    Rotary delta calibration not implemented?
    LPC
    4.4k
    • Orang_undefined
      Orang_
      could this have something to do with that t2 tool? the printer is set up so that 0 is the effector, or rather the fisheye center
        Phaedrux Moderator @Orang_
        @Orang_ said in Rotary delta calibration not implemented?:
        ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M563 P2 S"2rr" D0 H1 F0 ; define tool 2 G10 P2 X0 Y0 Z-23.3 ; set tool 2 axis offsets G10 P2 R0 S0 M563 P5 S"TEST" D0 H1 F0 ; define tool 2 G10 P2 X0 Y0 Z-29.3 ; set tool 2 axis offsets G10 P2 R0 S0
        You mean this?
        Why does it go from P0 to P2 then P5, but P5 still uses G10 commands with P2?
        Orang_undefined 1 Reply Last reply Reply Quote 0
        • Orang_undefined
          Orang_ @Phaedrux
          @Phaedrux said in Rotary delta calibration not implemented?:
          I switched to rrf firmware not long ago
          • Orang_undefined
            Orang_
            You mean this?
            I mean that during normal movement the printer moves correctly, during arc calibration you can see it on the video. it can be related to the offset of the tool and the sensor
              I'm not exactly sure how the -Z offset on tool2 is going to have an effect. I'm not even really sure what the reasoning or intension is there.
              You're using an IR sensor though, so you should have an XY offset configured for it in G31
              G31 X0 Y0 Z33.385 P25
              And the Z trigger height should be calibrated.
              https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
              I would try simplifying your tool definitions to
              And then select T0 at the end of config.g instead of T2
              Then try G32 again.
              • Orang_undefined
                Orang_
                https://github.com/Duet3D/RepRapFirmware/blob/dev/src/Movement/Kinematics/RotaryDeltaKinematics.cpp
                221 bool RotaryDeltaKinematics::DoAutoCalibration(size_t numFactors, const RandomProbePointSet& probePoints, const StringRef& reply)
                222 {
                223 	return true;	// auto calibration not implemented yet
                224 }
                225
                226 // Write the parameters that are set by auto calibration to a file, returning 227 true if success
                228 bool RotaryDeltaKinematics::WriteCalibrationParameters(FileStore *f) const
                229 {
                230	return true;	// auto calibration not implemented yet
                231 }
                • Orang_undefined
                  Orang_ @Orang_
                  I understand correctly that there is no calibration for rotary delta?
                    dc42 administrators @Orang_
                    That is correct. The problem is that there are potentially many calibration variables for a rotary delta. For example, there are two pivot locations (like the tower position corrections for a linear delta), three upper arm lengths, three lower arm lengths, three pivot height corrections, three homing position corrections, and the delta radius. That's 18 parameters. It's unlikely the by probing a flat bed and measuring the height errors, it would be possible to calibrate all of these. However, if some of these are known to be accurate (for example, if all the arms are manufactured to precise lengths) then it may be possible to auto-calibrate the remaining parameters.
                    I can try adding auto calibration when I have time, but it might not give very good results.
                    • Orang_undefined
                      Orang_
                      @dc42 said in Rotary delta calibration not implemented?:
                      Thank you, I really like your firmware, if there are any changes with the calibration, please let me know, I would be happy to test it. Also there is not a big group of people who own similar printers I think they will also support it.
                      PCRundefined dc42undefined 2 Replies Last reply Reply Quote 0
                        jay_s_uk
                        I'll just make @gloomyandy aware of this thread
                        • PCRundefined
                          PCR @Orang_
                          @Orang_ on another note. Is there a good project for building one? Saw this one this week: https://www.youtube.com/watch?v=Tj1KAbq99dc
                          • Orang_undefined
                            Orang_ @PCR
                            @PCR I have one of these https://www.youtube.com/watch?v=COUdIsoDgMw&ab_channel=AlexKorvinWorkshop
                            • Orang_undefined
                              Orang_ @Orang_
                              @Orang_ https://www.thingiverse.com/thing:3489886
                              • Orang_undefined
                                Orang_ @jay_s_uk
                                @jay_s_uk but smoothie doesn't work quite right.
                                  jay_s_uk @Orang_
                                  @Orang_ who said anything about smoothieware?
                                  • alankilianundefined
                                    alankilian @jay_s_uk
                                    @jay_s_uk I think he's saying smoothie (which runs on that thingiverse-link printer) doesn't work, so he's looking at Duet firmware.
                                    • Orang_undefined
                                      Orang_ @alankilian
                                      The project specified in the link works on smoothie. but I reconfigured it to rrf
                                      jay_s_ukundefined 1 Reply Last reply Reply Quote 1
                                        jay_s_uk @Orang_
                                        @Orang_ ah, ok. no problem
                                          Do you know which parameters of your machine are likely to be accurate, and which need to be calibrated?
                                          Another issue may be available memory. The RAM needed to do the calculation goes up as the square of the number of parameters to be calibrated. Nine is OK because that's the maximum supported on linear delta printers.
                                          Orang_undefined 2 Replies Last reply Reply Quote 0
                                          • Orang_undefined
                                            Orang_ @dc42
                                            M669 K10 U169.85 L320 R55.94 A-45:52 H432 X-60,Y60,Z180
                                            U, L, - maybe accurate enough to measure;
                                            R,H - within a small margin of error
                                            A - it is difficult to measure without special tools
                                            x y z - depends on the construction of the printer
