
also has no effect(((( -
Try to halve the speed values to 3000
sorry I have M203 X1000 Y1000 Z1000
could this have something to do with that t2 tool? the printer is set up so that 0 is the effector, or rather the fisheye center
; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M563 P2 S"2rr" D0 H1 F0 ; define tool 2 G10 P2 X0 Y0 Z-23.3 ; set tool 2 axis offsets G10 P2 R0 S0 M563 P5 S"TEST" D0 H1 F0 ; define tool 2 G10 P2 X0 Y0 Z-29.3 ; set tool 2 axis offsets G10 P2 R0 S0
You mean this?
Why does it go from P0 to P2 then P5, but P5 still uses G10 commands with P2?
I switched to rrf firmware not long ago
You mean this?
I mean that during normal movement the printer moves correctly, during arc calibration you can see it on the video. it can be related to the offset of the tool and the sensor
I'm not exactly sure how the -Z offset on tool2 is going to have an effect. I'm not even really sure what the reasoning or intension is there.
You're using an IR sensor though, so you should have an XY offset configured for it in G31
G31 X0 Y0 Z33.385 P25
And the Z trigger height should be calibrated.
https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
I would try simplifying your tool definitions to
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0CAnd then select T0 at the end of config.g instead of T2
Then try G32 again.
https://github.com/Duet3D/RepRapFirmware/blob/dev/src/Movement/Kinematics/RotaryDeltaKinematics.cpp
221 bool RotaryDeltaKinematics::DoAutoCalibration(size_t numFactors, const RandomProbePointSet& probePoints, const StringRef& reply) 222 { 223 return true; // auto calibration not implemented yet 224 } 225 226 // Write the parameters that are set by auto calibration to a file, returning 227 true if success 228 bool RotaryDeltaKinematics::WriteCalibrationParameters(FileStore *f) const 229 { 230 return true; // auto calibration not implemented yet 231 } -
I understand correctly that there is no calibration for rotary delta?
That is correct. The problem is that there are potentially many calibration variables for a rotary delta. For example, there are two pivot locations (like the tower position corrections for a linear delta), three upper arm lengths, three lower arm lengths, three pivot height corrections, three homing position corrections, and the delta radius. That's 18 parameters. It's unlikely the by probing a flat bed and measuring the height errors, it would be possible to calibrate all of these. However, if some of these are known to be accurate (for example, if all the arms are manufactured to precise lengths) then it may be possible to auto-calibrate the remaining parameters.
I can try adding auto calibration when I have time, but it might not give very good results.
@dc42 said in Rotary delta calibration not implemented?:
I can try adding auto calibration when I have time, but it might not give very good results.Thank you, I really like your firmware, if there are any changes with the calibration, please let me know, I would be happy to test it. Also there is not a big group of people who own similar printers I think they will also support it.
I'll just make @gloomyandy aware of this thread
@Orang_ on another note. Is there a good project for building one? Saw this one this week: https://www.youtube.com/watch?v=Tj1KAbq99dc
@PCR I have one of these https://www.youtube.com/watch?v=COUdIsoDgMw&ab_channel=AlexKorvinWorkshop
@jay_s_uk but smoothie doesn't work quite right.
