Changing pt100 to standard thermistor
3.0k
    Atraedes
    thanks again, so i made the changes you advised straight to the config files incl the config in sys folder on the sd card, loaded back into the machine, then ran pid tune, got this - "Auto tune heater 0 completed in 1489 sec
    Use M307 H0 to see the result, or M500 to save the result in config-override.g", but then when i entered M500 via the console it answered - "M500
    Warning: No M501 command was executed in config.g". Did i do something wrong?
    undefined 1 Reply Last reply 12 Jan 2021, 19:08 Reply Quote 0
      Atraedes
      i then tried M501, and got this - "M501
      Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 692C.", feels like im back to square one lol, but the whole hotend, cables and all, are new, and confirmed 24v
      undefined 1 Reply Last reply 12 Jan 2021, 19:42 Reply Quote 0
        Veti @Atraedes
        @Atraedes said in Changing pt100 to standard thermistor:
        add M501 to the end of your config.g
          Atraedes
          so remove the SD card from the machine and type M501 at the very end of the config file? Can i not send that via the console?
          undefined 1 Reply Last reply 12 Jan 2021, 19:11 Reply Quote 0
            Veti @Atraedes
            @Atraedes
            just edit the file using the web ui
              Atraedes
              sorry i dont know how to do that, im still learning the ropes with the duet3d board i have
                Veti
                please read
                https://duet3d.dozuki.com/Wiki/Duet_Web_Control_Manual
                  Oh wow, I didn't realize you weren't even connected to the web interface yet.
                  https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7
                  It definitely makes a world of difference.
                    Atraedes
                    so if i understood correctly, ive gone into system in the web ui, found config.g, opened and typed M501 at the end of the file, and its asking if do i want to reset the board and apply the update? is that correct?
                      Atraedes
                      no sorry, i probably didnt explain, i am using the web ui, all the time,and running these commands via the console in the web ui, but i thought it was a simple M500 via the console in web ui to save it, and it doesnt
                        Yes you have to edit config.g and add M501 at the end.
                        As I said, M500 saves SOME settings (like PID tuning or other measured values) to the file config-override.g. And M501 loads that files.
                        https://duet3d.dozuki.com/Wiki/Gcode#Section_M500_Store_parameters
                          Atraedes
                          ok thanks, so to try solve these spurious heating faults, run my pid tune, after it shows results then go into system in the web ui, into config.g, M501 at the end of the file, and reset the board and apply the update?
                            Phaedrux Moderator @Atraedes
                            That's not a heater fault. It's a warning.
                            https://duet3d.dozuki.com/Wiki/FAQ#Section_M307_Heater_1_appears_to_be_over_powered_If_left_on_at_full_power_its_temperature_is_predicted_to_reach_521C
                              PID tune, send M500 in console, add M501 to config.g. done.
                              undefined 1 Reply Last reply 12 Jan 2021, 22:31 Reply Quote 0
                                Atraedes
                                awesome thanks, much appreciated
                                  Atraedes
                                  oh my good lord i am losing my mind...I've done everything, seemed fine, heated up hotend to 200c to do a test cube, and "M501
                                  Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 612C.", and then "Error: Heating fault on heater 1, temperature excursion exceeded 15.0°C", and it cools down the hotend. I know the first is a warning which i could live with but it then goes into error! Sorry I know i seem like a noob and keep asking questions but i dont get it lol, cables seem fine and ive rechecked everything, do you think there may be another fault elsewhere or is it likely the cables?
                                    Veti
                                    post a picture of the temperature graph.
                                    also do you have the silicone sock on?
                                      Atraedes
                                      Yes got a sock on, and thanks for your assistance
                                        Atraedes
                                        sorry did you want me to rest the hotend and heat again first?
                                          Atraedes
                                          reset the hotend even
                                          42 out of 76
